Old 03-23-2006, 10:39 AM   #6601
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by andyuk99
OK Thanks. We don't have that in the UK. Looks like will need to wait for Holland to produce it and then we will get it.
Specialized R/C is a brand that's apparently run by the same guys as Corally USA. They create parts for the RDX (and others, it seems) like the 4mm chassis, and this new motor mount. I haven't heard anything about Corally producing this piece directly. I'm sure the SRC guys would be kind of bummed if they do, since they probably paid a bit of money to get this latest batch machined.
Regardless, if you feel you need it, Jeff said they will ship them worldwide. It moves the motor in by 5mm (closer to the centerline of the car) which helps with overall balance, and apparently makes the car transition faster. Since Tosolini just used it as part of his winning setup for the nats, I imagine everybody will think they need one.
Personally, since I'm running brushless, I'd like to get some of the motor weight toward the center so I don't have to load up the right side with weights to balance things out. I don't think I'm good enough to notice the other changes just yet.
syndr0me is offline   Reply With Quote
Old 03-23-2006, 10:44 AM   #6602
syndr0me's Avatar
Originally Posted by LANCEisaCRACKER
I just dont get how the heat sink is the only thing that is bigger, and it requires modification? Is it that critical to purchase this, will I be blown or left out of the water if i dont have this?
The heatsink is bigger because the motor is moved inwards by 5mm. The larger heatsink is just because there's more material there than the stock bulkhead to accommodate the change of motor position.
Many people won many big races prior to this new bulkhead being released. I would say the car is just fine without it, though having it certainly won't hurt anything, and might help a little depending on your needs.
Here's a picture of the bulkhead to make it a little more clear on how it's different.
Old 03-23-2006, 10:57 AM   #6603
Jeff Brown's Avatar
Are you guys talking about this part ?
RDX Offset Motor Mount
PART NO. SRC79206
SPECIAL INSTRUCTIONS:
MOTOR AREA MUST BE CUT TO ALLOW MOTOR CLEARANCE
So I assume Corally will be making their own version ?
Specialized RC is the US Importer for Corally products. The DBA name is CorallyUSA. Any products under SRC are designed and developed by us. International orders can be placed for the SRC line of products. We do not ship Corally products internationally as there are other importers. SRC can be picked up by distributors and/or dealers overseas as well.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-23-2006, 07:02 PM   #6604
LANCEisaCRACKER's Avatar
thanks for the information. my other thing was, how do you make the mods? i am consider getting this, and i would like to know how much of a mod has to be done, and where. do i have to drive any new holes in the chassis?
LANCEisaCRACKER is offline   Reply With Quote
Old 03-23-2006, 07:11 PM   #6605
tc3blue's Avatar
You can't do it by yourself, you have to send the chassis back to corally to cut some material out to make more space for the motor mount, then you can just install it.
Read back a few pages, ppl were talking about this.
tc3blue is offline   Reply With Quote
Old 03-23-2006, 07:18 PM   #6606
Still Bill's Avatar
Default Snap ring pliars
Where do I find a set of miniature snap ring pliars to change out the thrust bearings?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-23-2006, 07:20 PM   #6607
stiltskin's Avatar
Trader Rating: 102 (100%+)
Sears
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-23-2006, 07:34 PM   #6608
Still Bill's Avatar
Originally Posted by stiltskin
Sears
Thanks. I did see some fairly large looking ones in the Sears on-line catalog.
Any miniature units out there for hobbyists?
Old 03-23-2006, 07:38 PM   #6609
stiltskin's Avatar
Sears has a small set for about 8 bucks.
Tony Rumple
Old 03-23-2006, 07:39 PM   #6610
HarshGuy's Avatar
I got mine at sears, they work perfectly ...go to the store
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 03-23-2006, 07:41 PM   #6611
Big Rigg's Avatar
I have these and they work great
http://www.galesburgelectric.com/store/product.php?productid=1817
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 03-23-2006, 09:54 PM   #6612
CrashTstDummy's Avatar
actually if you read back acouple of pages you will in fact see the mods can be done if you take your time using a dremel and acouple of pieces listed
CrashTstDummy is offline   Reply With Quote
Old 03-23-2006, 10:33 PM   #6613
Soviet's Avatar
Originally Posted by Sushi Man
can someone post pics of how they mount a novak GTX on this car? thanks
There you go!
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 03-24-2006, 06:20 AM   #6614
HarshGuy's Avatar
Yep ...I did I posted the pics and items I used on my dremel, just make sure to wear a mask and long sleeve shirt ...lots of graphite dust.
Old 03-24-2006, 09:41 AM   #6615
RC_Woody's Avatar
I could only find the large ones at Sears too. Napa auto store actually carries a set of 4 minitures, I picked up for about $12
Woody
Woody
Sponsored by - My Wallet
LOSI SCTE
Tekno EB48
Home Track: Firridge Raceway, Scappoose OR
RC_Woody is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
