Old 05-07-2006, 03:58 PM   #7306
kartermdb's Avatar
Trader Rating: 15 (100%+)
the outer rear hole on the new arm is for a completely different hub that isnt available yet, just use the inner hole, thats what i did, i raced the the new arms today and they held up great, nice and beefy, but heavier
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 05-07-2006, 04:53 PM   #7307
syndr0me's Avatar
Trader Rating: 32 (100%+)
Oooh, new hubs, updated arms in the states? Where's the love Corally USA?
syndr0me is offline   Reply With Quote
Old 05-07-2006, 05:11 PM   #7308
Korey Harbke's Avatar
Just to let you know, we are left in the dark at times as well... We had no clue about the new rear hubs they will be releasing especially for the new position on the rear arms untill Corally Intl announced it on their website.
We have made it known Corally is working on new arms for a while. They addressed the problem because people were complaining that the original ones were a little fragile. The new arms are stronger and offer more room for adjustment.
Corally was having some problems producing them for a while, so they are only available in small quantities. Corally USA recieved a a VERY SMALL BATCH. Production will pick up soon, and we'll be getting the new hubs in the states soon as well.
The new outer position will acomidate a entirely new rear hub carrier. When that pivot point it set out further, and the hub becomes narrower, it makes the rear end more stable. Very similar to the idea Losi had on the XXX-S (dont know if they do on the JRX-S though) with standard rear hubs and Offset ones. The offset ones (which are similar in concept with our currently available hubs) will free the car up. The Newer ones which are similar in concept to the Standard style Losi used to have will make the car more stable over bumps and long sweeping corners.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-07-2006, 05:25 PM   #7309
syndr0me's Avatar
Ah, you guys are very forthcoming about information, I didn't mean to insinuate otherwise. There are plenty of people who are fans and the company that aren't privy to the information the team folks are, so we rely on you guys to keep us in the know. Or, going to Corally's international site. :-D
As an additional setting option the rear wishbones feature an added outer hingepin position placing it further into the wheel. This allows less chassis roll resulting in higher cornering speed. New narrow uprights (0 degree toe, #79299) are required to use the additional outer hingepin setting option. These as well as other available narrow rear uprights are to be used with standard width hexes only. The existing rear uprights can be used in the inner position only.
So, these new 0 degree narrow uprights (79299) are different than the new 0 degree narrow uprights (79298) that were just released?
Old 05-07-2006, 05:30 PM   #7310
Yes, as far as I know. Sorry about getting all jumpy like that lol.
-Korey
Old 05-07-2006, 05:30 PM   #7311
syndr0me's Avatar
If they're putting the arms into new kits, I guess I can understand why they had such a small batch to send to their USA distributor.
Old 05-07-2006, 05:35 PM   #7312
syndr0me's Avatar
-Korey
No problem, man, I know I'm a pain in the ass. You guys can all jump me if I ever attend a big race. :-)
I love hearing all about how the team drivers are having a bunch of fun with the new arms, but how there's not many in this batch.
Old 05-07-2006, 05:40 PM   #7313
Well, not very many people have the arms yet. Mine will be here soon and I'll do some testing. I'll let everyone know what I think of them.
-Korey
Old 05-07-2006, 05:58 PM   #7314
Jeff Brown's Avatar
None of the kits we have in stock have the new arms. They are still the standard arms. I am not sure when we will start receiving kits with the new arms.
I don't even have the new arms on my car.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 05-07-2006, 08:35 PM   #7315
ran the new arms all weekend, had no problems with them.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 05-07-2006, 08:37 PM   #7316
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I ran 1 of Cuffs old arms today and was faster with it. Thanks again buddy.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 05-07-2006, 09:03 PM   #7317
syndr0me's Avatar
*sneer*
Old 05-08-2006, 01:41 AM   #7318
Merciless's Avatar
Send a message via ICQ to Merciless
Default NEED HELP PLZ
Hi all,
Ran the car on the weekend , Tarmac with rubber tires, first time i've tried this. I had terrible mid corner push and need help !!
Set-up
Front
17lb spring ,30wt oil ,Tamiya 3hole pistons mounted 2 holes in at the top and all the way out at the bottom.
One-way used
Upper links mounted bottom row 3rd hole in
1.5deg negative camber
4deg caster blocks
Rear
19LB springs ,30wt oil ,Tamiya 3hole pistons mounted all the way out top and bottom
Diff ... set as loose as i could without any slippage on track
Upper links std. position on the hub 2nd hole in bottom row on the tower
2deg hubs used
1deg neg camber
Track was high grip i'm told and it was pretty hot for over here so i was using take off premounted cs 27's . to me they didn't seem to go off through the run so i assumed they weren't over heating
Like i said i have terrible mid corner steering it just seems to take an age to turn, although initial steering is pretty fierce. Sweeping bends are no problem at all, it's the slower 180's that cause the problem when i just have to wait while the car slows enough to go around
Any help please ??
Merciless is offline   Reply With Quote
Old 05-08-2006, 05:30 AM   #7319
CrashTstDummy's Avatar
If All goes well I should have some of the new arms in stock later today...will let everyone know if they arrive.....as Jeff has said they are in very very short supply....
Jim
CrashTstDummy is offline   Reply With Quote
Old 05-08-2006, 06:23 AM   #7320
Just walked in and they had them on the wall at Superior yesterday (Corally USA)
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
