Team Corally RDX Touring Car >
Old 08-14-2006, 07:42 PM
  #8461
Mr. McGoo's Avatar
Originally Posted by andrewdoherty
At least now I have an excuse to cover my poor driving.
nice try awd...
Mr. McGoo is offline
Old 08-14-2006, 08:09 PM
  #8462
syndr0me's Avatar
Trader Rating: 32 (100%+)
Surprise, surprise, another bent front bulkhead! Do you breathe heavily? I hear that can sometimes make them warp.
I usually lay them on my pit board, hold one end down firmly and then tap the other end. If I hear a click, it means it's tapping against the board, and probably slightly bent. I usually notice it when the bearings seize, or most often when the holes that the bumper plate screws into stretch out, and seem like they're stripped. Every time that happens, it's another $20 bulkhead. I haven't had trouble with the rear, just the front.
syndr0me is offline
Old 08-14-2006, 08:19 PM
  #8463
Trader Rating: 38 (100%+)
Originally Posted by or8ital
I got a second RDX this week and am having some problems with the new kit. The hexes dont fit on the axles (and as a result I stripped the threads on 3 of them). Anyone else had this problem? I measured the axle diameter at 4.95mm and the hex at 5.05 to 5.1mm. The hex wont hold tight against the axle. Am I doing something wrong? If not will Corally replace the broken hexes and whichever part is out of spec?
Anyone?
or8ital is offline
Old 08-14-2006, 09:16 PM
  #8464
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Where are you getting them for 20$?
Orbital,
Perhaps the drive pins are too long and are not allowing the hex to clamp to its smallest dia?
andrewdoherty is offline
Old 08-14-2006, 10:05 PM
  #8465
syndr0me's Avatar
Stormer when he's got 'em. I bought their last two a couple of months ago and haven't seen any show up since then.
syndr0me is offline
Old 08-14-2006, 10:16 PM
  #8466
syndr0me's Avatar
This is kinda nice looking:
http://www.teamcorallyaustria.at/07_...ver/index.html
syndr0me is offline
Old 08-15-2006, 05:15 AM
  #8467
Seems a very good idea
http://video.yahoo.com/video/play?vi...14e6bbf.683651
Andyg01 is offline
Old 08-15-2006, 06:09 AM
  #8468
sohlman's Avatar
Trader Rating: 89 (100%+)
Anyone?
I had the same problem. I reamed them out with a step reamer drill bit and now they fit snug.
sohlman is offline
Old 08-15-2006, 08:25 AM
  #8469
Ted B.'s Avatar
On the setup sheets there is a value called "shims under the couplers". What excatly does this value pertain to?
Also, I've noticed that your steering travel in the front is basically maxed out when inside of the front tires hit the shocks when they are fully turned in. Is there any way around this to get more steering travel?
Ted B. is offline
Old 08-15-2006, 08:42 AM
  #8470
Jeff Brown's Avatar
These are the softest arms, right? Mostly for asphalt? Carpet guys should be waiting for the 80's?
No. Do not wait for the 80's as they probably will not exist. The arms are way more beefy so the available compounds are changing most likely. The New 35 arms are between the 50 and 75% old arms. I would use them for carpet and asphalt.
Jeff
Jeff Brown is offline
Old 08-15-2006, 08:47 AM
  #8471
HarshGuy's Avatar
Jeff
Dude, what do you have against the 80's? Disco, Maimi Vice (the real one), Cheap Gas ...it was a wonderful era.
HarshGuy is offline
Old 08-15-2006, 08:53 AM
  #8472
Jeff Brown's Avatar
Also, I've noticed that your steering travel in the front is basically maxed out when the front tires hit the shocks when they are fully turned in. Is there any way around this to get more steering travel?
Shims...... the amount of shims behind your roll center blocks. In the front it controls the width of the car.
Steering travel...... on rubber tire it is plenty of throw. On foam tires it is usually enough, you can shave the tires a bit to get a little more. You could also move the front shocks in a hole on the tower and arm, but you will have to increase your spring rate and oil.
Jeff
Old 08-15-2006, 08:56 AM
  #8473
Jeff Brown's Avatar
Nothing....... Miami Vice rocked. Along with The A-Team, The Fall Guy.....
Jeff
Old 08-15-2006, 09:09 AM
  #8474
What about knight rider ?
Chris Reilly is offline
Old 08-15-2006, 09:19 AM
  #8475
Suspended
McSmooth's Avatar
Talking
.....400+ 1/12 scale entries in Cleveland.....
McSmooth is offline
