Old 05-10-2006, 11:10 PM   #7381
Originally Posted by Mr. McGoo
here are pics of Team Tamale's shock tower braces - it is just with my camera phone....so sorry for the so-so pics
Just a quick note to you Corally guys. Here is a pic of the lastest shock tower braces. The ones pictured in McGoo's post were the original prototypes. These had holes drilled in them and required a nut on one side to secure the upper camber link mount. In the new version, the holes are threaded 3mm eliminating the need for this nut. You can check them out at http://www.teamtamale.com.
teamtamale is offline   Reply With Quote
Old 05-11-2006, 12:04 AM   #7382
syndr0me's Avatar
Trader Rating: 32 (100%+)
Tamale,
Thank you, that's a great deal. A single shock tower costs more than four of these parts, and it doesn't take much at all to break them if you use the outer camber positions. I ordered mine today.
syndr0me is offline   Reply With Quote
Old 05-11-2006, 01:25 AM   #7383
syndr0me's Avatar
For you guys running foam tires, do you find that you wear down the fronts more quickly than the rears? I'm blazing through front tires these days, especially now that I've got a little more confidence to drive the car harder into and through the turns. Any general advice on what you guys do to your foam tires to make them last as long as possible? Mine don't chunk, they just shrink. I'm running Jeff Cuffs' IIC setup.
Old 05-11-2006, 03:41 AM   #7384
syndr0me's Avatar
Do you guys find yourselves selling a lot of the new bulkheads internationally? Looks like German driver Marc Fischer is using one. Or, maybe Corally has one of their own now?
http://www.lrp-hpi-challenge.de/eppe...C_2843_600.jpg
Old 05-11-2006, 07:23 AM   #7385
HarshGuy's Avatar
Just an FYI for anyone sportin a Corally at the Paved Nationals, 2 degree rear hubs w/standard hexes w/the handout tire will not pass tech, the rear tires do not "roll freely" in and out of the tech box, fronts with 1 degree toe out, standard hexes, handout tires are ok. I put HPI hexes with no extra spacers on the back and that brought it in enough to work.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-11-2006, 08:04 AM   #7386
Korey Harbke's Avatar
Thats just something the RDX does. Since the front of this car is heavier than most cars, the tires tend to wear faster than the rear.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-11-2006, 10:19 AM   #7387
Still Bill's Avatar
syn,
Gotta ask...What tire size are you starting with?
My JRX-S did the same thing with tire wear as does my RDX foam car. For me, that has been the norm.
One thing to consider, is to initially cut your front foams about .1-.2mm larger than the rears. It gives you a bit more of the fronts to work with. I especially like the feeling of the minor overdrive condition it creates...even with two diffs on my RDX.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-11-2006, 12:21 PM   #7388
syndr0me's Avatar
Originally Posted by JRX-S Bill
syn,
Bill
I'm using Parmas (cyan/magenta) and cutting them down to 58mm. I still get a decent number of runs from the tires, but if they lasted anywhere as long as the rears, I'd be a happy guy. I'm running a 4300 brushless in the car, which has got surreal amounts of torque. No matter where I'm at in a turn or on the throttle, if I pull the trigger even a little more, the car launches forward so noticeably that people start whispering and making snide remarks about me, my family, and everybody I know. I'm wondering if that's putting more wear on my tires in the front. I can smooth it out a bit by gearing up, but it's still punchy.
I wonder how terrible the car would handle if I started using all my rear tires that have plenty of life left in them all the way around the car for practice only. :-D
Old 05-11-2006, 12:33 PM   #7389
rayhuang's Avatar
Pretty darn terrible!! Maybe even flip out of the track-especially after they heat up and get covered in sauce from the track.
Old 05-11-2006, 01:35 PM   #7390
syndr0me's Avatar
Dang, maybe it'll explode into flames too! Okay, scratch that idea. :-D
Old 05-11-2006, 02:41 PM   #7391
JohnB's Avatar
R/C Tech Charter Subscriber
Tire wear is my only complaint with the car. I loose .5 mm on the front with each run. I guess a small price to pay with the way the car handles Doesn't seem to matter is I run 19 turn or 8 turn mod, it's about the same amount of wear.
take care
john
JohnB is offline   Reply With Quote
Old 05-11-2006, 03:18 PM   #7392
Still Bill's Avatar
take care
john
That's an abrasive track...
For that much loss, I would attempt to start with .3-.4mm bigger on the fronts. I don't like the handling with smaller fronts than rears (underdrive).
And when you get down to that last minute of the run, they should be pretty close.
Old 05-11-2006, 03:50 PM   #7393
JohnB's Avatar
Yes it is pretty bad. It's not Ozite, it's a black carpet, but has a LOT more traction than Ozite. Luckily I can run them all way down to below 55mm before the fronts start loosing to much traction. I've been running Parma. Got a couple sets of Jaco the wear is the same.
I might try starting out with the fronts a little bigger. I start at 58mm now. All the new ones I have now are already cut so the next batch I'll try it.
take care
john
Old 05-11-2006, 04:00 PM   #7394
Glowster21's Avatar
Trader Rating: 116 (100%+)
These look absolutely AWESOME!!!! I just ordered a set!
Glowster21 is offline   Reply With Quote
Old 05-11-2006, 06:33 PM   #7395
Jeff Brown's Avatar
Which is why everyone puts narrow hexes on the rear of the RDX.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
