Old 07-03-2006, 09:31 PM   #7981
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
standard diff balls
I usually sand the rings but didn't on this car, guess I should have.
Thanks Bill your always helpful.
Ceramics are in the future, just not soon enough though.
Dayton
1armed1 is offline   Reply With Quote
Old 07-03-2006, 09:48 PM   #7982
Still Bill's Avatar
Default Diffs
No problem Armed. No racing for me this past weekend; so, I am going through my asphalt car now. Finally added the ceramic thrust bearings and my diffs are killer...Now!
One other thing that I seen on Aaron Young's RDX diffs are stick-on rings (donuts) of contact paper that help keep the dirt out of the diffs. Very cool move; but, I expect that of Aaron. Every tip AY gives me is pure gold.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-04-2006, 11:23 AM   #7983
Hey guys. The RDX Tweak Plate is under development. Got some cool ideas for this one.
Art Jensen is offline   Reply With Quote
Old 07-04-2006, 12:54 PM   #7984
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Does tweak plate mean multi flex?
Old 07-04-2006, 01:26 PM   #7985
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
i still half to give props to corally the rdx is the most effiecient car to buy in my eyes. I bought the rdx carpet spec only ran it 3 times but still its very stable great take off good high speed handle. The only problem i have is that i only run oval carpet so it was a little harder to make it like the left hand turns with the batt on the right side but i got it taken care of with puting 50wt shock oil in the car after that it was a little camber change and this thing was a rocket. Great job guys keep it up... Now im lookin for a car for asphault might be another rdx on the way..
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 07-05-2006, 02:41 PM   #7986
tim fry's Avatar
Hi all
Can someone please remind me of the part number of the HPI/Hotbodies body posts to use please?
tim fry is offline   Reply With Quote
Old 07-05-2006, 02:55 PM   #7987
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I use the T2 body posts and they work awesome. Give them a try.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-05-2006, 03:04 PM   #7988
Trader Rating: 38 (100%+)
Originally Posted by tim fry
Hi all
http://rctech.net/forum/showthread.p...pi#post2260525
The search function is on the top right
or8ital is offline   Reply With Quote
Old 07-05-2006, 03:21 PM   #7989
Trader Rating: 22 (100%+)
Default Why would I chose an RDX over a Hot Bodies Hara/Surikarn edition
what makes the RDX so good?
I am looking for a new car why would I choose a rdx.
What are its strengths and weaknesses as I run on ashphalt what would I need that is not in the standard kit.
Thanks in advance for any opinnions.
bjspinner is offline   Reply With Quote
Old 07-05-2006, 03:41 PM   #7990
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default One way question
Is there another , other than stock one one that fits the car? If not , where can I get a reasonably priced one way for it? Thanks..............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-05-2006, 09:24 PM   #7991
what makes the rdx so good.... the quality of the car its percision... i mean dont get me wrong i was not happy with mine till the last time i took it out... i was super pissed because the car felt to good through the corners and that usually means your tight and not tight pushing just tight and slow. i finally figured out y and got it to fly.
Now i got a question for the rdx kings in hear. i need to know what i need to change on the carpet spec to make this thing a front runner in asphault or do i need to buy a new rdx just for that?
also i have 200 bucks im going to spend for parts on my rdx what all should i get...
im thinkin a full shock kit. and some arms but what else
yokomo yz-2
Old 07-06-2006, 06:30 AM   #7992
Looking for some help . . .
My local track has slowed this summer so traction is not like it used to be during the "season" Typical lap times earlier this year when traction was higher were in the low 13's/high 12's. The track now leaves my car pretty dusty after a run and there is an obvious reduction in traction. Last week's race I was able to get my lap times down to around 14.4 seconds. I went back up to practice today and mess with some changes. Due to the loss of traction I have been unable to get the on power steering I would like. So just for grins I decided to sauce all the way across each front tire. Viola! My lap times dropped instantly to 14.0 until the sauce wears off and I start having to lift throttle to get the car to turn in. Any suggestions to gain more steering without saucing the whole fronts? I have my steering turned to 100% already and have set my epa's to take advantage of all the steering travel I can with out hitting the lower shock collars.
Old 07-06-2006, 08:04 AM   #7993
alb
Trader Rating: 19 (100%+)
anyone notice Kaerup's RDX? No bellcrank, single steering arm, servo facing in, straping tape.............................................. .
alb is offline   Reply With Quote
Old 07-06-2006, 08:21 AM   #7994
Yeah. I notice that too. And he use Associated springs and new Corally delrin spool. New chassis and upperdeck also.
How he made that servo turnaround thing?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 07-06-2006, 08:28 AM   #7995
where is this pic??
josh short is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
