Team Corally RDX Touring Car >
Old 05-31-2006, 08:45 PM
  #7711
thx Jeff.
gotyournumber is offline
Old 06-01-2006, 03:16 PM
  #7712
tim fry's Avatar
Hi all
Just finished building my UK-spec RDX and it comes with 2 deg rear hubs but still says to install the 2 washers behind the hinge pin mount giving 4 deg rear toe in. Isn't this too much or should I just try it as it is?
Tim
tim fry is offline
Old 06-01-2006, 05:36 PM
  #7713
Korey Harbke's Avatar
Well... we measure it as 2 deg. It's 2 deg each wheel. Thats a good starting point though, I would just leave and and give it a whirl. If you need to free the back end up any, go to 1.5 deg of rear toe on each side.
-Korey
Korey Harbke is offline
Old 06-01-2006, 05:41 PM
  #7714
TeamPink91's Avatar
I think what he means is that he has the 2 degree hubs on the car and isn't sure if he also needs to put the spacers behind the roll blocks, which would equate to 4 degrees per wheel. Tim, either way you do it just start out at 2 degrees per wheel.
TeamPink91 is offline
Old 06-01-2006, 06:17 PM
  #7715
HarshGuy's Avatar
The Corally guys where tearing it up at the Naionals track today huuweee fast, fast, fast!!!
HarshGuy is offline
Old 06-01-2006, 07:13 PM
  #7716
I just dont remember them comming with 2 deg rear hubs... might be a new thing they are doing. But yes, if it indeed comes with 2 deg rear hubs (it will say directly on the hub), just leave the rear toe shims out.
-Korey
Old 06-01-2006, 07:55 PM
  #7717
Trader Rating: 78 (100%+)
I have two cars for sale if anyone is interested, one for carpet and the other for asphalt.
MUDVAYNE is offline
Old 06-01-2006, 07:59 PM
  #7718
Still Bill's Avatar
-Korey
My UK car kit came with 0 degree hubs. Check again. If it is so, follow Sushi Boy's direction. And consider taking a half a degree out by adding a narrow shim to the front of the inner hinge pins.
Still Bill is offline
Old 06-01-2006, 08:11 PM
  #7719
See I thought so. Mine did a long time ago... but Corally tends to do little updates like that to the kits as we all know.
-Korey
Old 06-02-2006, 08:06 AM
  #7720
Originally Posted by tim fry
Hi all
Tim
Id did that tried it and it did not work took them out and was so much better.
adavison1974 is offline
Old 06-02-2006, 08:26 AM
  #7721
Ollie RDX's Avatar
Just put a 1°shim in the back and 1°shim in the front
that make the car a bit wider in the back(on the rear bulkhead!)! and more stabile! (only if you have 2° rear uprights)
Greetings Ollie
Ollie RDX is offline
Old 06-02-2006, 03:34 PM
  #7722
tim fry's Avatar
It definately has 2 printed on the hubs. I will try it first but I will probably end up taking the shims out from behind the hinge pin holder.
tim fry is offline
Old 06-02-2006, 03:45 PM
  #7723
Jeff Brown's Avatar
REGARDING UK EDITION KITS
There are two different UK Kits. The UK kit shipped to the US is not the same as what is shipped to the UK. I am not totally sure of the differences. I know the UK overseas has nylon steering bellcranks. I do not know what hubs it comes with for sure. They wanted to drop the price in the UK plus have a double diff setup as far as I know.
Jeff
Jeff Brown is offline
Old 06-02-2006, 04:01 PM
  #7724
John Tag's Avatar
Trader Rating: 42 (100%+)
Jeff.. You got PM..
John Tag is offline
Old 06-03-2006, 01:48 AM
  #7725
tim fry's Avatar
Jeff
I've emailed Corally to ask them so we'll see what they say.
On another note I've fitted the bigger bumper but it seems its going to make it difficult to fit a Mazda 6 shell. Should I cut the bumper down? It seems silly to get a bigger bumper then chop bits off
tim fry is offline
