Old 02-28-2006, 07:55 PM   #5986
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Brit, you'll see as soon as you start building
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-28-2006, 07:55 PM   #5987
Still Bill's Avatar
Originally Posted by HarshGuy
Have you guys found that with the specialized chassis and top deck, you are overwight for ROAR foam T2? ....I'm about 13 grams over in stock and 33 grams over in 19T ...without adding any weight whatsoever.
Poor baby!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-28-2006, 07:59 PM   #5988
kartermdb's Avatar
Trader Rating: 15 (100%+)
just use the weight to carry more entry speed which means more corner speed, which means you go faster
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-28-2006, 08:03 PM   #5989
BritRacer's Avatar
Pretty impressed so far, didnt even know it came with aluminum hubs!
The guys on the T2 forum can go back to their undying lovefest for their Xray baby.
BritRacer is offline   Reply With Quote
Old 02-28-2006, 08:24 PM   #5990
Jeff Brown's Avatar
With a 7 turn I am only 7 grams over.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-28-2006, 08:30 PM   #5991
Jeff Brown's Avatar
Originally Posted by MUDVAYNE
Hey Jeff, 0 degree caster blocks on your car? wouldn't that make the car seem a little darty? I run 6 on my asphalt car, with a spool and 1 degree rear toe in on the rear. I'm thinking of trying a sway bar in the front to see if I can get the front to stop sliding because of the spool, as I believe the front inside tire is lifting up too much. I have about 1 mm of droop in the front and 2 in the rear. I also have no couplers in the front (very narrow front). Let me know what you think about the sway bar. Thanks,
Kenny
Hey Kenny......
Well, first off......... I never knew that "darty" and "asphalt" could be associated with each other. Remember, I run modified so a 7 turn might yield a different feel than 19T or Stock. You may need to stiffen up the front springs.
The 0 deg blocks increases initial steering, helps with low speed steering and makes the car feel more "direct" on steering inputs. I have been a fan of it for a while. But I guess I might be weird.
Jeff
Old 02-28-2006, 08:37 PM   #5992
HarshGuy's Avatar
Jeff
Ah ..ok so it's "normal" ...I've only ran rubber tire big races before, so I was used to having to add weight in order to make minimum.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-28-2006, 08:40 PM   #5993
Jeff Brown's Avatar
Yeah.
The 4mm chassis is heavy, couple that with the thicker topdeck. Then you throw into the mix the different motors and their weights.
19T being the heaviest cuz of the most arm material and wire. Then Stock with a lot of wire but no arm material. Then you have the Mods with standard arms and no wire. haha.
Jeff
Old 02-28-2006, 08:41 PM   #5994
Guilty...at the Novak race I was 36 g over
That is however, with 24 g added to balance the chassis. As long as you're not like 50-60 g too heavy, it won't make a huge difference.
USVTA Member #211
Old 02-28-2006, 08:48 PM   #5995
Yep, having to add a brick on the chassis behind the battery to balance the car really sucks. That darn motor sticks out too far. Hope Corally hurrys up with a new left rear bulkhead that moves the motor in farther. I can't even imagine how bad the balance would be when adding a motor guard/fan unit.
Stealth_RT is offline   Reply With Quote
Old 02-28-2006, 08:50 PM   #5996
HarshGuy's Avatar
I posted over on the On Road Rules discussion thread posing the question how the difference in weight was figured out for the ROAR T2 minimums:
http://www.rctech.net/forum/showthre...7336&p=2173229
Old 02-28-2006, 08:55 PM   #5997
Jeff Brown's Avatar
Hmmmmmmmmmm................
Old 02-28-2006, 09:03 PM   #5998
Number 11's Avatar
Originally Posted by Sushi Boy
Sure did, TQ and win too. The Car was diaaaaled. With a CO27 stock motor I rolled out at 26.88mm, but for a Monster I would run about 25.2mm. If the motor fades... trim the trailing edge of the brush a touch.
-Korey
Cool thanks I just got a C027 so I will try the old and new motor.
Number 11 is offline   Reply With Quote
Old 02-28-2006, 09:08 PM   #5999
Korey Harbke's Avatar
F brushes, small cavity drilled in them, with red springs was dialed for the co27.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-28-2006, 11:27 PM   #6000
BritRacer's Avatar
are these the low roll centre blocks for carpet, or are there ULTRA low blocks...
http://www.corallyusa.com/istar.asp?a=6&id=COR79121!COR
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
