Old 06-29-2006, 03:20 PM   #7966
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Shuold probably pick up a differential for the front.
EricO3 is offline   Reply With Quote
Old 06-29-2006, 04:52 PM   #7967
T1Raycer's Avatar
low roll block and the silver spring if you dont have them
T1Raycer is offline   Reply With Quote
Old 06-29-2006, 07:39 PM   #7968
Big Rigg's Avatar
All that's groovy for foam... for rubber just rock it!
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 06-29-2006, 11:32 PM   #7969
CHRIS CHAVEZ's Avatar
Default OFF SET MOTOR MOUNT
I'm looking for the new offset motor mount.
I tried my local shop Speed tech and they were out of stock.
I tried Corally in Florida and they are on back order.
Although, they did give me a few of there biggest dealer numbers to see if they had one sitting on the shelf but they were all out of stock as well.
Does anybody know where i might be able to find this bad boy?
Thanks, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 06-30-2006, 01:21 AM   #7970
Default V ONE RRR WORLDS FOR SALE
V ONE RRR WORLDS EDITION WITH RB X12 AND PIPE WITH FUTABA 3PK RADIO AND S9550 STEERING AND BRAKE SERVOS STARTER BOX AND BATTERY QUICK SALE PREFERED OFERS OVER $650 CONSIDERED YOU PAY FOR SHIPPING PHOTOS AVAIBLE BY EMAIL ONLY MY EMAIL IS [email protected]
mikey23 is offline   Reply With Quote
Old 06-30-2006, 01:59 AM   #7971
rc_bam226's Avatar
uhhhh, wrong forum man.
rc_bam226 is offline   Reply With Quote
Old 06-30-2006, 03:31 AM   #7972
Bear I was going to rely on you for some good infomation? I was told however for using the asphalt car would be okay. I did get a spring set . So if you need to use the springs I'm not your welcome to use them.I'll try to call later at work or you can call me.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-01-2006, 08:56 AM   #7973
Still Bill's Avatar
Corally International website down!?!
But CorallyUSA works.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-01-2006, 11:55 AM   #7974
syndr0me's Avatar
Trader Rating: 32 (100%+)
Uh oh, someone didn't pay their hosting bill.
syndr0me is offline   Reply With Quote
Old 07-01-2006, 11:59 AM   #7975
Still Bill's Avatar
Probably all off at the Worlds.
Old 07-03-2006, 08:14 AM   #7976
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I'm having a problem with the diffs in my rdx.
If they are set to get a nice diff action they are to loose. If I set them so they don't slip the diff action is pretty tight. They are smooth with either setting, not notchy but slips.
Any help???
Dayton
1armed1 is offline   Reply With Quote
Old 07-03-2006, 11:40 AM   #7977
Originally Posted by T1Raycer
for asphalt i would go whit softer spring like 17 front 14.5 rear !! jeff brown has a good starting setup on corallyusa.com you can start whit that and chnage litlte thing to make your rdx dialed on your track cause every track is different!! and the droop try 2mm front and 3mm rear tell me if it work !!!
Later!!
TiRaycer,
I did the damn thing this weekend and the car was much better, now my transition from left to right is slower i wanted to standup the shock but didn't have the time to do so i will try it next week.
Mutabarucka is offline   Reply With Quote
Old 07-03-2006, 04:51 PM   #7978
Trader Rating: 46 (100%+)
dayton
rebuild the diffs with NEW everything
josh short is offline   Reply With Quote
Old 07-03-2006, 07:20 PM   #7979
1armed1's Avatar
Josh,
The rear I did, the front still looked decent so I just flipped the rings.
I'll order all new and try it again.
Old 07-03-2006, 09:23 PM   #7980
Still Bill's Avatar
Any help???
Dayton
What diff balls are you using? Go with ceramic for the best performance. Same applies to the thrust bearings.
After running 1/12th scale for awhile, I learned to sand my diff rings with 600 grit sand paper on a flat surface. Gives the diff balls more grip to the rings. No mirror-like diff rings for me. Makes a noticeable difference.
Also check the cleanliness/condition of the thrust bearings too.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
