Team Corally RDX Touring Car >
Old 06-10-2006, 02:06 PM
  #7786
RichO's Avatar
Looks like Jeff Brown is doing really well with the car in Calif. this weekend at the nationals. Anyone know what he has done to the setup for the weekend?
Quick question about shocks:
Are people using the factory ones or switching to Tamiya?
RichO is offline
Old 06-10-2006, 02:51 PM
  #7787
Merciless's Avatar
Think most people stick with factory ones although alot are using Tamiya 3hole pistons in them They need alittle shimming to space them on the shaft but are a perfect diameter inside
Merciless is offline
Old 06-10-2006, 09:56 PM
  #7788
At the Reedy Race we were using Tamiya 3 hole pistons and taking out bottom o-ring and replacing with a .090 plastic spacer to fill gap. Makes the shock smoother.
barnacle is offline
Old 06-10-2006, 11:03 PM
  #7789
syndr0me's Avatar
Trader Rating: 32 (100%+)
Have you guys ever had trouble with inconsistent rear toe on the car? I've got a single 1 degree spacer in the rear of the car on each side (for 1 degree of rear toe) but one of the sides is showing 2 degrees on the setup station. The chassis is brand new, and I checked the bulkheads on a flat surface and can't detect any kind of bend or anything. The rear uprights are both 0 degrees (at least there's no stamp on them) so I don't think I'm running outboard toe by accident. I'm perplexed though. Is it possible one of the uprights is drilled wrong? I suppose I could measure the holes in the chassis, and possibly swap things around to see if the problem follows a particular part.
This is a car I bought used so I didn't have to touch my foam car while our track insists on us running these ridiculous rubber tires for the summer. I really think this car is haunted, it's been nothing but trouble. Maybe that's why it was for sale. :-( I might just convert the foam car to rubber so at least I know what I'm working with. I'm about ready to melt this rubber car down for spare parts. Piece of crap.
syndr0me is offline
Old 06-11-2006, 01:36 AM
  #7790
Ollie RDX's Avatar
Thats shit man may be the rear upright has been bend or your setup systems is bend! But the car can have tweak so if your car is tweaked nothing is right you know! screw the topdeck a bit lose and ask some friend if he can push the chassis againts something flat and then screw your topdeck good!
Greetings Ollie
Ollie RDX is offline
Old 06-11-2006, 05:08 AM
  #7791
Fervidsea's Avatar
Just losen your bulkheads from the chasiss and losen your arms as well. Retighten then, like a torque pattern so to say, and that should take car of it. I was pulling my hair out about a month ago over the same thing.
Fervidsea is offline
Old 06-11-2006, 05:52 AM
  #7792
Could it be the result of slop in suspension. Check and shim the car.
barnacle is offline
Old 06-11-2006, 08:51 PM
  #7793
rayhuang's Avatar
Congrats to Jeff Brown on a Great Nationals!!
rayhuang is offline
Old 06-12-2006, 08:28 AM
  #7794
syndr0me's Avatar
I noticed on his carpet nats setup that Tosolini used the 2.4mm topdeck with the 3.9mm chassis. Everything I've learned about carpet setups seems to indicate that you want to make the car as stiff as possible, especially when the traction comes up, like at a big race. What would be the advantage (or reason) for putting the thin topdeck on in a situation like that?
Or, was that just a typo?
syndr0me is offline
Old 06-12-2006, 09:31 AM
  #7795
Ollie RDX's Avatar
The 3.9mm chassis is for direct steer and allot of steer and the 2.4mm topdeck is for the back to be stabile!
On rubber you have to do the other thats 2.4mm chassi and 2.9 topdeck thats for rubber on Carpet!
Old 06-12-2006, 09:53 AM
  #7796
Jimmy Morris's Avatar
Yeah, way to go Jeff, as well as Mike bruce, Shad and TJ.
Jimmy Morris is offline
Old 06-12-2006, 10:08 AM
  #7797
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
We need Jeffs Setup asap.
L.Fairtrace is offline
Old 06-12-2006, 10:16 AM
  #7798
syndr0me's Avatar
Yea, but that was a foam tire race. It kind of goes against conventional setup wisdom to combine the stiffest car possible with a thin topdeck when you're running on foam. That's why I'm wondering if it was a typo.
syndr0me is offline
Old 06-12-2006, 12:12 PM
  #7799
Brian McGreevy's Avatar
He did use the 2.4 topdeck. That topdeck gave the car a little more steering at the sacrifice of a tiny bit of corner speed. In mod you need the car to turn hard, and also carry speed, but not like stock where roll speed is the name of the game.
Brian McGreevy is offline
Old 06-12-2006, 12:13 PM
  #7800
Korey Harbke's Avatar
It wasnt a typo. Carpet nats had some weird bumps in the track.... I'm not exactly sure why Robbie and Toso setteled on the 2.4mm upper deck... but it was probably only because it was faster for the conditions at Carpet nats.
-Korey
Korey Harbke is offline
