Old 08-16-2006, 09:13 PM   #8506
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Jeff Brown
Hot........ Hot?! LOL...... I don't leave the shop during the day.
Jeff
Hell its that hot here!! Im tired of 100 degree days Im ready to see snow and CARPET!!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-16-2006, 09:32 PM   #8507
T1Raycer's Avatar
hey guys where i can buy the new arms whit paypal????? cause i dont really liek to use the credit card
Later!!
T1Raycer is offline   Reply With Quote
Old 08-16-2006, 11:27 PM   #8508
Still Bill's Avatar
Jeff,
I just thought...On my outdoor car, I have the new arms on the front and the old arms (with extensions) on the rear. Can you make a setup sheet for that instance?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-17-2006, 04:52 AM   #8509
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I ordered a four set of the xray T2 hexes. When measured at the track they were 5 mm thick compared to the corally narrow thickness of 4.5 mm. Test fitted them and they worked awesome. Allowed me to snug them up nicely. Ill let y'all know how it turns out when they come in.
And for those of you who care I also saw that xray makes an offset -.75 mm set of hexes also. I assume these are 4.25 mm thick. Don't know if this matters to anyone but its info nonetheless.
Old 08-17-2006, 06:21 AM   #8510
Fervidsea's Avatar
Default Hexs?
Why would you want the wider hexs vs. the standard ones?
Fervidsea is offline   Reply With Quote
Old 08-17-2006, 11:44 AM   #8511
Big Rigg's Avatar
The new arms never had toe built into them from everything I understood. It would not make sense to do that. The latest batch we received should be straight as well.
Jeff
hmmm... I have 2 cars 1 with old style arms and 1 with new... the old style has 2 shims to make 2 degrees and the new arms only have 1 shim to make 2 degrees. Other people I have talked to have had this same experience
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 08-17-2006, 05:42 PM   #8512
T1Raycer's Avatar
hey jeff brown check your Private Message!!
Later!
Old 08-17-2006, 08:40 PM   #8513
The narrow ones keep breaking on me.
Old 08-18-2006, 04:32 PM   #8514
Got tired of the cracked rear narrow hexes on my car, and the lack of interest in anyone finding/making solid hexes, so I made my own. Took a full set of solid hexes I had from YEARS ago, that I ran on my Yok YR-4M, and were about 10mm wide, and machined them down to ~3.78 mm width. Added some thin 5mm axle shims behind the drive pin, and went racing! Since these hexes are even narrower than the narrow RDX hexes, I put a full 3 mm of shims behind the hinge pin mounts. RDX narrow hexes are ~4.15 mm wide, plus the 'lip' on the back that rides on the bearing race.
Stealth_RT is offline   Reply With Quote
Old 08-19-2006, 10:51 AM   #8515
gmintimidator's Avatar
I am looking at replacing my TC3 with an RDX (used off this forum). My question for you guys, is which kit should I be buying? I run 6 cell stock. I have heard people talking about the 2.9mm chassis is good for stock, but I want to be sure as it's like $100 to replace with the 4mm Carpet Spec chassis!
Is there anything you'd suggest getting for the car for tuning?
gmintimidator is offline   Reply With Quote
Old 08-19-2006, 12:20 PM   #8516
T1Raycer's Avatar
6 cells stock hum kk
Rubber or Foam????
Old 08-19-2006, 12:28 PM   #8517
Opps, sorry about that...
I am on foam, older carpet, using Jack the ripper. It's also road coarse
Old 08-19-2006, 12:30 PM   #8518
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
The carpet spec kit would be good for you then.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-19-2006, 12:34 PM   #8519
What thickness chassis and top plate come in the Carpet spec car?
The Corally site lists it as 2.9 bottom with a 3.4 top.. is that correct? So the only difference in the 2 cars is the top deck, and the kit gives you a spring set?
Old 08-19-2006, 12:54 PM   #8520
The carpet spec comes with a 3.4 mm topdeck, 2.9 mm chassis.
Other differences between the carpet spec and UK spec:
Carpet spec comes with:
x-Hard 75% arms
4 degree caster blocks instead of 2
Silver spring set
USVTA Member #211
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
