Old 04-25-2006, 01:21 PM   #7141
Trader Rating: 76 (100%+)
Originally Posted by Jason B
I just finished placing my kit and parts order with Jim at AB Charles. He was extremely helpful both through PM's and over the phone. If every hobby shop was as knowledgable about their products as Jim is, there would probably be a many more successful hobby shops. Great guy.
Can't wait to build my RDX!
Jim's the Man!
MUDVAYNE is offline   Reply With Quote
Old 04-25-2006, 01:24 PM   #7142
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally Posted by Jeff Brown
RW gears I believe don't fit because they are a 6 hold pattern instead of an 8 hole pattern. Kimbrough, Corally and other standard 8 hold pattern gears will work. There is no optional adapter.
Jeff
Actually, Jeff, RW gears do fit...at least the ones I've used have.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-25-2006, 01:26 PM   #7143
Jon Williams's Avatar
Jim *is* da man!
Jon Williams is offline   Reply With Quote
Old 04-25-2006, 01:28 PM   #7144
Korey Harbke's Avatar
I think it depends on if you are using 48 pitch rw spurs or the 64 pitch ones. I remember 48 pitch spurs had a slightly different bolt pattern. I just remember xray guys using them for a while complaining they coulding use the 64 pitch gears. I have used the 64 pitch spurs with success on the RDX though.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-25-2006, 01:29 PM   #7145
AdrianM's Avatar
You my have some really old RW gears. I am not aware of any car that the RW's do not fit on. As of December of 2004 RW 64p gears have 12 outer holes just like Kimbrough on the same bolt circle. The inner 6 holes are on the same bolt circle as the inner row on a Kimbrough gear but with only 4 holes. This lets you fit the gear to Xray's 3 bolt gear adapter and everyone else 2 bolt adapter.
The 48dp gears have fewer holes (as they are never used as diff gears) but fit the same.
Adrian Martinez
Old 04-25-2006, 04:01 PM   #7146
Trader Rating: 46 (100%+)
what is the difference between shock piston 79223 and 79224
thanks
josh short is offline   Reply With Quote
Old 04-25-2006, 04:24 PM   #7147
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
79223 has the .9mm holes, 79224 has the 1.3mm ones...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-25-2006, 04:54 PM   #7148
the carpet spec comes with 79223??? according to the manual
Old 04-25-2006, 05:01 PM   #7149
Trader Rating: 18 (100%+)
They changed it to the 79224 a while ago. Your kit should have the 1.3 pistons in it.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-25-2006, 05:07 PM   #7150
ok thanks
Old 04-25-2006, 05:45 PM   #7151
Merciless's Avatar
Send a message via ICQ to Merciless
Hey JEFF,
Don't suspose you could tell me if the NEW bulkheads are in yet ?? Or if mine has been sent ??
Cheers
Rod Mingo
Begining to think your having them imported from another galaxy .....
Merciless is offline   Reply With Quote
Old 04-25-2006, 08:47 PM   #7152
BrianH28's Avatar
I ran my Corally RDX in a race for the first time over the weekend. I broke 2 a-arms in practice (one hard hit and one soft hit). The qualifying went better, but in the second heat if I would just tap a wall the front ball caps would come off. I ended up qualifying third. In the main I had 2 ball caps pop and then I think my Novak 4.5 thermal and I only got 5 laps.
A few questions for you all:
First: What are you all using to replace the Corally turnbuckes and ball caps?
Seconded: Should I cut the blue wire on my Novak speed controller and 4.5 motor? Or should I gear down. Iím running 105/30. 7.0 roll out.
Third: What a-arms would you guys recommend for asphalt track? I have the hard ones on and I just ordered the extra hard ones.
Thanks for any adviceÖ.
BrianH28 is offline   Reply With Quote
Old 04-25-2006, 09:06 PM   #7153
T1Raycer's Avatar
you need the SRC ultimate bumper or take the BRP TC3 bumper at you local hobbyshop and cut it to fit the RDX!! www.corallyusa.com have the desing of th ebumper you can print and cut on the wide BRP TC3 bumper!!
but your best buy will be the SRC RDX bumper combo(Hard Foam and Wide Plastic Bumper)
i use the TC3 turnbuckles but the lunsford titanium its the best!!
and RPM turnbuckles cap are bigger and they are pretty good you cant pop off the rpm jujst like that!! they are tight!!!!
also the new a-arm will be avaible soon but you can still perform whit breaking arm whit the stock one!! i dsont break them often!!!! but if its a big problem for you!! just buy the new stronger arm!! ( they are biffffffff) ehhe!!
Later!!
T1Raycer is offline   Reply With Quote
Old 04-25-2006, 09:49 PM   #7154
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
Anyone have a safe (and secure, and girlfriend-proof) way of fitting an Orion lipo pack into an RDX? I know the battery posts can be shimmed to clamp the pack down to the deck as pictured earlier in the thread, but that's not going (imho) to prevent lateral movement. Looking for some alternative other than Shoe Goo'ing battery straps to the lipos, which would work but would be costly buying either more packs or more straps. Also, as-is the fit is so tight that the top of the battery strap is this/close to binding on the bottom of the upper deck.
Suggestions (with pics?) appreciated.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-25-2006, 09:54 PM   #7155
rcdougie's Avatar
Tape the Lipo pack to the battery strap. That way you can still remove it from the car.
rcdougie is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
