Old 03-29-2006, 08:26 AM   #6706
CrashTstDummy's Avatar
Post
Hey Jeff!!...whats the word on the new arms??..........just joking!!!!....
CrashTstDummy is offline   Reply With Quote
Old 03-29-2006, 10:12 AM   #6707
Trader Rating: 76 (100%+)
I would like to thank Ray Derrock and Danny Hartman on this thread as well for all their help and support throughout the weekend. You guys really made my car 100 times better than whet it was. All they have to do now is work on the driver, lol. You guys and the AB Charles team are really making this a really fun hobby and I can't wait to see whats in store in the future. Thanks again for all your help.
MUDVAYNE is offline   Reply With Quote
Old 03-29-2006, 10:23 AM   #6708
gibbous's Avatar
Originally Posted by kobiwan
On the subject of the lowered front shock tower, Are you supposed to cut both the shock shaft 3mm and the eyelet 3mm or just one or the other?
Are people cutting the e-clip end and just cutting new slots for clips? Or does there happen to be enough thread on the threaded end to take some off there? Alternatively, is there another part that you could swap in?
gibbous is offline   Reply With Quote
Old 03-29-2006, 10:34 AM   #6709
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking race
Originally Posted by Jeff Brown
I am flying up for the race. If you have any questions let me know. I will start with either Rob's setup or Jason's from the IIC.
Jeff
COOL it will be nice to meet U thanks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 03-29-2006, 10:34 AM   #6710
koabich's Avatar
Send a message via Yahoo to koabich
No, you cut the threaded ends of the shock. No worries, thee is plenty of material. You also cut the shock ends too.
No other parts.
koabich is offline   Reply With Quote
Old 03-29-2006, 11:15 AM   #6711
syndr0me's Avatar
Trader Rating: 32 (100%+)
I wonder if Corally will come out with a lowered shock tower kit for the shocks in the future? Some shortened shafts and ball ends would be sweeeet.
syndr0me is offline   Reply With Quote
Old 03-29-2006, 11:34 AM   #6712
Post
It wouldnt surprise me since Corally remains on the cutting edge with upgrades rather than wholesale changes in kits
Old 03-29-2006, 12:37 PM   #6713
Suspended
McSmooth's Avatar
Don't mean to stir the pot, but I've found that cutting the ends of the shock shafts it completely unnecessary.
I only cut 3mm off the eyelets, and use the Associated spring retainers, and have plenty of room.
And before anyone tells me the piston will hit the bladder/top of shock....
take a look at your shock while it's on the car and at the correct ride height. Push down until your chassis nearly hits the ground and notice how far the shock shaft moves in....less than 3/16 of an inch. The threaded portion doesn't even enter the shock body.
So there's no way the piston is going to go "too far" while the car is running on the track. If you're THAT worried about it, get the Tamiya 3-hole pistons that's everyone's raving about, and put them in the "lower" position (since they're thinner than the Corally ones and have to be shimmed...put the shim on the top).
McSmooth is offline   Reply With Quote
Old 03-29-2006, 12:42 PM   #6714
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
It's more than that, McSmooth.
When you make the piston's "neutral" position higher in the body, there is less volume of shock oil for it to push up and against. It changes the dampening characteristics.
I've also found that it is hard to get less than 2 mm droop over ride height (without compromising ride height) if you do not also cut the shock shaft.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-29-2006, 12:45 PM   #6715
Suspended
McSmooth's Avatar
Haven't had a single problem with either, and I've been running them this way for the last 6 months.
Old 03-29-2006, 12:50 PM   #6716
koabich's Avatar
I know this issue comes up a lot with real cars and people using lowering springs but keeping the same shocks. May not cause a problem right away and it may not bottom out, but it does not place the piston in the best or optimal position within the shock body causing premature wear and less than optimal performance.
Plus, you may be fine without cutting the shock shafts but I definately had too. What works for one does not work for another. Plus with having the best car out there and all the money invested into it that you have, why half-ass it? It takes about 1/2 hour to do correctly and once it's done, it doesn't have to be done again!!
As far as the Tamiya piston, still does not solve the problem because the shock shaft is still the same length and the shaft is what will hit the bladder.
Plus there will always be the chance that the shock will hit the bladder. Just pushing the car down on a flat table until the bottom of the chassis "nearly" hits does not cut it. Forces under racing are always more extreme than playing with the car on a set-up board...Murphy's Law...if it can happen it will!!
Old 03-29-2006, 01:02 PM   #6717
Suspended
McSmooth's Avatar
You can try to justify it all you want, I have found it completely unncessary. If you have nothing better to do and want to cut them, then knock yourself out.
If you want to get into Fluid Mechanics, dynamic systems, and mechanical vibration (shock theory)...then bring it.
It all is nothing more than "Hey, so-and-so did it, so I better do it too!"
Nobody is going to convince me otherwise.
Old 03-29-2006, 01:05 PM   #6718
gibbous's Avatar
That may be true for full scale, but I don't think it's much of an issue here.
All in all, I don't think it matters either way, but FWIW,
The amount of oil resting on top of the piston does change, but the dampening action should not signfiicantly change, it will still take a certain amount of force to move the piston through the oil at a certain speed. As for wear, you're looking at having the o-ring rub against the shaft at a different location than usual. Unless I'm missing something I don't see the issue here, to be honest.
Old 03-29-2006, 01:27 PM   #6719
syndr0me's Avatar
I can't think of an ulterior motive for suggesting people trim their shock shafts, since nobody is making money on it. Presumably, people are making that suggestion in good faith, and the honest belief that is makes a difference.
McSmooth, instead of trying to intimidate us with the threat of debating fluid mechanics with you, perhaps you can "bring it" to us first by using that knowledge to provide definitive proof that this is an unnecessary modification.
Old 03-29-2006, 01:31 PM   #6720
Suspended
McSmooth's Avatar
Doesn't get any simpler than this:
1. I've tried it both ways already.
2. Didn't make a bit of difference.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
