Team Corally RDX Touring Car >
Old 08-23-2006, 02:09 PM
  #8596
Default rubber vs foam
I have an RDX already set up for foam racing but I'm worried about showing up to race and there not being a foam class. What would be the changes I would need to make to my foam setup to make it rubber worthy? I would also have to make these changes at the track 10 minutes before racing starts because I was just told there is no foam class.
Parts:
One way
Shocks - I have an extra set of Tamiya shocks I can dedicate to rubber
Tires - of course
Anything else??
Setup:
What changes from my foam setup??
Or should I just buy a whole new car? $$$$$
slow is offline
Old 08-23-2006, 03:53 PM
  #8597
Im wanting to pick up a few things for my RDX can someone point me in the direction of who has a really big surplus of parts for these cars.
Thanks Brendan
mtmmotorcycles is offline
Old 08-23-2006, 04:45 PM
  #8598
Trader Rating: 38 (100%+)
Originally Posted by Jeff Brown
It is possible the stock ones might get compressed too much. Tough to say since we don't assemble them. I always rebuild things that come preassembled. Also make sure the flat side of the snap ring is facing outward.
I am not sure the effects of the smaller thrust washer on the outside. I will have to check with Rob.
Jeff
When you say outward. Do you mean outward toward my snapring pliers or outword toward the outside of the diff assembly (like toward the dogbone).
or8ital is offline
Old 08-23-2006, 06:04 PM
  #8599
Big Rigg's Avatar
I'm pretty sure he meant outward as in toward the rest of the diff (or toward your pliers ), becasue that would be 'out' when your putting it together, (the reason I believe is if the beveled side is 'out' it will be more likely to bend and it'll be a pain to get out the next time you build it)
Big Rigg is offline
Old 08-23-2006, 06:30 PM
  #8600
Trader Rating: 9 (91%+)
New Front Arms
- Outside Hole is the same as the old arms with the short extension installed
- Inside Hole is the same as the old arms outside hole
New Rear Arms
- Inside Hole is the old arms outside hole
- Middle Hole is the old arms Short Extension
- Outside Hole is the old arms with SRC X-Long Extensions
Hopefully that makes sense!!
Johnny Carey is offline
Old 08-23-2006, 06:42 PM
  #8601
New Front Arms
New Rear Arms
Almost, but the extension was never used on the front arms. Unless you mean the spacer to move the shock out away from the arm, but that made foam tires hit too much, so is never really used.
Stealth_RT is offline
Old 08-23-2006, 06:46 PM
  #8602
Yes I know, SeaBall had commented if he had only put front arms all the way around.
Old 08-23-2006, 07:02 PM
  #8603
Joel Lagace's Avatar
Thanks guys! Its as clear as mud! LOL When i saw the car i was so excited that all 4 corners where the same.... LOL but i can stop progress.
Joel Lagace is offline
Old 08-23-2006, 07:16 PM
  #8604
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Just use the "old" arms that are the same at all 4 corners. With the src bumper I haven't broken an arm in a long time. And I aint no A main driver. I plan on using them till I can't get them any more.
andrewdoherty is offline
Old 08-23-2006, 09:37 PM
  #8605
Jeff Brown's Avatar
Thanks Brendan
AB Charles & Son, Speedtech RC, Stormer Hobbies, Superior Hobbies..........
Speedtech has gotten bigger so they move quickly, same with Stormer. AB Charles usually has a great selection, as with Superior.
Jeff
Jeff Brown is offline
Old 08-23-2006, 10:27 PM
  #8606
Superior has great service!
Old 08-23-2006, 10:42 PM
  #8607
Still Bill's Avatar
Corally USA/Specialized is great...Thanks to Jeff.
Still Bill is offline
Old 08-24-2006, 04:35 AM
  #8608
Jeff, I sent an email to [email protected]. Does that mail get checked?
or8ital is offline
Old 08-24-2006, 12:21 PM
  #8609
Trader Rating: 6 (88%+)
thanks jeff for letting fullthrottle motorsport's be part of your team
BILL.D is offline
Old 08-24-2006, 04:34 PM
  #8610
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Jeff Brown, Korey etc.
Are you guys running the long ball stud on the steering knuckles on asphalt with the standard roll center blocks?
Or is this change for the ultra low roll blocks only?
J.Gonzalez is offline
