Old 03-29-2006, 01:33 PM   #6721
syndr0me's Avatar
Trader Rating: 32 (100%+)
So then, it's just your opinion, and not based on your superior knowledge of fluid mechanics, dynamic systems, and mechanical vibration?
syndr0me is offline   Reply With Quote
Old 03-29-2006, 01:44 PM   #6722
Suspended
McSmooth's Avatar
OK, genius:
For internal incompressible flow, the flow rate of a fluid is defined as:
Q = (pi*delta p*diameter^4) / (128 *mu*length)
and the average velocity is:
V = Q / A
Nowhere, in either equation, is the "amount of fluid on top of the piston" even a factor. Flow through a hole is a product of cross-sectional area only, and not volume. All of the other variables are contant (viscosity, diameter, length, pressure, etc)
McSmooth is offline   Reply With Quote
Old 03-29-2006, 02:01 PM   #6723
syndr0me's Avatar
Well, it's hard to argue with the facts. Clearly we're all unnecessarily butchering our shock shafts, and should heed your expert advice. Touché.
Old 03-29-2006, 02:13 PM   #6724
The Teacher's Avatar
Trader Rating: 49 (100%+)
McSmooth, I think in some cases you might be right on this...but this depends on a few factors that you are not mentioning....Tire size, ride height and shock position. Also, you didn't mention that when you use the Associated spring retainers it allows the shock to compress more before any load is put on the spring, which is what needs to happen when you use the lower shock tower. I don't think you trick will work with any size tire....
The Teacher is offline   Reply With Quote
Old 03-29-2006, 02:51 PM   #6725
CrashTstDummy's Avatar
Post
actually i do happen to know McSmooth does run several different tire sizes and yet changes nothing in the way his shocks are set up....i know this because he trues his tires with our truer.
CrashTstDummy is offline   Reply With Quote
Old 03-29-2006, 04:46 PM   #6726
Trader Rating: 76 (100%+)
When did this go from having fun with a toy car to quantum physics?
MUDVAYNE is offline   Reply With Quote
Old 03-29-2006, 04:56 PM   #6727
BrettBowen's Avatar
Send a message via AIM to BrettBowen
You guys put oil in your shocks?!?! Dorks....
BrettBowen is offline   Reply With Quote
Old 03-29-2006, 05:12 PM   #6728
rc_bam226's Avatar
Yes, we attach the flux capacitor to the ESC, and therefore.....
rc_bam226 is offline   Reply With Quote
Old 03-29-2006, 05:35 PM   #6729
Post
Hey Kenny you need to change your avatar to say "Fast Chargin"...
Old 03-29-2006, 05:59 PM   #6730
Suspended
McSmooth's Avatar
BOTH! Physics was my minor in school.
As for the Associated spring retainers, they're only used for 'geometry'.
It put the spring lower on the shock, so that more threads are available to run larger tire sizes. I can run as big as 60mm quite easily.
Old 03-29-2006, 06:11 PM   #6731
Trader Rating: 52 (100%+)
Originally Posted by McSmooth
OK, genius:
V = Q / A
damn...and you race toy cars
I have been running the car for 2 years and havent cut anything but the spring retainers so they sit lower and it gives me 10 times more droop than I will ever run, although I think the biggest tire I can run is 2.30, but on foams
I think the car is prime on 2.22-2.25.
Mo
Mo Denton is offline   Reply With Quote
Old 03-29-2006, 06:22 PM   #6732
Post
Well I guess if both McSmooth and Mo Denton dont believe its necessary to cut the shafts then it should simply be something that is the judgement of each individual opinion.....thanks Mo
Jim
Old 03-29-2006, 06:30 PM   #6733
Oh so now I'm hard and fast huh? lol
Old 03-29-2006, 07:14 PM   #6734
stiltskin's Avatar
Trader Rating: 102 (100%+)
I've tried it both ways and found that it doesn't make a bit of difference. I still hit the wall at the same speed.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-29-2006, 07:38 PM   #6735
Send a message via AIM to ERTRACHTER
[QUOTE=Jeff Brown]I am flying up for the race. If you have any questions let me know. I will start with either Rob's setup or Jason's from the IIC.
my car was good in vegas fellas give it a shot
ASSOCIATED 12r5.1,REEDY MOTOR AND BATTERY, LRP SPEEDO,KIMBROUGH PRODUCTS,BIG DOG RACING,BELMONT R/C SPEEDSHOP, DENNIS LYMAN RACING, TEAM TOSO, TEAM FACTORY BITTER, SCHUUR SOLUTIONS, SIMMONS RACING, TEAM BOOZCRUZ
ERTRACHTER is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
