Old 04-05-2006, 09:06 PM   #6916
RC_Woody's Avatar
Originally Posted by koabich
Constant toe out does give you more initial on-power steering. But remember that bump steer gets worse as the suspension compresses. So think of it like this: Going into the turn, you have minimum bump steer but as you reach the apex of the turn, your car leans over more and more causing inconsistant toe throughout the turn. This leads to inconsistant handling because though out the turn, your toe is constantly changing.
Thats what I was thinking that it would be inconsistent, but I was also wondering if it was what Big rigg said, Is the toe -out on the outside tire or the inside tire? It makes sense that steering would be worse if the outside tire has toe-out.
Woody
Woody
Sponsored by - My Wallet
LOSI SCTE
Tekno EB48
Home Track: Firridge Raceway, Scappoose OR
RC_Woody is offline   Reply With Quote
Old 04-06-2006, 07:55 AM   #6917
koabich's Avatar
Send a message via Yahoo to koabich
Woody
As I stated in my first post, when you turn left, your right suspension arm is the one that compresses. So a car with bump steer would have toe-out on the outside wheel.
koabich is offline   Reply With Quote
Old 04-06-2006, 08:27 AM   #6918
RC_Woody's Avatar
I guess I didnt read it careful enough. That makes sense now.
Woody
LOSI SCTE
Tekno EB48
Old 04-06-2006, 08:38 AM   #6919
koabich's Avatar
No problem at all...I hope this helps as was not too confusing!!
Old 04-06-2006, 10:16 AM   #6920
RC_Woody's Avatar
without having my car infront of me to test this... If the outside tire gets some toe-out, then does the inside tire get some toe-in?
Woody
Woody
LOSI SCTE
Tekno EB48
Old 04-06-2006, 10:50 AM   #6921
stiltskin's Avatar
Trader Rating: 102 (100%+)
Woody
It's possible. The amount of toe in you would get would depend on how much droop you allow. Less droop = less toe in.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 04-06-2006, 01:30 PM   #6922
1shnot's Avatar
Finally went out to try out my rdx fot the first spin yesterday.....
It was good.. I got it almost good as my fk05( had the car for over a year) just out of the box!!!!!!!!!!
Only thing I couln't figure out was when I turn the steering to either side it would shake like crazy!!! as if it was rubbing on something... It wasn't. I've tried to limit my exp + d/r on my m8 but when it gets around 80% or higer it would shake so bad I was affraid to drive it...... Any one?
only thing I could think of is -shim behind the wheel adptor with tamiya shims
Help!!!!!!!!!!!!!!!!!!!!!!!!
thanx alot guys
1shnot is offline   Reply With Quote
Old 04-06-2006, 01:38 PM   #6923
Korey Harbke's Avatar
You could try that, sometimes it's just the cvd's chattering. The only way you can really fix that is to turn down your steering travel like you already have. Also, put a shim or spacer on the steering knuckle where it hits the caster block at full lock steering. This will prevent the inside wheel from turning too far and putting the cvd's at an extreme angle. I would just dial in more steering through suspension setup to get it to rotate more. The result will be a much smoother car.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-06-2006, 03:29 PM   #6924
T1Raycer's Avatar
New arm is now available!!
http://www.corally.com
T1Raycer is offline   Reply With Quote
Old 04-06-2006, 03:48 PM   #6925
1shnot's Avatar
-Korey
Thanx for the quick reply.....
I'm sorry but I don't quite understand,I was thinking putting the shims on behine the cvd pin... just b4 the hex adaptor.. is that what you are saying?
if not would you happend to have any pics on it? that would help alot
thanx again
Old 04-06-2006, 08:12 PM   #6926
Jeff Brown's Avatar
thanx again
There is not much gap between the pin and knuckle. So, shims would not help much. I think Korey meant putting them between the wheel itself and the hex.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-07-2006, 12:03 AM   #6927
syndr0me's Avatar
Trader Rating: 32 (100%+)
Looks like new arms and narrow rear hubs are on the list of things to buy. Presumably, we'll want the harder arms for carpet.
Can we pre-order? Please please? :-)
syndr0me is offline   Reply With Quote
Old 04-07-2006, 12:09 AM   #6928
syndr0me's Avatar
I haven't broken an arm in months, but I had to switch to soft arms up front. Seems like now that I'm driving better, I hit stuff mainly with the front of the car. I've killed a bumper plate and kydex lower bumper, but no arms. More durability is good though. I wonder if I'll need to stock on up hingepins.
Old 04-07-2006, 07:38 AM   #6929
1shnot's Avatar
Jeff
yeah... found out shimming between the pin and the hex does not help nor putting the shim between hex and the tire does not help either..... I still get the violent shakes when I turn my wheels what is going on?
Is this a common thing for rdx? or just mine?
Old 04-07-2006, 08:03 AM   #6930
JohnB's Avatar
R/C Tech Charter Subscriber
Does it shake when the car is sitting still or just when moving?
If so, are you sure it's not just your servo? Try disconnecting the turnbuckle on the servo and turn the wheel.
Also, have you set the End Point Adjustment so the servo does not try to keep turning after the steering blocks have hit the lock?
take care
john
JohnB is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
