Old 07-29-2006, 05:43 PM   #8326
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
EricO3 is offline   Reply With Quote
Old 07-29-2006, 07:56 PM   #8327
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Does anyone know if the corally twisted battery connectors are compatible with the orion ones?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 07-30-2006, 08:04 AM   #8328
Have anyone use a different shock ball end other than the Corally type? my LHS don't have it.
Mutabarucka is offline   Reply With Quote
Old 07-30-2006, 10:26 AM   #8329
Trader Rating: 38 (100%+)
I broke a diff screw yesterday. Any tips on getting the broken screw out of the side of the diff without the head on it?
or8ital is offline   Reply With Quote
Old 07-30-2006, 10:31 AM   #8330
tel
I broke the diff screw a few months ago. Dremel disks do not have a large enough diameter to reach the screw. Get a very thin hand metal saw and cut a slot into the plastic nut and screw from the outside of the diff half. Then you should be able to turn the screw out with a very small flat screwdriver.
Travis Lewis
Team Kyosho, Team Orion, Avid RC, JTP RC
tel is offline   Reply With Quote
Old 07-30-2006, 12:54 PM   #8331
drew85's Avatar
Have you guys ever had a problem with the droop screws rubbing holes in the chassie? There not that bad but looks like it could get worse? I have only run the car 1 night.
drew85 is offline   Reply With Quote
Old 07-30-2006, 12:58 PM   #8332
OllieRDX's Avatar
Send a message via MSN to OllieRDX
Hi Drew,
yeah thats normal if you knwo what a force there is in those droop screws in the chassis you should understand! Bit it wouldn't get worse, till it get worse your chassis is already F* up and tweaked!
Greetings Ollie
| Team Corally | GM Racing | SpeedTech RC Germany | Toni Sport | MobGums | XXX Racing Shop | Black Art | Futaba | Loomans Distribution |
OllieRDX is offline   Reply With Quote
Old 07-30-2006, 01:24 PM   #8333
There's two thing you could do first most Hobby Shop sell thin strip of copper you can place under the droop screws and next you can drill a bigger hole like the one XRay use you might not have enough space to do the bigger hole but you can give it a try hope this help.
Old 07-30-2006, 01:27 PM   #8334
There was some talk about that a few pages back if you search you will find some information.
Old 07-30-2006, 01:57 PM   #8335
I looked and all I found was someone saying you had to buy the whole half new again.
Which is the new reinforced diff screw - the one threaded all the way or the one that isnt? I think thats the diff but wasnt sure which was the stronger one.
Old 07-30-2006, 02:03 PM   #8336
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
the diff screw that is not threaded all the way up is the newer stronger diff screw.
wallstreet is offline   Reply With Quote
Old 07-30-2006, 02:04 PM   #8337
syndr0me's Avatar
Trader Rating: 32 (100%+)
The screw without the threads at the top is the new, stronger one.
syndr0me is offline   Reply With Quote
Old 07-30-2006, 02:08 PM   #8338
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Some have had success using a hair dryer or heat gun to heat up the diff half which expands the aluminum allowing the plastic to be removed easier. It has been said Corally USA will hook you up with just the plastic nut, as well as some LHS's so you don't have to buy the entire diff half.
Old 07-30-2006, 05:10 PM   #8339
Sedan's Avatar
Send a message via AIM to Sedan
Spool / Blade Question
I searched this and other threads for something similar to my problem, but got nothing specific. Hope you guys can help out.
I installed a spool tonight, but the metal blades seem like they are WAY too tight when putting them in the spool. Once together the front end bounces up and down because the the blades are so tight they keep the bones from moving freely.
Any idea whats up with this? I can post a pic or video if anyone needs!
Sedan is offline   Reply With Quote
Old 07-30-2006, 05:13 PM   #8340
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I had the same problem, I just got a file and took a little off the spool. It worked like a charm.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
