Old 05-19-2006, 12:52 PM   #7561
syndr0me's Avatar
Trader Rating: 32 (100%+)
With the SRC bumper, the car is a tank. I haven't broken an arm in a couple of months, but they can be somewhat fragile. The new ones seem to be a lot more durable.
Also, get the aluminum steering knuckles, and you're golden.
syndr0me is offline   Reply With Quote
Old 05-19-2006, 02:45 PM   #7562
Ollie RDX's Avatar
Send a message via MSN to Ollie RDX
I still drive with the original bumper and i haven't broke anything in a cuple of months
Greetings ollie
Ollie RDX is offline   Reply With Quote
Old 05-20-2006, 02:32 PM   #7563
Mission_carbon's Avatar
Guys,
I am having some problems with my new Mazda 6 shell mounting on my RDX, the front is fine the wheel arches are all ok with the front etc but at the rear the body posts sit where the wing is mounted and if i move the body back so they are not the rear wheels arent alliend properly with the arches. Any help?
Willz
Mission_carbon is offline   Reply With Quote
Old 05-20-2006, 02:35 PM   #7564
Korey Harbke's Avatar
Originally Posted by Mission_carbon
Guys,
Willz
There should be a slot (older plate) or some holes (newer plate) further in on the rear body post plate. Just relocate the posts to those positions and it'll all line up.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-21-2006, 08:20 AM   #7565
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Few questions
I just picked up a used RDX yesterday, it has silver and black springs on it. Is there any way I can figure out wich rate they are?
Wire dia, number of coils?
How should I gear it with a CO27, and a Orion Element based 19t with laydown brushes.
Tires are 2.30" and has a 64p 108 spur.
The tracks straight is about 80ft, infield always changes, usually has decent flow.
Dayton
1armed1 is offline   Reply With Quote
Old 05-21-2006, 09:43 AM   #7566
Ollie RDX's Avatar
Guys,
Willz
You have to put the post to the inside of your bodypost plate!
Greetings Ollie
Old 05-21-2006, 02:27 PM   #7567
Originally Posted by 1armed1
Few questions
Dayton
The number of coils on the springs is how you figure out which is which. When I get home form work I'll go look at my spring chart and post it here. For the c027... gear it about 1-2 teeth bigger on the pinion than a monster stock. The orion element you can go about 1-2 lower on pinion than a reedy quad mag. It's been a while since I've ran that motor.
-Korey
Old 05-21-2006, 04:35 PM   #7568
1armed1's Avatar
Thanks Sushi,
I'm new to the RDX so I'm not even sure where to gear a monster.
Dayton
Old 05-21-2006, 04:54 PM   #7569
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Start that CO27 at a 32 tooth, possibly a 33 tooth. Go up about 2-3 teeth from that for the Element.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-21-2006, 04:58 PM   #7570
1armed1's Avatar
Thanks Brian
Old 05-21-2006, 05:19 PM   #7571
tim fry's Avatar
Need some help please.
I'm just building my twin diff RDX kit and in the instructions it shows there is a difference between the front and rear diff bearing support inserts but mine look all the same. Is this correct? If it is do I set the front diff for high or low?
tim fry is offline   Reply With Quote
Old 05-21-2006, 05:30 PM   #7572
Trader Rating: 21 (100%+)
The different front one is for a one-way. Dual diff will both be the same. I run mine with the diff down.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 05-22-2006, 11:38 AM   #7573
Ollie RDX's Avatar
The manual shows you how to put a one-way in the front if you drive a diff in the front you just have to do it like the rear diff!
Greetings Ollie
Old 05-22-2006, 01:02 PM   #7574
stiltskin's Avatar
Trader Rating: 102 (100%+)
Need some help please........ If it is do I set the front diff for high or low?
Both diffs should be low. If you raise one of them, it will take away traction from that end.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-22-2006, 01:55 PM   #7575
Now that is time for outdoor racing do Corrally make a spool? and with rubbers which setup work better for outdoors spool or oneway.
Mutabarucka is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
