Old 03-28-2006, 11:07 AM   #6676
LANCEisaCRACKER's Avatar
See, unless I did something wrong, my dad is the one that paints them and mounts them. And all the alignment was perfect. Just the body touched the towers. and theres nto front or rear, so its not like i have the shock towers mixed up.
Im getting fustrated because the RDX is starting to become a money pit.
LANCEisaCRACKER is offline   Reply With Quote
Old 03-28-2006, 11:13 AM   #6677
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking rdx
Hello I am going to S&N Trackside @ the end of April for a stock rubber race where can I find a good starting setup for a 1way,spool or diff....Thanks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 03-28-2006, 11:19 AM   #6678
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Try Jason Ertrachter's setup from the IIC. I'm working on my own concoction that seems to be really fast, as well.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-28-2006, 11:33 AM   #6679
Post ok
I will start with it LMK what changes U make as well please thanks Kevin
Old 03-28-2006, 12:08 PM   #6680
JKA
My hood does touch the front tower, but it only "rests" there. I keep it from rubbing paint off by using a little glaze of shoe goo. Good luck.
JKA is offline   Reply With Quote
Old 03-28-2006, 12:28 PM   #6681
Lightbulb
@ the novak race toso helped me with my car and the 1st thing he told me to do is add 2 shims under the couplers in the frt does the rdx like a narrow frt end as the IIC setup....
Old 03-28-2006, 01:08 PM   #6682
Keep the front end wide. It keeps the car more stable and also makes it initiate faster.
USVTA Member #211
Old 03-28-2006, 01:08 PM   #6683
koabich's Avatar
Send a message via Yahoo to koabich
Hello,
Just wondering if there was any information on when the 4mm chassis's will be available? I have a new bulkhead just sitting there waiting to be used!!
koabich is offline   Reply With Quote
Old 03-28-2006, 01:51 PM   #6684
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
As far as chassis go...a thicker/stiffer chassis will never hurt you on carpet. It allows the suspension to do all the work and the car will be more consistent.
Vaguely related question... if running on asphalt is the 2.4mm chassis (and upper deck) really needed, or can one get away with running the standard carpet spec chassis with just the 2.4mm upder deck?
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 03-28-2006, 03:53 PM   #6685
The standard chassis works fine for asphalt for most conditions. If it's really hot then the 2.4 mm chassis will help. The standard chassis and topdeck or 2.4 mm topdeck work fine.
USVTA Member #211
Old 03-28-2006, 04:31 PM   #6686
Slingblade's Avatar
I broke my diff screw. Does anyone have the part numbers for twhat I need to fix it? I couldn't get that DA^$ black plastic nut out. Do I have to buy a WHOLE new diff to get that plastic nut thinggy?????? Please HELP!!!!!!
Slingblade is offline   Reply With Quote
Old 03-28-2006, 06:31 PM   #6687
On the subject of the lowered front shock tower, Are you supposed to cut both the shock shaft 3mm and the eyelet 3mm or just one or the other?
kobiwan is offline   Reply With Quote
Old 03-28-2006, 06:35 PM   #6688
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Both
EricO3 is offline   Reply With Quote
Old 03-28-2006, 06:42 PM   #6689
what's the difference between running a 100 spur vs. a 110 spur?
and does it matter what stock motor you run with these spurs(like this stock motor performs better with this spur etc.)?
bosfan is offline   Reply With Quote
Old 03-28-2006, 08:22 PM   #6690
Jeff Brown's Avatar
I am flying up for the race. If you have any questions let me know. I will start with either Rob's setup or Jason's from the IIC.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
