Old 05-08-2006, 08:37 PM   #7336
HarshGuy's Avatar
Originally Posted by JRX-S Bill
Qualified 5th. Seemed good; but, the grip was ridiculously high for the race and EVERYONE was surprisingly fast. Got bumped to last on the second lap and got back to 5th by the end.
In those conditions, even a JRX-S was ahead of me for most of the race.
ahhhh ...working on a 19T setup this Friday.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-08-2006, 09:07 PM   #7337
Still Bill's Avatar
And a more forgiving track...Especially the left side...Pleeeeeeeeeeeze...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 05-08-2006, 09:36 PM   #7338
HarshGuy's Avatar
...just don't hit stuff ...I ran 16 packs last friday and didn't break a thing.
Old 05-08-2006, 10:29 PM   #7339
Still Bill's Avatar
Didn't break anything either during Saturday practice; but, sure did do some BIG whacks on dem boards...All on the left side of the track!
Did get a supply of the new arms from Jeff Brown today...Thanks Jeff. Fast shipping by Specialized.
Can carry this on at the other string...Something about Nat Asphalt Champs or something...ummmmmmmm yours.
Old 05-09-2006, 12:45 AM   #7340
Sean T Guy's Avatar
Rod , Having me!!! I think not my friend. If ou are up sunday then bring your bilge to my table and let the LEGEND put it right. Hey did you see me and Justin go out later with stocks , quicker than your time with 19 I do believe , maybe you can use 1 of my stocks
On a side note , Trying to get a set-up for our track from people who have never run there is hard to say the least , the grip levels and adverse corners make the need to change things a little different to other places. The best place to get advise is from is the people who are beating you at that track , so just ask anyone this Sunday .
Schumacher Racing UK
Team Scream UK
eXpress Motorsports UK
FTQ Models
Sean T Guy is offline   Reply With Quote
Old 05-09-2006, 01:16 AM   #7341
Merciless's Avatar
Send a message via ICQ to Merciless
Let us not forget Sean in 19t you out qualified me by a few seconds only, it was my first ever attempt at outdoors to .......
But your right i wasn't impressed at the proformance either , i Believe it was the FIRST time you've ever beat me ?? But hey we all have to learn , as i said i really enjoyed the day and will be back
Merciless is offline   Reply With Quote
Old 05-09-2006, 09:11 AM   #7342
Sean T Guy's Avatar
Let us not forget Rod , I was messing around all day with diffs , 1-ways , and spools , Hey I was even playing with 2 cars so consistancy wasnt my aim. I too had a good weekend and glad you enjoyed and hope to see you this weekend. As for being the 1st time I out-qaulified you Mmmmmm , It sure wont be the last I shall knuckle down with only 1 car this weekend and work on a "nearly" set-up I had and we will see how many seconds or even minutes I out-qaulify you this time. I might even run my 2400's as my 1700 sports pack seems to be fading at 3 minutes.LMFAO
Team Scream UK
FTQ Models
Old 05-09-2006, 09:51 AM   #7343
Merciless's Avatar
LOVING the BANTER "big guy"
Old 05-09-2006, 09:56 AM   #7344
Sean T Guy's Avatar
Its all good... Rod , you got to start running 28's and then go onto 32's later on in the day and that will settle your car down. See me Sunday and I will see if I got any you can use , or ask Colin about the ones I let him use indoors , I'm sure there might be some rubber left on them.
Team Scream UK
FTQ Models
Old 05-09-2006, 10:39 AM   #7345
Steve_L's Avatar
Originally Posted by Merciless
Steve,
I don't suspose you could post me a link or a base set-up you guys would start from normally for tarmac ?? just so i can see if i'm way off base with any settings ??
Hey Merciless,
Base setup normally is:
Front
17lb spring with 50wt oil and Tamiya 3h pistons
Shocks mounted in 3rd hole in the top and all the way out at the bottom.
Camber links mounted in the bottom row, 2nd hole in.
6 degree caster with lowered roll centre blocks up front to give -1.6 antidive
1.5deg negative camber
Rear
17lb springs ,30wt oil ,Tamiya 3h pistons
Shock mounted in 2nd hole in up top and on the extension on the bottom
Camber links mounted on the lowest hole outer and 2nd hole on the bottom row inner.
Diff just on verge of slipping
2deg hubs with 1 degree of inner toe in.
1.5deg neg camber
Hope that helps
(Oh yeah this is for a flat track, at a more bumpy track I put the front arms level or 1.6 kickup.)
Steve_L is offline   Reply With Quote
Old 05-09-2006, 12:30 PM   #7346
Mission_carbon's Avatar
Thanks steve,
I'll be using this on sunday at Cotswolds.
Mission_carbon is offline   Reply With Quote
Old 05-09-2006, 01:54 PM   #7347
Merciless's Avatar
Originally Posted by Steve_L
Hey Merciless,
Front
Rear
1.5deg neg camber
Hope that helps
Thanks for that, there were quiet a few bumps so i don't think anti dive on the front would be good, so would you still recommend the 6deg. blocks or would 4deg. be better with alittle kick up ??
Thanks again
Old 05-09-2006, 01:57 PM   #7348
Robfo's Avatar
merciless what steering are you using, the plastic or aluminium?
Robfo is offline   Reply With Quote
Old 05-09-2006, 02:17 PM   #7349
Drcy's Avatar
Default New "rounded" RDX pistons vs. the classic Tamiya 3 holes
Hi all,
I was trying to figure out the difference in damping between the new "rounded" RDX pistons vs. the classic Tamiya 3 holes with 50W oil front and 30W on the rear.
The point is that I was not able to find a reportable notice..
Does sombody has experience on this???
tanks in advance ...and sorry for starting the "avalanche" abou the new arms/hubs
cheers
Pedro
Drcy is offline   Reply With Quote
Old 05-09-2006, 02:23 PM   #7350
Steve_L's Avatar
Yeah if you are not going with the anti-dive i would go to 4 degrees, if you then suffer from lack of turn in go down to 2 degrees.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
