Old 04-24-2006, 11:26 AM   #7111
Jeff Brown's Avatar
Originally Posted by McSmooth
Rob/Jeff:
Since all the kits over the last 6+months have included the new 1-piece, white diff pulleys, maybe Corally should change the packaging for their spool.
Right now, all you get is the aluminum piece. People that bought a kit in the last 6+ months don't have the black 42T pulley or the 3 tiny screws to attach it, and will have to buy those separate. Maybe start including those items in one package, just as is done for the 1-way unit. Makes it a lot simpler.
Yeah, I don't know why they don't just put them in the same bag. Probably because the kit was originally going to be a one-way kit so you would have the pulley. I will shoot an email overseas to suggest it.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-24-2006, 11:28 AM   #7112
Jeff Brown's Avatar
Originally Posted by Customworksking
I will be there with a few friends ...Jeff what setup will U start with?
I'm not totally sure. I was looking at this setup below and probably make some roll center changes.
http://international.corally.com/xls...feld_Stock.xls
Jeff
Old 04-24-2006, 12:09 PM   #7113
Alb are you working today ? Congrats on the new member of the family.
Chris Reilly is offline   Reply With Quote
Old 04-24-2006, 01:37 PM   #7114
Mr. McGoo's Avatar
for those interested - Larry from Team Tamale said he should have the shock tower braces (similar to the T2 braces) done this week sometime - he is going to make a handful so if you are interested shoot me a pm - i think they are only going to be around $12-15 for a set (front and rear)
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 04-24-2006, 01:40 PM   #7115
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Where is the best place to buy a RDX carpet spec. Price and stock!
fpart is offline   Reply With Quote
Old 04-24-2006, 01:48 PM   #7116
Trader Rating: 76 (100%+)
AB Charles and sons 412 561 3068. Ask for Jim. He always has them in stock and I'm not really sure what his prices are on the kits, but I know they have the best deal in the nation!
MUDVAYNE is offline   Reply With Quote
Old 04-24-2006, 03:18 PM   #7117
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by wallstreet
Traction was not very good today and Brian your setup didnt work very well today. Mike Nelson and Brian Koch both ran different setups and Brians was the better of those two. I started with yours from IRP and it was way loose, and i started going towards Koch's setup but didnt get all the way, ran out of time.
IRP currently has way more traction. That may change next weekend, but be prepared to dial in more grip for all 4 corners.
Old 04-24-2006, 07:07 PM   #7118
Originally Posted by barnacle
Duckman - check the snapring/C clip inside the diff. If it is bent at all it will catch and loosen diff, I bent one during a diff rebuild and it took a while to figure it out.
This was the cause of the diff loosening madness... thanks for the advice guys.
duckman996 is offline   Reply With Quote
Old 04-24-2006, 07:16 PM   #7119
koabich's Avatar
Send a message via Yahoo to koabich
Getting out of RC. If anyone is looking for a like brand new RDX that's fully loaded with tons of extra's, please see the link below:
http://rctech.net/forum/showthread.p...46#post2313246
Thanks guys, you've been great!!
koabich is offline   Reply With Quote
Old 04-24-2006, 10:13 PM   #7120
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post setup
Jeff
I will be running Marco Jennings motors he said U knows U I will look u up Friday .....
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 04-25-2006, 01:43 AM   #7121
Default Rw Spur Gears
I have just tried to put RW spur gears on my RDX. However when trying to attach the adapter to the spur i noticed that only two of the screw holes match up with the spur. Is this right or is there another adapter which needs to the be used with RW spur gears.
Cheers
adavison1974 is offline   Reply With Quote
Old 04-25-2006, 06:44 AM   #7122
Default Buying a New RDX
I'm ordering an RDX today and I was just hoping I could get some pointers on what additional items I'll need. Here's my list so far for stock racing on indoor carpet:
- Corally Tool Set (#16070)
- Specialized RC "Ultimate" Bumper
- Silver Spring Set
- Futaba 9550 and Futaba Servo Saver
Am I missing anything? For spares I was told to get a pack of the extra hard arms and front and rear body mounts.
Jason B is offline   Reply With Quote
Old 04-25-2006, 06:49 AM   #7123
kartermdb's Avatar
Trader Rating: 15 (100%+)
get spare front knuckles and arms, unless your track is hard on body mounts, you dont need them, however most people either drill out the stock mount or they swap it for the HPI ones so they can use clips, I prefer the "tophats" myself
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-25-2006, 08:51 AM   #7124
Mr. McGoo's Avatar
- Silver Spring Set
You are on the right path...here is what i have found you need:
- I didn't like the torx screws, so i put regular hex screws throughout, so i didn't get the tool set
- bumper is a must
- the silver spring set comes with it, so get the black set
- futaba 9550 is one of the best out there
- i would get aluminum steering blocks - that is what i was breaking the most - so i spent $40 bucks on those
- i bought the lunsford titanium camber links for easier adjustments for toe and camber
- xray or hpi body posts work great if you want to use regular body clips for your body
- if you are running on carpet:
--lowered shock tower is great
--if you can afford it, it is not a must but is nice - the low roll center blocks - they are around $7-8 for one block and yo will need 8 of them
for spares:
- arms
- nice to have a shock tower or two laying around
- if you don't get the aluminum steering blocks, get some spare steering blocks
- rear body post holder - just in case you get punted into a wall
i think that should get you going - i have bought alot from AB Charles and Son, they are easy to work with and have a wealth of RDX knowledge
marc
Old 04-25-2006, 09:26 AM   #7125
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Mr. McGoo covered it all pretty well. If you get the lowered shock tower for carpet racing, you'll need to take 3 mm off the threaded portion of the shock shaft and the shock end. This keeps the piston in the same place within the shock as it would be with a stock tower.
You should get the Kimbrough medium (for TCs) servo saver. It's black and larger than Kimbrough's small 12th scale servo savers.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
