Old 06-03-2006, 03:17 AM   #7726
Ollie RDX's Avatar
Send a message via MSN to Ollie RDX
Originally Posted by tim fry
I've emailed Corally to ask them so we'll see what they say.
On another note I've fitted the bigger bumper but it seems its going to make it difficult to fit a Mazda 6 shell. Should I cut the bumper down? It seems silly to get a bigger bumper then chop bits off
Yeah you got to make the foam bumper a bit smaller!
Greetings Ollie
Ollie RDX is offline   Reply With Quote
Old 06-03-2006, 05:49 AM   #7727
stiltskin's Avatar
Trader Rating: 102 (100%+)
The better the bumper fits inside the front of the body, the less likely you are to crack or tear the body. I'd rather cut some off than have to glue extra pieces to the front of a "small" bumper. I got the large bumper by mistake and it worked great.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-04-2006, 02:15 AM   #7728
syndr0me's Avatar
Trader Rating: 32 (100%+)
With CS27's on the car, if you turn the wheels far enough, the inside of the wheel clears the leading front edge of the suspension arm and starts to rub. Should I set my EPA so the wheels don't turn that far, dremel out the inside of the wheels, or something different entirely? It's not a lot of rub, but it's enough to make some noise if the wheels are turned and the car is moving.
With foam tires, the internal diameter of the wheel seems to be larger, so there's no rubbing.
syndr0me is offline   Reply With Quote
Old 06-04-2006, 02:45 AM   #7729
Ollie RDX's Avatar
Thats Because you set to Much steer on your car if you turn the Steering block may not touch the C-Hub Really Close But not Touch it!
greetings Ollie
Old 06-04-2006, 02:38 PM   #7730
hi everybody im new to the corally rdx and i was wondering
with my car the electrics and all the wieght is in the car it needs but at the front there is still 5mm ride hirght without me twisting the shock collar
could someon help me on this as i race on carpet and use about 3.5 or 4mm ride hieght
jordan
jordy is offline   Reply With Quote
Old 06-04-2006, 03:55 PM   #7731
Jimmy Morris's Avatar
Xray spring perches=fast and easy fix. What hole are your shocks in on the tower and the arm?
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 06-04-2006, 04:03 PM   #7732
Korey Harbke's Avatar
Try some different spring perches on the front shocks for a quick fix. The Xray or Associated ones work pretty well. You can also try just cutting the top of the actual shock end and trimming the spring perch bottom a little bit and that will also let the spring sit a tiny bit lower.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-04-2006, 04:35 PM   #7733
Merciless's Avatar
Send a message via ICQ to Merciless
I've found the take-off rims to be just too small a diameter , so you have to either mount the 27's your self on a slightly larger rim or use a wheel spacer to move the wheel alittle further out.
Either way works, but i've just moved over to Sorex pre-mounted tyres and all's sweet I
f your looking for something comparable to the cs27 i'd recomend the Sorex 32's
Merciless is offline   Reply With Quote
Old 06-04-2006, 04:42 PM   #7734
You really shouldn't need to run that much dual rate to where the rim rubs on stuff. Try turning it down some.
Old 06-04-2006, 05:17 PM   #7735
Trader Rating: 38 (100%+)
Default Keep Diff Clean?
Any recommendations on how to keep the diffs clean when running outdoors on a somewhat dirty track? My diffs seem to really attract the dirt.
or8ital is offline   Reply With Quote
Old 06-04-2006, 05:22 PM   #7736
Wipe any excess diff lube off the pulley after you build the diff, and after a run cause some might get slung up. Corally makes sealed diffs as well. That is probably your best bet. It happens to everyone really, it's just the nature of the beast.
Old 06-04-2006, 05:30 PM   #7737
They make sealed diffs? Whats the part #? I couldnt find it on their site.
Old 06-04-2006, 05:45 PM   #7738
double post.
Old 06-04-2006, 05:45 PM   #7739
COR79160 I believe. No picture was avalible so I am not posative if thats the new or old style. Someone else might be able to tell you for sure.
Old 06-04-2006, 05:54 PM   #7740
kartermdb's Avatar
Trader Rating: 15 (100%+)
its the old assassin diff, thats completely sealed, but i get about 5 months on a diff, racing outside constantly
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
