Team Corally RDX Touring Car >
Old 08-01-2006, 06:49 PM
  #8356
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by EAMotorsports
You can also put two springs end to end and compress them against each other. The softer spring will compress fully first. Be careful though...they will shoot out across the room if you dont get it right
EA
If you put the 2 springs on a nut driver or decent size screwdriver, they are easier to keep a hold of. The driver helps to keep them upright, and they don't shoot out sideways and scar you for life.
robk is offline
Old 08-01-2006, 07:17 PM
  #8357
Regional Moderator
Jim Herrmann's Avatar
Always thinking, is this guy.
Jim Herrmann is offline
Old 08-01-2006, 07:51 PM
  #8358
Team EAM
Trader Rating: 79 (100%+)
I always point them away from me so it scars the guy next to me for life
J/k of course!!
EA
EAMotorsports is offline
Old 08-01-2006, 08:57 PM
  #8359
Korey Harbke's Avatar
EA
Or they shoot into your FACE!!!!!
Korey Harbke is offline
Old 08-01-2006, 09:10 PM
  #8360
Jimmy Morris's Avatar
yeah I was squeezing 2 springs together and they sprang out and hit me in the face. owwies!
Jimmy Morris is offline
Old 08-01-2006, 09:12 PM
  #8361
I'll remember to point them at EA in vegas
Old 08-01-2006, 10:11 PM
  #8362
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'll take a shock spring to the face ANY day over one of those clips that keep the o-ring in the bottom of the shock. Those things are evil.
syndr0me is offline
Old 08-01-2006, 10:18 PM
  #8363
AT MY LOCAL TRACK I RUN MY SHOCKS ALL THE WAY IN ON THE REAR BUT INSTEAD OF A WASHER INBETWEEN THE SHOCK AND TOWER I USE A NUT FOR MORE CLEARANCE AND I HAVE NO PROBLEMS I CANT POST PICTURES OR I WOULD
ERTRACHTER is offline
Old 08-02-2006, 04:41 PM
  #8364
CHRIS CHAVEZ's Avatar
Hey Jason,
Are you also adding extra spacers or nuts to the bottom of the shock mount?
or is it only on the top?
CHRIS CHAVEZ is offline
Old 08-02-2006, 04:47 PM
  #8365
I need some advice on freeing up the pivot balls on the top and bottom of the shocks.
Old 08-02-2006, 04:52 PM
  #8366
TeamPink91's Avatar
It's probably from overtightening the screw/nut onto the pivot ball and making the ball expand inside the ball end. I'm not real sure how you would fix that though.
TeamPink91 is offline
Old 08-02-2006, 04:56 PM
  #8367
That definitely makes sense. Although, when i first installed the pivot balls i noticed that some moved freely and some didn't.
Old 08-02-2006, 05:25 PM
  #8368
Big Rigg's Avatar
Hey Jason,
I'll pinch hit... I'm pretty sure (96.3333%) he has no spacers on the bottom with the new style arms... with the old style arms he had a silver spacer in the fronts and the regular extension piece in the rear. I might be wayyy off though depending on what setup he's running...
Big Rigg is offline
Old 08-04-2006, 08:43 PM
  #8369
Jeff Brown's Avatar
Jeff Brown is offline
Old 08-04-2006, 09:12 PM
  #8370
syndr0me's Avatar
Kinda quiet around here, eh? Seems like Corally's success is definitely making a difference. After being the only RDX guy in town for the last year and a half, a few local regulars are buying or considering kits.
Among racers, I get the impression that Corally's dedication to improving the existing car, and the outstanding support from the team drivers at large events (so I'm told) is going a long way. Good job, guys. :-)
syndr0me is offline
