Old 07-12-2006, 07:17 PM   #8101
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Ive never had a leak in my shocks. They go together just perfect. Only thing I could ask is for an externally adjustable piston option for testing
Old 07-12-2006, 07:39 PM   #8102
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
I wouldn't go so far as to call it a flaw when you only know of 2 people and yourself having this problem...
EricO3 is offline   Reply With Quote
Old 07-12-2006, 07:48 PM   #8103
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Originally Posted by or8ital
Top.
Are you sure you're not pinching the bladder when you screw the cap on?
TeamPink91 is offline   Reply With Quote
Old 07-12-2006, 07:57 PM   #8104
Big Rigg's Avatar
or try to put an insert in above the bladder, lots of people use the tamiya pink foam dealios, but I like the Yok ones because they're a bit wider (and I already have them... )
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 07-12-2006, 07:59 PM   #8105
Trader Rating: 38 (100%+)
I dont think Im pinching the bladder. they seem pretty flush all the way around and tight. Havent tried any rebound foam.
or8ital is offline   Reply With Quote
Old 07-12-2006, 10:00 PM   #8106
Is there a general concensus about a rubber tire of carpet set up? I am assuming one of these should get me pretty close.
http://www.corallyusa.com/2005/setup.htm
Is this the only 1 way available for the rdx ?
http://www.corallyusa.com/istar.asp?a=6&id=COR79167!COR
Old 07-12-2006, 10:40 PM   #8107
Jeff Brown's Avatar
Originally Posted by Sushi Boy
Kinda.... most of the team just rounds up... so a .8mm shim is a 1mm shim, and a .4 mm shim is a .5mm shim. It just makes things easier for us when we are communicating setups at the races.
Exactly.
The reason for this is because .8mm is 1 deg of toe and not 1mm, and .4mm is 1/2 deg of toe. They did it to keep it simple.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 07-12-2006, 10:43 PM   #8108
Jeff Brown's Avatar
Originally Posted by T1Raycer
hey jeff brown i want to know when the new bacth of arm will be ship to some hobby shop !! i went to my local hobby shop and he said it was backortder like a month ago!!! so im confused here??
Later!!
Well, the arms are in short supply due to molding complications. The material did not shrink properly and caused the 5,000 or so pieces of 35 arms to have too small of hinge pin holes. Reaming them just would not be accurate enough so they did not release them to the masses. Instead they have been fixing the problem and should be available shortly.
We will also send you some when you change the spelling to "Corally" in your signature.
Jeff
Old 07-12-2006, 10:46 PM   #8109
Jeff Brown's Avatar
Yes, those setups will get you close.
Yes, that is the only one-way for the RDX.
Jeff
Old 07-12-2006, 10:48 PM   #8110
Jeff Brown's Avatar
Worst case replace the bladders. If you sprayed them with motor spray I would definately recommend replacing them. The motor spray seems to attack them and make them swell.
Swollen bladders are not good. See a doctor.
Jeff
Old 07-12-2006, 11:02 PM   #8111
CHRIS CHAVEZ's Avatar
Top.
I had the same problem as you and I know how annoying it can be.
The Corally shocks are fine. Although, I'm not the biggest fan of their bladders. After testing multiple shock oil weights in a day, I noticed the bladders became very swollen and difficult to re-install. I also found if the bladders became too swollen then the cap would not re-seat properly and cause a leak. Furthermore, After replacing the swollen bladders with some fresh new ones i figured my problems would have been cured. Unfortunatly they were not. It seemed that the new bladders were very slighty too small and would not seat properly and also cause a leak.
I know there's other people that have not had these problems, so "maybe" I just got a bad batch. Finally, I followed Barnacle's advise to try out the tamiya TRF bladders and I no longer have any leaks.
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 07-12-2006, 11:15 PM   #8112
Anyone have a oneway they wouldn't mind selling?
Old 07-12-2006, 11:46 PM   #8113
latest in the lipo use project.
6 of these glued to an Orion Lipo that has shrink wrap around it. 20 g apiece for a total of 120 grams possible. Can't wait to try it out.
Old 07-13-2006, 12:44 AM   #8114
Korey Harbke's Avatar
I was actually just dealing with the whole leaky shock thing today.... the shock bladder would slip off and break the seal. I noticed there was shock oil on the cap, the plastic part at least. If that isnt dry then when it crimps down on the bladder it slips off and breaks the seal. I just cleaned it up really well and it went away. The cap/bladder assembly for the corally shock jyust has to be really clean and dry and everything will work. If you have any doubts just replace the pastic cap part and the bladder and everything goes together well again.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-13-2006, 09:26 AM   #8115
Jeff
Thanks Jeff. Are there any other parts necessary to adapt the one way? Right now I am running a foam carpet spec car and am wanting to try my hand at rubber carpet. THX
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
