Old 05-22-2006, 01:58 PM   #7576
CrashTstDummy's Avatar
Originally Posted by Mutabarucka
Now that is time for outdoor racing do Corrally make a spool? and with rubbers which setup work better for outdoors spool or oneway.
corally does make both a one way and a spool....which one you use is personal preference.....
CrashTstDummy is offline   Reply With Quote
Old 05-22-2006, 02:06 PM   #7577
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Spools are better for tight tracks were a lot of braking is used. One-ways are generally used on more open tracks were little braking is used, since one-ways are very unstable under braking.
EricO3 is offline   Reply With Quote
Old 05-22-2006, 02:24 PM   #7578
Ollie RDX's Avatar
Send a message via MSN to Ollie RDX
Corally does make a spool but one 5min driving you have to change the blades(driveshaft caps) because they are broken! But the corally spool is the best for the RDX i had the White prototype Delrin spool from corally but that was good to only for a high speed track with lots of braking! The Duraluminium Spool for the RDX is good for both!
Greetings Ollie
Ollie RDX is offline   Reply With Quote
Old 05-22-2006, 02:35 PM   #7579
tim fry's Avatar
Originally Posted by Ollie RDX
The manual shows you how to put a one-way in the front if you drive a diff in the front you just have to do it like the rear diff!
Greetings Ollie
Thanks for the response I have set it as the rear
tim fry is offline   Reply With Quote
Old 05-22-2006, 02:38 PM   #7580
Ollie RDX's Avatar
No Problem my friend
Old 05-22-2006, 02:54 PM   #7581
Thank's guy's for the info, if they make a Duraaluminium then that is the way to go, now where can i get one of the aluminium spool.
Mutabarucka is offline   Reply With Quote
Old 05-22-2006, 03:02 PM   #7582
Korey Harbke's Avatar
Greetings Ollie
Thats why you get some of the super cool Specialized R/C steel blades and special bones for the steel blades. They last a lot longer.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-22-2006, 03:23 PM   #7583
Send a message via AIM to aoizip
Jeff,
what is the part number for the steel bone?
my alum dog bone pin got ripped into pieces!
thanks,
~Ming
aoizip is offline   Reply With Quote
Old 05-22-2006, 03:28 PM   #7584
src 79189 is are the blades and src79182st are the bones Ming
Old 05-22-2006, 11:27 PM   #7585
syndr0me's Avatar
Trader Rating: 32 (100%+)
What are you guys doing to get your ride height to 5mm with rubber tires? I can't seem to get it much below 6.
syndr0me is offline   Reply With Quote
Old 05-22-2006, 11:29 PM   #7586
Just in the front? Or front and rear?
Old 05-22-2006, 11:35 PM   #7587
Jeff Brown's Avatar
I usually back off on the shock collars. Its crazy I know, but try it. LOL.
Make sure you reset the droop. I have never had a problem with 5mm ride height or less on Rubber tire. I've been down as low as 3mm I think before setting the collars.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 05-23-2006, 01:13 AM   #7588
Merciless's Avatar
Send a message via ICQ to Merciless
Just get yourself some associated tc4 spring "perches" and your golden ,you'll never have issue's with getting the ride height down again (part number 6475).
Hope that helps
Merciless is offline   Reply With Quote
Old 05-23-2006, 01:27 AM   #7589
syndr0me's Avatar
Geez, tough crowd!
The preload is backed off all the way, and I backed out the droop screws, and I filled the car with all the electronics and everything that's in there when I drive. The shocks are all the same length, and I believe I have the shock ends on as tight as they can go without pushing the thread into the eyelet. The spring perches seem to be pushed all the way down on the ball ends.
Still, the best I can do (with CS27's) is about 5.5 or 6mm. Now I'm worried that something is wrong, you guys made it seem like an absurd question. :-D The rubber car is built from spare parts, so maybe something is awry. I'm going to build up one with all the good parts (we're done with foam for a while I guess) and then I'll see where I'm at. Nobody runs the lowered shock towers with rubber, right? No weird spacers or anything in the shocks that I should know about?
Old 05-23-2006, 01:32 AM   #7590
syndr0me's Avatar
3mm?! Wow, something must really be wrong then. One end was at 5.5 and one was at 6 with the preload backed all the way off, and droop screws backed out. I set them both at 6 for now, but I guess I need to figure out what's wrong. I -just- rebuilt the shocks a few days ago, too.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
