Old 04-04-2006, 01:11 PM   #6871
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by CrashTstDummy
alot of guys are using the rpm 4-40 cups with the lunsford Ti turnbuckles and they seem to work out quite well
Got it.Thats what I was looking for. I think however that the ball grippas on schumacher's site come in sets of 8 cups and 8 ball studs.
Old 04-04-2006, 01:34 PM   #6872
Default Getting ready for outdoors
I have a carpet edition RDX. I'm going to start racing modified rubber tire outdoor on asphalt. What are the must have parts?
2.4mm top deck ?
spool ?
oneway ?
2.4mm chassis ?
etc.
PhatPat is offline   Reply With Quote
Old 04-04-2006, 01:40 PM   #6873
Pat Clark's Avatar
Yea but just remember that the top c-hub screw has the ball on it....
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
Old 04-04-2006, 02:03 PM   #6874
Korey Harbke's Avatar
If it were me, I would grab the 2.4mm upper deck, a spool, and a black spring set. If you seem like the car gets really weird whent he temperature rises then maybe grab the 2.4mm main chassis as well. It tends to make the car a little easier to setup on asphalt.
A Front one way might be a good thing to have. I dont find much of a benefit for it outdoors. I do like them on indoor asphalt and carpet tracks though.
Since you are running modified, the spool will give you some more forward traction off the corner, and enable you to apply the brakes without the worries of the car just spinning out on you like a one way will. Hope that helps you out some.
-Korey
2.4mm top deck ?
spool ?
oneway ?
2.4mm chassis ?
etc.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-04-2006, 02:14 PM   #6875
Thanks for your help
Old 04-04-2006, 02:51 PM   #6876
DOH! Good thinking. I had not thought of that. Thanks.
Old 04-04-2006, 03:29 PM   #6877
1shnot's Avatar
Default any pics?
Just finished building a rdx.... very limited space, anyone have a closeup pics on their neat electronics layout????? I'm using spectrum+q2.....
Thanx
1shnot is offline   Reply With Quote
Old 04-04-2006, 04:29 PM   #6878
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i have been using RPM ball cups on the stock balls... works fine, either with original 3mm turnbuckles, or lunsfords. i have one with each....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-04-2006, 04:48 PM   #6879
koabich's Avatar
Send a message via Yahoo to koabich
Thanx
I run the same set-up. And while I do not have photo's, there will be more than enough room for the ESC and receiver to laying flat on the chassis as opposed to standing them on their side or stacking the receiver on the servo.
koabich is offline   Reply With Quote
Old 04-04-2006, 06:04 PM   #6880
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
kinda stupid question but how do yuo guys get the same steering trow on both sides? mine is always off. even if i do it on my setuop board. any tips or tricks are greatly appreciated.
Z.Hallett is offline   Reply With Quote
Old 04-04-2006, 06:17 PM   #6881
T1Raycer's Avatar
mine is off also what i do is do litle circle (Full Sterring) onn the track and look how big is the circle you do whit the car!!! do the same thing the other side and if your circle is litle wider you need more dual rate on this side !! do it when your car do the same circle both side!! if your D/R its like 80% one side and 75% they other and your car do the same circle its ok ( for the pro its not ok they ahve to see the same number each side) but for amateur club racer its pretty close just 5% difference
Later!
T1Raycer is offline   Reply With Quote
Old 04-04-2006, 06:52 PM   #6882
Any problems dialing in more than 1.5* of front camber whn using the upper outer most position on the front lowered shock tower? (ala the McGreevy setup) With the stock turnbuckles and cups the turnbuckle threads in to the cup so far that it distorts the cup and doesn't allow the cup to move freely when I get near 1.5* or so of front camber.
Old 04-04-2006, 07:00 PM   #6883
kartermdb's Avatar
Trader Rating: 15 (100%+)
put a set of rear turnbuckles on the front to get more camber, thats what i did
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-04-2006, 07:19 PM   #6884
Dang you guys think of everything!!
"Don't foget the upper c-hub screw incorporates the ball stud"
"Try using a rear turnbuckle in the front to get more camber"
Brilliant I say!!
Old 04-04-2006, 07:28 PM   #6885
koabich's Avatar
Mine is perfect but then again I set aside several hours one night making sure it was so.
The first thing is to make sure the center link that attaches one bell crank to the other is at a length so that the center bellcranks are dead parrallel.
Next you have to make sure the link that attaches the steering servo to the bellcrack is dead accurate as well. With the servo attached to the bellcrank, you need to make sure that the bell cranks are now pointing directly north and south. Do this whith your radio tuned on so you can also center the servo with on the radio making your efforts more accurate.
Once this is set, I made sure that the links that attached the bellcranks to the steering hubs were both identical in length.
Getting the steering perfect can be difficult because no matter what you do for whichever car, there will always be some degree of slop or play. Just take your time, adjust, setup, readjust and resetup. Eventually you will get there.
One point I find very helpfull which I have seen nobody do is the fact that I check my steering on a Hudy setup system with my radio ON. Before taking the reading, I throw the steering wheel on the radio left and then right several times. This makes sure that the servo is center when you take the readings and it also gives you readings that would be more race-condition like than using a dead servo. I find that using a dead servo to make steering adjustments can be difficult because of slop...there will almost always be 1 to several degrees of play or difference with each reading. But with the radio ON and the servo now powered, the steering system, regarless of play will usually always center itself.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
