Old 04-14-2006, 09:48 AM   #7006
hi. is there a problem with the pin in the rear ball diff? they break easy?
XingXing is offline   Reply With Quote
Old 04-14-2006, 09:52 AM   #7007
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Are you referring to the Diff Screw that goes through the middle to hold the two halves together?
EricO3 is offline   Reply With Quote
Old 04-14-2006, 09:57 AM   #7008
yeah the screw/pin that you adjust to set the tightness of the ball diff
Old 04-14-2006, 10:14 AM   #7009
RC_Woody's Avatar
The original ones had a tendancy to stretch and break. If it breaks inside the diff half you basically have to replace the whole diff half.
the new Diff screws which have a solid lip with no threads around the head are much stronger and work well.
If in a pinch and you have the old one use it, but I would replace it ASAP.
Woody
Woody
Sponsored by - My Wallet
LOSI SCTE
Tekno EB48
Home Track: Firridge Raceway, Scappoose OR
RC_Woody is offline   Reply With Quote
Old 04-14-2006, 11:23 AM   #7010
Originally Posted by RC_Woody
Just to confirm that this is a common thing, I too had the same problem.
Diff would back way out, because the C clip was catching. Rebuilt, put a new clip in and haven't had a problem since!
Woody
I will try that ... I really hope that it is the solution to my problem. Thanks for the advice guys.
duckman996 is offline   Reply With Quote
Old 04-14-2006, 11:29 AM   #7011
Woody
You can actually get the broken screw out without damaging the hub ... what I have found is that if there is enough of the screw visible, take a small file and file a slot into the screw - then use a small slot screwdriver to unscrew the broken part from the hub. Now if Corally would sell the plastic insert seperately, you can actually drill out the old plastic unit (carefully) and replace it with a new one ... Corally - any chance that the insert can become available seperately???
Old 04-14-2006, 11:33 AM   #7012
CrashTstDummy's Avatar
Post
Duckman.check where you buy your Corally parts from and they may have the small insert to give you as a replacement at no cost
CrashTstDummy is offline   Reply With Quote
Old 04-14-2006, 12:05 PM   #7013
RC_Woody's Avatar
I'm not sure what you mean my drill out the old plastic unit, but if you look at a undamage diff half, there is actually threads in the metal part of the diff half that the diff screw threads into right before it reached the plastic insert.
Also if you do happen to salvage a diff half that you think will still work, Call CorallyUSA and they will send you some of those black plastic pieces.
Woody
Woody
LOSI SCTE
Tekno EB48
Old 04-14-2006, 02:24 PM   #7014
EricO3's Avatar
The plastic insert comes out easily if you heat it up with a hair-dryer/heat-gun. No need to drill it out really.
Old 04-14-2006, 09:09 PM   #7015
Jeff Brown's Avatar
Hopefully we will offer the snap rings and diff nuts seperately. The Snap rings are easy. The diff nuts we currently provide for a quick fix for people at no charge. The new diff bolts seem to be working out nicely. If you see your diff loosen from one run to the next and you tighten it a couples, STOP. The bolt is probably stretching. So save some hassle and swap it out.
One thing we recommend is to use loctite on the screw even though it is going into plastic. The diffs seem to hold up better all around if you apply a dab.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-16-2006, 10:18 AM   #7016
Trader Rating: 38 (100%+)
Originally Posted by 1shnot
ok thanx alot guys
I'm not gona worry about it until someting major hapend with it....
I'm looking for a very responsive car almost too twichy lol, only on power that is.. may be my car is too new at the momment belts,diffs,cvds....
like I said b4 out of the box it was ALMOST good as my year old fk05 and I had that thing dialed!!!!!!! AWESOME CAR!!!!!!!!
So has this been a problem? I have the EXACT same problem. My car shakes violently when I turn the wheels to a certain point. Definately seems to be some kind of frequency thing b/c the point it happens changes based on speed. At lower speeds I have to set my EPA down to around 30% to get it to not do it. I cant image I will be able to get much of a turn at 30%. The shaking seems awfully violent for there not to be something wrong. Its definately not hitting on anything. Perhaps its a problem in my diffs? They are a bit wobbly but I have rebuilt them a couple of times to try to eliminate it and just cant do it.
or8ital is offline   Reply With Quote
Old 04-16-2006, 10:23 AM   #7017
Jeff
I just ordered a couple of the new diff bolts ... and a couple rebuild kits. I hope that the snap ring has been my problem.
Old 04-16-2006, 10:27 AM   #7018
Woody
Sorry - to be more clear, one you remove the broken screw and if you find that the plastic nut as found in the drive cup is damaged (stripped, etc), you can drill it out from the outdrive side and replace it with another nylon nut ...
I made this recomendation before I knew that you could remove the plastic with a little heat and Corally has the replacements.
Old 04-16-2006, 12:27 PM   #7019
Korey Harbke's Avatar
The diff pulleys should wobble a tiny bit. The Diff probably wouln't work properly otherwise. Do you only notice the shaking when the car is driving or when the tires are lifted off the ground? They will do that when there isnt any weight on the tires... All cars will do that to a certain extent.
I have a problem when I was using the CVD bones for the steel blades. The pin shifted slightly and moved so it was hitting the bearing that retains the diff. This caused the car to do all sorts of funky things, but you wont have this problem with the standard bones.
How big of a circle can your car turn around at low speeds?
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-16-2006, 08:44 PM   #7020
tbeardmore's Avatar
I think I know what your "shaking" problem is.
I think it's the outer CVD "Cross pin" that drives the FRONT outer axles. The "set" screw may not be tight. If the set screw isn't tightened properly the drive pin will shift - hence rubbing on the INSIDE of your steering blocks.
If you have the aluminum steering blocks - it'll be easy to see if there's been some "pin rubbing" on the inside. If you are using the black plastic steering blocks the pin "wear" markes may not be as easy to see.
I've actually had a pin loose like that and it worked it's way into the holes where the C-Hub pins are and completely lock up the axle/wheel.
An easy fix for this is to "dremel" a flat spot in the center of the "cross pin" so when you re-tighten the set screw that holds it in place - the set screw will have a liitle more grip to hold onto. (ps. put a small amout of threadlock on the tip of the set screw- that'll help also)
Hope this fixes your ~SHAKE~ ??
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
