Old 03-10-2006, 08:06 AM   #6241
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking mount
I seen the team drivers useing the new mount at the Novak race
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 03-10-2006, 08:17 AM   #6242
Jeff Brown's Avatar
Originally Posted by josh short
i just put my rdx carpet spec together and noticed that there are no shims for the cvd s to take up the slop do you guys shim so no slop ??
I assume you mean behind the hexes. It doesn't require shims. You should be able to get the play out just by pushing the hexes on all the way.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-10-2006, 08:21 AM   #6243
Jeff Brown's Avatar
Originally Posted by HarshGuy
In regards to using the Tamiya 3 hole pistons in the shocks, I'm curious how *big* of a difference it makes, or more to the point *what* difference it makes ...same thing with the extra long rear shock extensions, I tried the non-viagra version of the extensions and they really made a difference, I loved the way they felt compared to no extensions ..at this point any changes I make I can't test till round 1 of practice at the nats .
Also does anyone have some pics of the extra long chingaderas and how they mounted the shocks to them? Using a ball stud and ball cup on mine rubs the rear tires, so I must not be doing something right? Or using the wrong studs, or something!!
You need to put your tires on the truer and shave off the foam that overhangs on the insides. I even grind about 1mm off further, I do that front and rear. You have to use 79263 ball studs I believe.
The Tamiya pistons have more "pack" and react quicker. The car doesn't feel so dumpy and rolls less through the corners. Transitions side to side better due to the more pack.
Jeff
Old 03-10-2006, 08:23 AM   #6244
Jeff Brown's Avatar
Yeah, there were a few floating around but we found out they were not perfect. So we got them back and made changes.
Jeff
Old 03-10-2006, 08:59 AM   #6245
After putting a couple club races on the RDX, I have to say that I am REALLY impressed. Using the Dayger set-up with a couple little changes, this car is dialed. Although I was skeptical about the internet hype surrounding this car, I am pleasently surprised. I have just made the switch from another company and I cannot believe the on-power stearing of this car.
Adding to the performance of this car is the performance of the customer service ... great job guys - I am now officially a convert.
duckman996 is offline   Reply With Quote
Old 03-10-2006, 09:12 AM   #6246
HarshGuy's Avatar
Jeff
Oh great, I got a factory guy's not perfect reject
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 03-10-2006, 09:42 AM   #6247
Jeff Brown's Avatar
Trust me you would know. They were so far off the topdecks had to be dremeled.
Correction...... you need 79264 for the extensions. Not 79263, this is used on the steering knuckles to fix the bump steer.
Jeff
Old 03-10-2006, 09:49 AM   #6248
Trader Rating: 18 (100%+)
Who ....me?
Where's my $10 then?
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 03-10-2006, 10:20 AM   #6249
Default rollcenter
If I want more on-power streeing ....If I use the stock couplers to raise the rollcenter on the rear and use the low on the FT? ....running stock foam thanks
Old 03-10-2006, 12:01 PM   #6250
Jeff Brown's Avatar
Yes, that will help the car rotate more on exit of the corners. You may have too much front droop, I would drop to about 1mm in the front if you are running more.
Jeff
Old 03-10-2006, 04:22 PM   #6251
subman's Avatar
Originally Posted by subman
can someone post a pic of how they mounted the motorguard/fan. where they dremeled ect.
anyone?
subman is offline   Reply With Quote
Old 03-10-2006, 09:35 PM   #6252
Trader Rating: 8 (90%+)
Here are some pictures of my car... Just got anodized Hot Pink.. Looks good!!
Johnny Carey is offline   Reply With Quote
Old 03-10-2006, 09:44 PM   #6253
Still Bill's Avatar
Put the belt tension pulley wheel on no matter what class you run.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-10-2006, 10:10 PM   #6254
edit...
HEWITT is offline   Reply With Quote
Old 03-10-2006, 11:00 PM   #6255
Jeff Brown's Avatar
I have never used the belt tension pulley with my 7 turns. You can use it, just put it halfway back on the topdeck. Do not put it immediately behind the front pulley.
Jeff
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
