Old 02-19-2006, 09:52 PM   #5881
HarshGuy's Avatar
OK version 2 of the editable RDX setup sheet is done ...the "dots" are bigger as well as the weight numbers, should be easier to read than 1st version:
http://www.gearchart.com/index.cfm?f...tsblank&type=1
The one titled "Editable Corally RDX Blank Setup Sheet"
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-19-2006, 10:05 PM   #5882
Still Bill's Avatar
Default Eye Test
So that wasn't my eye test for racing in the Nationals???
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-19-2006, 10:23 PM   #5883
kartermdb's Avatar
Trader Rating: 15 (100%+)
unfortunately im not able to use that sheet cause my roll center option isnt a choice, o well, very nice though, looks awesome
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-19-2006, 11:38 PM   #5884
HarshGuy's Avatar
What roll center option? you mean the ultra lows? there is a dot under the 1, I guess I could add the text "ultra low" to it, but there is a dot under the "1"
Old 02-20-2006, 12:40 AM   #5885
HarshGuy's Avatar
OK, now the "Ultra Low" option says "Ultra low" next to it.
Old 02-20-2006, 12:52 AM   #5886
FBJ's RDX's Avatar
Default Ultra Low Couplers/Mounts
Hi, can you use the Ultra Low Couplers on Asphalt? Thanks
Sonny
FBJ's RDX is offline   Reply With Quote
Old 02-20-2006, 04:18 AM   #5887
Merciless's Avatar
Send a message via ICQ to Merciless
Thanks HarshGuy sheets great
NOW !!
For more mid corner steering do i ......
Go for a longer front camber link or Anti squat on the rear first ??
This lack of steering is only apperant on 180deg slow corners in the very middle of the turn on a neutral throttle, rest of the time the cars great
think these are the options i should look at first but if you have diffeent idea's please pass them on ....
Cheers
Rod
Merciless is offline   Reply With Quote
Old 02-20-2006, 06:22 AM   #5888
kartermdb's Avatar
your sheet does look great, i am using the ultra low blocks, but they would be in spot "5" based on the numbering system, and yes i know, its very high. just a suggestion, has anyone seen a set up sheet where there is a place to put if the diff is in the upper or lower position??
Mark Burt
Thanks to:
Old 02-20-2006, 07:44 AM   #5889
HarshGuy's Avatar
...so you're using the ultra lows "upside down"?
Old 02-20-2006, 07:46 AM   #5890
kartermdb's Avatar
yes, in the top row of holes, upside down, and using and old c4 parts on the rear of the front arms to get it up there
Mark Burt
Thanks to:
Old 02-20-2006, 08:47 AM   #5891
Drcy's Avatar
Default Ultra low Couplers
Hi,
one photo would make my day...
thanks
Cy
Drcy is offline   Reply With Quote
Old 02-20-2006, 09:38 AM   #5892
HarshGuy's Avatar
WOW ...ok, well the editable sheet won't work for you ;-) ....use the notes section to type out the change
Old 02-20-2006, 11:21 AM   #5893
Jeff Brown's Avatar
Sonny
You can use them on Asphalt but I would not recommend it. The car will be lazy feeling and roll too much.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-20-2006, 11:23 AM   #5894
Jeff Brown's Avatar
NOW !!
Cheers
Rod
Well, a longer camberlink would lower the roll center a bit and help with steering through the whole corner. I would lean towards that option.
Jeff
Old 02-20-2006, 06:46 PM   #5895
kartermdb's Avatar
let me know what you guys think
Mark Burt
Thanks to:
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
