Old 07-13-2006, 09:47 AM   #8116
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
hey andrew... for the oneway, you will need the different bearing holders, plus a larger bearing, but i forget the size.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-13-2006, 09:49 AM   #8117
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Got it. Thanks Wes.
Old 07-13-2006, 09:51 AM   #8118
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
I believe they're 12x18x4.
EricO3 is offline   Reply With Quote
Old 07-13-2006, 10:26 AM   #8119
Thanks guys, just ordered it all. Should be tearing up the carpet with rubber in around 2 days. At major races are the rubber lap times about .1 to .5 secs off the foam times?
EDIT: Just checked last years IIC results (had to use the best lap in the B main as I couldn't find the A main results) and the rubber times in 19t and stock were about 1 sec off.
Old 07-13-2006, 10:45 AM   #8120
belgianchamp's Avatar
Send a message via MSN to belgianchamp
Hello Guys,
Do u guys have the problem when running spool that the front drive axels are doing BRBRBRRRRRR when taking a corner? (thats really shit) some people say use 3 c-hubs will help instead of 2(standard) and turn in steering on your transmitter...what are u guys doing?Ow every part on my car is perfect smooth,drive axels are flat,bearings are new... please help me
belgianchamp is offline   Reply With Quote
Old 07-13-2006, 10:53 AM   #8121
Check that your wheels aren't hitting your lower shock collars when your radio turns full lock and that your wheels aren't scraping the edge of your steering knuckles. It may be just close enough that when theres no load (straight) it doesn't rub, but when you place a lateral load on it (turning) the wheel flexes and rubs. Although it sounds like you're running rubber asphalt and this stuff usually only happens on foams . . .hmmmmm
Old 07-13-2006, 11:06 AM   #8122
Hello,
Yes i'm running asphalt rubber with spool...nothing is hitting the steering knuckles or the schock collars the BRRRRRRRR sound comes straight of the coupling of my front drive axles(inside my alu-steering knuckles)BTW thx 4 helping... some factory Corally guys sayed that they have it also so i dont have to worry about!
Old 07-13-2006, 11:11 AM   #8123
Anytime . . .I am Grandma sitting at my parents and there's nothing to do but surf the web. So sad . . .
Glad to hear others have the same problem . . .It's not the CVD pin working its way out of the cvd and scraping the inside of the knuckle, is it?
Old 07-13-2006, 11:26 AM   #8124
OllieRDX's Avatar
Send a message via MSN to OllieRDX
With spool your drivetrain get it very hard! The tension of your drivetrtain is just extreme and thats way your car make such a sound because you are getting that hard tension! you have to make your car agressive and set some lower steering then you don't have that extreme tension!
Greetings Ollie
| Team Corally | GM Racing | SpeedTech RC Germany | Toni Sport | MobGums | XXX Racing Shop | Black Art | Futaba | Loomans Distribution |
OllieRDX is offline   Reply With Quote
Old 07-13-2006, 12:43 PM   #8125
syndr0me's Avatar
Trader Rating: 32 (100%+)
From what I understand, the noise you're hearing with the spool has something to do with the interaction between the spool and the CVD's. I saw Adrian explain it really well once. Either way, I'm pretty sure it happens on nearly all cars that use CVD's and spools.
syndr0me is offline   Reply With Quote
Old 07-13-2006, 04:29 PM   #8126
Drcy's Avatar
Unhappy Corally Shocks
Originally Posted by Sushi Boy
I was actually just dealing with the whole leaky shock thing today.... the shock bladder would slip off and break the seal. I noticed there was shock oil on the cap, the plastic part at least. If that isnt dry then when it crimps down on the bladder it slips off and breaks the seal. I just cleaned it up really well and it went away. The cap/bladder assembly for the corally shock jyust has to be really clean and dry and everything will work. If you have any doubts just replace the pastic cap part and the bladder and everything goes together well again.
-Korey
Hi ,
I came to the same conclusion as Korey, What I am still looking for is to how I manage to get my shocks with almost no rebound???
I tried several times but when I screw the sock cap the piston goes down and I get more rebound than I want.
All the other attempts resulted in the blader getting out of the place (being sucke into the shock)
Does somebody know how to ajust the shocks with no rebound??
tx
Pedro
Drcy is offline   Reply With Quote
Old 07-13-2006, 05:16 PM   #8127
When I build my shocks, i put the blatter on the end of my exacto and push the blatter in just a extra bit to get a bit more oil out...then i screw the cap on. This has given me the "deadest" shock, maybe a mm or two of rebound, thats it...hope this helps
DH
Dhartman03 is offline   Reply With Quote
Old 07-13-2006, 05:18 PM   #8128
Make sure when you screw the cap on not to turn the eyelet, just turn the metal cap, that will make sure the blatter doesn't move and there is a secure seal.
Old 07-13-2006, 06:33 PM   #8129
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Originally Posted by Drcy
Hi ,
tx
Pedro
To get a dead shock I simply build it like normal, and once it is together if there is rebound I loosen the cap just enough to let a tiny amount of oil out and I push the shock shaft up to release any extra oil/pressure. Tighten the cap down and check for rebound and repeat the process until it is dead. My shocks always turn out pretty good and dead this way with no leaks.
TeamPink91 is offline   Reply With Quote
Old 07-13-2006, 09:11 PM   #8130
Jeff Brown's Avatar
Ditto.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
