Old 03-24-2006, 04:27 PM   #6616
HarshGuy's Avatar
Well, I have this weekend to get my rig ready for asphalt as I'm off on vacation the 2 after that then our 1st race of the season is 04/15. Does anyone have a good setup for an asphalt - smooth track? Last year I ran an FK05 at the track so I don't have a starting setup for an RDX, I race out at Speedworld Raceway, this is a pretty typical layout:
http://www.speedworldraceway.com/Track_Photos.cfm
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 03-24-2006, 05:25 PM   #6617
i currently run the standard roll blocks in the lowest position (carpet spec)
i want to know what performance gains i will get if i use the optional low roll blocks & will i have to adjust my setup for them?
bosfan is offline   Reply With Quote
Old 03-24-2006, 08:06 PM   #6618
BrettBowen's Avatar
Send a message via AIM to BrettBowen
The option roll center blocks are to accomodate high traction situations. It keeps the car flatter and prevents tipping/traction rolling. Something that worked well for me at a club level with not much traction is running the options in the front, and standards in the rear, this give the car a lot of steering with little traction, but at big races the option blocks help a lot, makes the car much easier to drive. However, TJ Bradley did really well at a lot of big races with the standard blocks, definitely something worth trying though, especially if you run on a high-bite carpet track.
Brett
BrettBowen is offline   Reply With Quote
Old 03-24-2006, 08:17 PM   #6619
LANCEisaCRACKER's Avatar
There are new roll center blocks? where i been
LANCEisaCRACKER is offline   Reply With Quote
Old 03-24-2006, 08:30 PM   #6620
Still Bill's Avatar
They are the optional low roll center blocks at about $8.95 each. Takes eight of them to do it all the way around; so, you are looking at about $70-80 total.
#79121 Hingepin Adjustment Block, Low (1 Pc) - Dural.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-24-2006, 11:22 PM   #6621
Soviet's Avatar
Way too much $$$ for simple hingepin blocks. It's a crime what the "options" cost for this car.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 03-24-2006, 11:32 PM   #6622
Slingblade's Avatar
No doubt!!! It is not just the options that are expensive!!
Slingblade is offline   Reply With Quote
Old 03-24-2006, 11:58 PM   #6623
RCFREAK's Avatar
Trader Rating: 17 (100%+)
just bought another new us spec kit(dual diffs) i was checking out the diffs and saw that mine came with a diff bolt with a hex head screw... and it was threaded all the way down... i thought the new diff bolt was better.. is this new or better by using the hex head?? i do have extra new revised bolt ... should i just go ahead and install the newer style in it??
glad to be running a new RDX again!!! nothing like having a new kit.... had to shelf the T2 !!! possibly gonna get rid of it.. cant get it consistant at different tracks!!
thanks
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline   Reply With Quote
Old 03-25-2006, 08:36 AM   #6624
thanks
The new bolts as far as I know still have the standard screw type head, but the bolt is supposed to have a solid shoulder on the threads not threaded all the way down.
On another note Jeff, I seen in a resent catalog that was sent to me from you guys that there is a clear chassis protector/cover. Do you have a part number because I cannot find the catalog anymore? Thanks!
429racer is offline   Reply With Quote
Old 03-25-2006, 08:39 AM   #6625
CrashTstDummy's Avatar
Post
For any of the Corally guys going to the Gate for the Grand Finale in April parts will be there if needed during the weekend. We will be bringing all of the parts and kits we have in stock to the race along with accessories.
Jim
CrashTstDummy is offline   Reply With Quote
Old 03-25-2006, 11:24 AM   #6626
syndr0me's Avatar
Trader Rating: 32 (100%+)
That's weird about the screw heads. Even my original UK kit had the flat head. How else would you make diff adjustments without removing anything?
You should post a picture of that diff screw, I'm curious to see it.
syndr0me is offline   Reply With Quote
Old 03-25-2006, 11:42 AM   #6627
Merciless's Avatar
Send a message via ICQ to Merciless
congrats guys on your Nats results
Merciless is offline   Reply With Quote
Old 03-25-2006, 04:42 PM   #6628
thanks
You will notice that there is a cut off allen wrench in your kit that you can use to adjust the diffs.
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 03-25-2006, 07:16 PM   #6629
Trader Rating: 46 (100%+)
What 64 pitch spur gear do you guys run in the car??
josh short is offline   Reply With Quote
Old 03-25-2006, 07:25 PM   #6630
I run precision racing. they have two type of spur gears. one for tc, one for oval. you want to purchas the oval 64 pitch spur gear for OVAL because the screw layout on the rear tensioner is different then stock ones.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
