Old 04-12-2006, 11:02 PM   #6976
Had a re-occuring problem tonight ... as did my friend that also races an RDX. On both of our cars, we have been having a problem with our diffs losening off during our runs... the front diff on my car and the rear diff on his. His car is three races old, and my diff is three race days old (with entire ceramic rebuild). We race in the 19 turn class so the motor's power should not cause this problem.
It was so bad that for my last run I tightened the diff so that it would almost act like a spool and it still losened off about 2 minutes into the run.
Has anyone else had this happen on their car? If so, what caused it? We were pulling our hair out today - and we almost resorted to rock-paper-scissors to see who got to race with 2 good diffs. We must have rebuilt our diff about 10 times today trying to figure this out.
duckman996 is offline   Reply With Quote
Old 04-12-2006, 11:03 PM   #6977
Originally Posted by 1shnot
Had heck of a time with my diff tonight, just a rear one keeps getting loose and even when it's tight, it's still little too loose for my driving style.....
anyone have a diff for sale? i'm loking for fully built one......
[email protected]
come-on man.....
Old 04-12-2006, 11:07 PM   #6978
Trader Rating: 8 (90%+)
check your diff screw it might be bent or broke!
Johnny Carey is offline   Reply With Quote
Old 04-12-2006, 11:24 PM   #6979
1shnot's Avatar
Originally Posted by duckman996
come-on man.....
KAAAMONG MANG!!!!!!!!!!!!!!!!!!!!!
p.s still looking for fully built diff to BUY!!!!!!!!!
1shnot is offline   Reply With Quote
Old 04-13-2006, 12:14 AM   #6980
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by EricO3
Anybody make something that covers the bottom of the chassis for Asphalt racing? Kind of paranoid about scratching the chassis at my first Asphalt race . Something sort of thick, would like to stay away from a little sheet of "sticker". Was thinking I could get a small sheet of lexan (dont know where I'd find any) or some type of plastic and cut it out to the chassis, coutnersink a couple holes in it and screw it on through a couple of the screws in the bulkheads. Any other ideas?
Your local hobby shop should have one of these. It's adhesive, and you can trim it to match your chassis. I used one on my RDX last summer during a moment of weakness when I thought I wanted to race on asphalt.
http://www2.towerhobbies.com/cgi-bin...?&I=LX2553&P=7
Edit: I think I just deciphered your post and realized you said you didn't want something like this. It's thick, and works pretty well. Not sure what else you could do.
syndr0me is offline   Reply With Quote
Old 04-13-2006, 05:27 AM   #6981
Trader Rating: 76 (100%+)
I've heard several people talk about this, and the only thing that can come into my mind would be that either the screw is striped, or its on the wrong side of the diff. Check your instruction manual and make sure that it's built correctly and that the screw is on the correct side. I've seen guys do this before with other cars and the same thing has happened. Also maybe check and make sure your cone washers haven't flatened out and go from there. Just my .02. Jeff Brown would probably have some more insight on this.
MUDVAYNE is offline   Reply With Quote
Old 04-13-2006, 06:02 AM   #6982
Suspended
McSmooth's Avatar
Exclamation
How about the COR78400 Undertray rain cover??? You would only need the bottom half of it.
JEFF BROWN - Does CorallyUSA have any of these in stock?
McSmooth is offline   Reply With Quote
Old 04-13-2006, 06:19 AM   #6983
Trader Rating: 21 (100%+)
Been dealing with that since I got the car myself.Any ideas would be appreciated here too.Mario.
lotus1 is offline   Reply With Quote
Old 04-13-2006, 07:11 AM   #6984
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i would replace the cone washers to start... and maybe check the thrust bearing... maybe? are you using 4 or 6 cone washers?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-13-2006, 08:16 AM   #6985
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have found for some reason (maybe I am wrong) that one of the thrust plates is different from the other and if they aren't in the right way I had my diff come loose as well.
Maybe its just me but I tried it both ways and one way worked perfect the other well, after three runs the diff got loose.
Also try the new diff screw and new cone washers. Use 6 to be sure.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-13-2006, 08:21 AM   #6986
Riketsu's Avatar
Send a message via AIM to Riketsu
-Shookie <><
Where can I buy the new diff screw?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-13-2006, 08:26 AM   #6987
Corally Usa.
There is a link if you hit Corally in my signature.
Here is the link to the screws...
http://www.corallyusa.com/2005/parts/77162.gif
just order part number #77162
-Shookie <><
Old 04-13-2006, 08:31 AM   #6988
Duckman - check the snapring/C clip inside the diff. If it is bent at all it will catch and loosen diff, I bent one during a diff rebuild and it took a while to figure it out.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 04-13-2006, 09:12 AM   #6989
I ran 2, 4, and 6 cone washers without any luck... though two would allow for more screw surface to make contact within the plastic nut that is pressed in the outdrive. Thanks for the suggestion though...
Old 04-13-2006, 09:13 AM   #6990
I will look into that... that it the only thing that I haven't checked.
Thank you.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
