Old 08-01-2006, 08:56 AM   #8341
Mission_carbon's Avatar
Arrrr!! I still havent sorted my spring problem out yet Because they were all mixed up i need them to get sorted before the Natts coming up in 2 weeks, Is it possible maybe some one could take a close pictured of each spring a lable it so i can see the diffrence between yours and myn?
Thanks,
Willz
Mission_carbon is offline   Reply With Quote
Old 08-01-2006, 10:16 AM   #8342
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
will,
i don't run the corally springs, but i had a similar experience with mine. there are a few things that you can inspect:
1) wire diameter - measure them with a caliper
2) coil number/spacing - match them up visually
3) coil ends - the beginning and end of the coil wire. match them by where the two ends line up. look down them axially, and you should see this.
the above criteria was enough to match up 9 pairs of springs that were all painted white, and then mixed up. that will match them up, and at 3lb intervals, you should then be able to determine the order they go.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-01-2006, 11:07 AM   #8343
Korey Harbke's Avatar
Originally Posted by seaball
will,
Yup thats how I would do it. It's a little bit easier for the corally springs though. There are only 2 wire sizes.... the black ones are a little thinner, and the silver ones are a touch thicker. The more coils in the spring itself... the softer the spring is, fewer coils makes the spring stiffer. Counting them... just start where the wire starts and go around in 360 rotations. at the endyou might have 1/4, 1/2, or 3/4 of a rotation left. Just make those accordingly and look on the original package the spring came in. It tells you what number of coils corresponds to the spring.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-01-2006, 12:31 PM   #8344
Thanks for your help guys ill get onto it late,
Would be nice if Corally coloured them
WiilLz
Old 08-01-2006, 01:55 PM   #8345
tbeardmore's Avatar
WiilLz
You might try coloring them yourself after you get them sorted correctly with fingernail polish.
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 08-01-2006, 02:09 PM   #8346
Yea I know... it's to hide secret squirell setups . You get used to them after a while. I remember one time I had a 14.5 and a 12.5 mixed up. So I had 14.5 on the front right and rear left corners of the car, and a 12.5 on the other 2 LOL.
-Korey
Old 08-01-2006, 03:37 PM   #8347
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Nice one Harbuckle..you secret squirrel you. I remember w/ the silver springs I used different colored sharpies and colored the top coil or two. That was on the old set I had.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-01-2006, 04:33 PM   #8348
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
You can also put two springs end to end and compress them against each other. The softer spring will compress fully first. Be careful though...they will shoot out across the room if you dont get it right
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-01-2006, 04:40 PM   #8349
rc_bam226's Avatar
You can take an eye out that way!!!
rc_bam226 is offline   Reply With Quote
Old 08-01-2006, 04:44 PM   #8350
EA
That's how it's done in the south, EA?
USVTA Member #211
Old 08-01-2006, 05:46 PM   #8351
Drcy's Avatar
Default Non Aluminium Spool fot the RDX
Does somebody knows where to get a spool for the rdx that is not made by Corally?
tx
Pedro
Drcy is offline   Reply With Quote
Old 08-01-2006, 06:05 PM   #8352
Trader Rating: 18 (100%+)
tx
Pedro
http://www.corallyusa.com/specializedrc/rdx.htm
Scroll to bottom of page.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-01-2006, 06:25 PM   #8353
Trader Rating: 47 (100%+)
there was a guy on ebay selling an all plastic one
josh short is offline   Reply With Quote
Old 08-01-2006, 06:41 PM   #8354
Sedan's Avatar
Send a message via AIM to Sedan
Thanks to L.Fairtrace for helpin me out with my spool question. Next, I wanted to ask about the shocks. Seems like the rear shocks are almost hitting the shock tower on top when I have then on the inner mount locations. I even put a small spacer in there to move it away a bit. is this normal??
Maybe someone could post a nice close up of their shock set up.... or is that too secret?
Thanks for the help!
Sedan is offline   Reply With Quote
Old 08-01-2006, 06:43 PM   #8355
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I dont think you'll ever be in a situation where you want to use the inner most hole on the shocktower. Most setups the outer 2 holes are used.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
