Old 03-25-2006, 07:27 PM   #6631
Trader Rating: 46 (100%+)
have a website or part number??? also what shock oil does everyone use??
josh short is offline   Reply With Quote
Old 03-25-2006, 08:18 PM   #6632
Jeff Brown's Avatar
The hex screw was a temp screw used while waiting for the upgraded style we are used too. It is an upgraded screw but not exactly what they wanted.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-25-2006, 09:24 PM   #6633
Korey Harbke's Avatar
What type of racing are you going to be doing? Carpet with rubber or foam tires? Asphalt on rubber?
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-25-2006, 09:59 PM   #6634
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
sorry guys to bother you but let me ask you some Questions.. i need to know should i get aluminum parts or stick with the graphit or plastic parts that it would replace? and also give me a list of things that i should stock up on for extra parts i know to get the carriers but other then that and ball ends what else? And also like to know what type oil i should run in my car for oval carpet foam tires? i was going to say 40 or 50 not sure thats what i run in the tc4 didnt know if it would be the same about on the rdx thanks
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 03-25-2006, 10:10 PM   #6635
I have everything stock on my car as far as the suspension goes. It already has a lot of aluminum goodies and stuff. I'd rather break a plastic arm than bend bulkheads or suspension mounts.
Things I always have spares of are blades for the CVD's, Arms (I prefer the X-tra hard 75% graphite arms), a few steering knuckles if you dont already have the aluminum ones. I try to keep a few 5x9 bearings on hand too... they go in the hubs and tend to wear out every now and then. Other than that I havent had any major issues.
Shock oil...... 40-60wt is usually good. Just depends, it should be too different than your tc4. For most racign I always start with 60wt up front and 40wt in the rear. Hope that helps ya out.
-Korey
Old 03-25-2006, 10:48 PM   #6636
syndr0me's Avatar
Trader Rating: 32 (100%+)
Man, I'm like Captain Corally, defending this car's honor in all corners of R/C Tech.
*wields mighty keyboard*
syndr0me is offline   Reply With Quote
Old 03-25-2006, 11:11 PM   #6637
subman's Avatar
Has anyone else had a problem with rear shock towers? I have broken almost one per weekend.
subman is offline   Reply With Quote
Old 03-25-2006, 11:25 PM   #6638
syndr0me's Avatar
I was blazing through them when I had my camber links in the outer most holes like a lot of the setups use. I moved them in one hole and haven't broken one since. I do wish there was a little more "meat" on the tower to support the outer hole.
Old 03-26-2006, 01:24 PM   #6639
Trader Rating: 17 (100%+)
Jeff, I seen in a resent catalog that was sent to me from you guys that there is a clear chassis protector/cover. Do you have a part number because I cannot find the catalog anymore? Thanks!
429racer is offline   Reply With Quote
Old 03-26-2006, 01:42 PM   #6640
Do most people run 2 degree rear hubs with rubber tires on asphalt/carpet or shim the arms? Running Takeoff CS27 tires how many shims do you use behind the front roll center blocks?
Old 03-26-2006, 03:38 PM   #6641
syndr0me's Avatar
Looks like you can buy the undertray from Corally USA here:
http://www.corallyusa.com/istar.asp?a=6&id=COR78400!COR.
Old 03-26-2006, 05:22 PM   #6642
Trader Rating: 21 (100%+)
Default wow
1st race,pole to pole win.Awesome.Have a problem tho.The rear diff keeps loosening.Had to retighten each heat.Barked thru the main.Any ideas on a fix for this.My kit has the newer bolt with the shoulder on it.It also has the screwdriver slot head.Someone said there is another updated bolt out there.Any help is most appreciared.Mario.
lotus1 is offline   Reply With Quote
Old 03-26-2006, 05:49 PM   #6643
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Well if the diff was a fresh rebuild they do have to break in and be tightened slightly after each run to keep them from "barking" or slipping.
TeamPink91 is offline   Reply With Quote
Old 03-26-2006, 06:06 PM   #6644
BrettBowen's Avatar
Send a message via AIM to BrettBowen
If you put a good sized washer between the stud and the tower it disperses a lot of the load and prevents them from breaking so easily. Hope that helps. Also, something Jeff Cuffs does is just runs a standard stud, not the extended one. He claims that it keeps them from breaking, and typically when Jeff talks, its a good idea to listen
Brett
BrettBowen is offline   Reply With Quote
Old 03-26-2006, 07:26 PM   #6645
syndr0me's Avatar
Brett
Wow, that's great advice, thank you!
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
