Team Corally RDX Touring Car >
Old 05-18-2006, 08:18 AM
  #7531
Suspended
McSmooth's Avatar
Talking
Originally Posted by MUDVAYNE
It's one of the finer qualities about ya! lol
He has more than one?!?!?!
McSmooth is offline
Old 05-18-2006, 12:01 PM
  #7532
syndr0me's Avatar
Trader Rating: 32 (100%+)
Man, if you ask about setups for rubber on carpet, RDX guys from the entire world will help you out. That's pretty cool. Corally has built a helpful team worldwide.
syndr0me is offline
Old 05-18-2006, 12:09 PM
  #7533
Ollie RDX's Avatar
Thats right all team drivers help eachother or other corally drivers!
Greetings Ollie
Ollie RDX is offline
Old 05-18-2006, 12:26 PM
  #7534
CrashTstDummy's Avatar
Thumbs up
Greetings Ollie
its not just the drivers who will help you out......jeff brown from Corally and most of their good shops will help anyway they can....
jim
CrashTstDummy is offline
Old 05-18-2006, 12:29 PM
  #7535
Ollie RDX's Avatar
jim
Hi I'm a Corally Teamdriver in Europe
  #7536
John Tag's Avatar
Trader Rating: 42 (100%+)
True.. Now pick up the phone Jim it's been busy..
John Tag is offline
Old 05-18-2006, 12:32 PM
  #7537
Ollie RDX's Avatar
Yeah its true
Greetings
Old 05-18-2006, 06:01 PM
  #7538
Jeff Brown's Avatar
Yeah its true
Greetings
Were you at the 2004 Worlds in Florida? I met someone from Belgium I believe that practiced in Tampa running an RDX.
Jeff
Jeff Brown is offline
Old 05-19-2006, 04:42 AM
  #7539
Suspended
McSmooth's Avatar
Has anyone tried the new arms with foams on carpet yet?
I've found that the additional outer hole on the front arms means your wheels will hit the shocks a lot sooner. Going to have to dial some EPA out of the radio as a result. Is this additional 'outer' hole in the arm meant for rubber tire and not foam?
Does the increased shock angle help make up for some of the lost steering? Will softer springs be necessary up front? Or do you just use the inner hole (which is the outermost hole on the old arms)?
McSmooth is offline
Old 05-19-2006, 07:56 AM
  #7540
Ollie RDX's Avatar
Jeff
No I wasn't there but i have the contract only from this year so!
Sorry Jeff
Greetings Ollie
Old 05-19-2006, 07:57 AM
  #7541
Ollie RDX's Avatar
the outer holes in the new arms are for foamracing!
Greetings Ollie
  #7542
Merciless's Avatar
I believe you just use the inner hole up front and carry on as normal
Merciless is offline
Old 05-19-2006, 08:01 AM
  #7543
Korey Harbke's Avatar
Yeah, thats what I would do. With the 28mm foams we already have issues with steering travel, so on the new arm just use the inner hole.
-Korey
Korey Harbke is offline
Old 05-19-2006, 08:03 AM
  #7544
rayhuang's Avatar
And go up one spring rate I would think.
rayhuang is offline
Old 05-19-2006, 08:04 AM
  #7545
Suspended
McSmooth's Avatar
Thumbs up
Thanks guys, that was kinda my thinking.
The inner hole on the new arm is the same as the outermost hole on the old arm. Don't think I should have to change the front spring.
Inner hole - foam.
Outer hole - rubber.
(that doesn't sound quite right )
McSmooth is offline
