Old 03-04-2006, 07:12 PM   #6091
ebone's Avatar
hey guys looking for a used diff for the rdx, it would appear stock foam is all the rage and i only have the oneway. please help.
ebone is offline   Reply With Quote
Old 03-04-2006, 09:34 PM   #6092
Jeff Brown's Avatar
Originally Posted by BritRacer
ok, how much do i need to take off the shock shaft to run the lowered tower??
I tried the associated spirng retainers, no good...
Running the stock tower at the moment.
Also, I have ordered some tamiya pistons, but could i just make my own from the stock corally piston? What is the hole dia that I would need.
3mm on the shaft and eyelet. You can use the stock spring cups then.
Well, depends what you define as the "stock" corally pistons. The kits used to contain 0.9mm pistons but for last 6+ months they have had the 1.3mm pistons.
The 3 hole Tamiya pistons are 3 small holes, around a #58 drill bit i think. So that is no where near 3 holes of the 1.3mm which is like a #54 if you drilled it. If anything you would take the 0.9mm pistons and add a 3rd hole.
Or take the 0.9mm pistons and drill them to a #56 size. I think we need more options in Touring Cars. haha.
Follow that? haha.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 03-04-2006, 09:37 PM   #6093
Jeff Brown's Avatar
Originally Posted by syndr0me
7. A bulkhead to move the motor closer to the center of the car.
http://www.corallyusa.com/specializedrc/rdx.htm
Waiting on more to be made.
Jeff
Old 03-04-2006, 09:38 PM   #6094
BritRacer's Avatar
Follow that? haha.
Jeff
Thanks!!
I also ordered some tamiya pistons, but for tomorrow I will try adding a 3rd hole to the stock ones, time permitting...
thanks again, the car is realy smooth....
BritRacer is offline   Reply With Quote
Old 03-04-2006, 10:42 PM   #6095
Mr. McGoo's Avatar
well, i took my rdx on its first outing, and without knowing exact setup, i can say i am impressed - other than the fact i had a 6.5mm front ride height i was too scared to take down the shafts too much.
i am going to talk to larry of team tamale, to see if he can make a lowered shock collar - he makes them for the xray, but the eyelets are just a little bigger on the xray
i am waiting on the black spring set and the aluminum steering blocks are on back order (does anyone know where i can get them?), i bought the lowered shock tower, and have so beefed up arms on order too.
all i can say is wow, my first time out with a dayger/mcgreevy combo setup it felt pretty good....not great, but i didn't expect it too - especially with my ride height being jacked....
all this to say...i am a happy corally convert.....
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 03-04-2006, 10:50 PM   #6096
Chris Adams's Avatar
except for that broken arm...
*giggling*
jk, I still haven't made up my mind Marc. Ill trade you car for car.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 03-05-2006, 12:21 AM   #6097
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
glad you like, Marc! i think the setup still on my foam car from the last time i was down at Mikes is McGreevys, with a copper bar on front.
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-05-2006, 07:12 AM   #6098
Mr. McGoo's Avatar
*giggling*
hardy har har har - actually the broken arm is not my fault - car glitched on the back straight and took a hard right into the wall....
Old 03-05-2006, 08:21 AM   #6099
Dont you have spectrum???
Texas EOS 2018!
Old 03-05-2006, 07:17 PM   #6100
BrettBowen's Avatar
Send a message via AIM to BrettBowen
Hey Guys that are heading to carpet nats....
I just got done running at our Region 11 regionals, we had it setup just like Carpet Nats. Same Carpet, Similar layout, and everyone used jack the gripper. I ended up with a pretty funky setup that worked REALLY good. Consisted of a 14.5lb rear spring, 33 front, Standard shock mount in the rear (not the extension) Ultra low roll centers in the front, standard in the rear, Jaco Dbl Pink/Dbl Pink Orange tires, 45-60wt oil etc... if you want more details pm me and ill give you the setup sheet. Very good in 19T and Stock, might be a lil soft for mod though.
Might wanna give it a shot!
Brett
BrettBowen is offline   Reply With Quote
Old 03-05-2006, 07:39 PM   #6101
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Wes, try my new one, it's better!
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-05-2006, 10:17 PM   #6102
BritRacer's Avatar
Glitching was really bad today too...ruined my racing Didnt run the RDX as I was in a hurry and didnt want to rush cutting the shock shafts.
I put the spare arms and t2 shock towers under your door.
Old 03-05-2006, 10:39 PM   #6103
Turbonium's Avatar
which new one? and is it posted on the website, or is there a special handshake involved? j/k!!!
send it over, and ill give it a whirl... we had a carpet track open up in Joplin, about 100 miles from home. kinda small, but its a closer drive than the previous 280!
Wes
Team Novak
Old 03-05-2006, 11:25 PM   #6104
RobertV's Avatar
Brett
Or.... you could ask one or more of the Corally drivers from the host track (Stockton RC Raceway) who have been tuning the setup for months.
RobertV is offline   Reply With Quote
Old 03-05-2006, 11:27 PM   #6105
The one from the Novak race. I have since gone to 50 wt rear oil and it feels good so far, but I have to do more testing to see if it's faster. I also want to try 4 degree caster blocks with this setup but a local teammate of mine has 'em and is holding them hostage! j/k justin
As for the handshake...didn't you get the memo?
USVTA Member #211
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
