Old 07-08-2006, 10:48 PM   #8026
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by or8ital
Im having a problem with my pre-mounted Take-Off tires. The rims are so thick they touch the A-Arm when I turn all the way to one side (causing me to spin out often). Anyone know a simple solution for that? Other rims work fine. Its just the new rims Take-Off is using.
I do have a shim between the hex nut and the tire and I am using Pro4 hex nuts (but I dont think that should make a diff).
I had exactly the same problem. I bought unmounted CS27's and mounted them on SpeedMind wheels and everything was fine. I bet you could mount them on Corally wheels and be fine as well. It's not an issue with EPA, the inside of the arm rubs on the inside of the wheel with very little steering throw.
syndr0me is offline   Reply With Quote
Old 07-08-2006, 11:01 PM   #8027
syndr0me's Avatar
I'm not sure if Corally International reads this thread or not, so maybe one of you guys that talk to them can pass this along if you think it's worthy.
I believe the front bulkheads might be unnecessarily weak. Our track (pictured here) has two sides that are walls, and extremely unforgiving. It's rare that I hit a wall, but we had a layout recently that had a particularly tight section that would bounce you into the wall (with the side of your car) if you cut it too tight.
I managed to bend two front bulkheads over the course of 3 months, and I've bent others in the past. The odd thing is, the impacts that bend them have never broken an arm or hingepin, which you'd expect to be more fragile.
Normally, a slight bend might be okay since you could put in a shim or something and just live with it. Unfortunately, with the RDX, a slight bend stretches out the screw holes, so nothing will thread into the bulkhead anymore, and it's nearly impossible to get the bearing holders back in once you take them out.
I've gotten a lot better at driving in the last year, and I have plenty of races where I don't touch a board or the wall, and actually rarely break anything these days. I'm not a hack or a reckless driver or anything, for what it's worth.
So, since the spirit of the RDX is to improve rather than reinvent, I thought I'd pass this along. If anybody else has experienced similar trouble, I'd be interested to hear about it to see if maybe I really am just a hack. :-) Thanks for reading.
Old 07-08-2006, 11:03 PM   #8028
syndr0me's Avatar
Also, since using the SRC Ultimate Bumper and switching to Parma tires, I haven't broken a single arm. I think there is REALLY something to the theory about wheel nuts catching on the boards and breaking an arm. The Parmas do a nice job of protecting the nut.
Old 07-08-2006, 11:27 PM   #8029
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Any tricks to removing bearings from the hubs? Mine are stuck and the ole "shove something through one bearing to push the other out" is proving useless.
Old 07-09-2006, 12:42 AM   #8030
syndr0me's Avatar
I switched from Cuffs' IIC setup to Dayger's Novak setup when I rebuilt the foam tire car, and I've really been liking the change. Both setups felt awesome, but to me, Dayger's setup seems a little bit less aggressive, and easier to drive smooth.
Old 07-09-2006, 07:42 AM   #8031
Trader Rating: 38 (100%+)
Originally Posted by Brian L
Take a dremel and grind a little bit off the edge of the arm.
I did that but apparently I didnt take enough off. I was hesitant to take too much off b/c the part I would dremel off seems to be the weakest part of the arm and always breaks.
Im definately going to get some new rims for my club race. Was just wondering though since I know those pre-mounted Take-Offs are popular handout tires.
I wish Take-Off hadnt stopped using the Speedmind rims.
or8ital is offline   Reply With Quote
Old 07-09-2006, 08:43 AM   #8032
HarshGuy's Avatar
OK, I'm having a strange problem that I can't figure out (others have looked over the car as well ...2nd set of eyes kind of thing) ...got my car working great ...but I keep poping the belt off the spool, I've tried no belt tensionser, belt tensioner, new belt, everything I can think of ...nothing is binding up and the spool has the sides intact, but it keeps happening ...in 2 qualifiers and the mains last night ....anyone else ever experience this? And if so, what was causing it?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-09-2006, 08:53 AM   #8033
Jimmy Morris's Avatar
It happened to me but only when I had the belt really loose. Is your spool installed correctly? It might be flipped 180 degrees.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 07-09-2006, 08:56 AM   #8034
May sound obvious but check to make sure you haven't switched where your belts go on the center drive pullies. This will force them to ride on an angle which would cause the belts to pop-off.
duckman996 is offline   Reply With Quote
Old 07-09-2006, 10:52 AM   #8035
You can also install the rear diff the wrong way, that will pop off, Don't ask how I know.
Cheers
Peter
Pedro 51 is offline   Reply With Quote
Old 07-09-2006, 11:14 AM   #8036
HarshGuy's Avatar
Well I just looked her over and everything *appears* installed correctly ...here are some pics ...for a second (third, fourth, fifth ...hundreth LOL) set of eyes to see if I'm missing anything
Team Corally RDX Touring Car-corallyclosed.jpg   Team Corally RDX Touring Car-corallyfront.jpg   Team Corally RDX Touring Car-corallyrear.jpg   Team Corally RDX Touring Car-corallyopen.jpg
Old 07-09-2006, 11:42 AM   #8037
syndr0me's Avatar
There's a lot more RDX porn from the worlds at this link:
http://www.petitrc.com/view_news.php?id=5796
Old 07-09-2006, 11:45 AM   #8038
syndr0me's Avatar
Harsh,
Is there anything at all that's binding up your front axle? Are you tapping boards or anything when the belt slips? Seems like with a solid front axle, any stoppage of the drive train, even momentarily can make the belt jump.
Old 07-09-2006, 03:24 PM   #8039
Drcy's Avatar
Thumbs up Fragile Bulkheads
Hi,
I had the same problems.
Now , since it is outdoor season, the impacts ar very slow but, still strong enough to "unround" the place whre the ftont nearings are secured.
I place two brand new bearings and after squeeze them in the plastic holders, they fell greety, like dirt old bearings.
Does somebody know how to solve this problem?
cheers
Pedro
Drcy is offline   Reply With Quote
Old 07-09-2006, 03:30 PM   #8040
Drcy's Avatar
Thumbs up Tamiya Shocks
Hi,
I saw some pics from your car and perhaps you can tell which parts I will need to buy to be able to use the Tamiya shocks.
thanks
Pedro
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
