Old 02-18-2006, 03:19 PM   #5866
Trader Rating: 76 (100%+)
Originally Posted by Sushi Boy
The motor guard/fan mount is available right now. So are the narrow rear hub carriers, and the 3 deg caster blocks as far as I know. The New suspension arms will be here soon. I'm not sure about the sp12X though. Hopefully soon because I cant wait to start running one.
-Korey
What will the narrow hub carriers do for the car?
MUDVAYNE is offline   Reply With Quote
Old 02-18-2006, 03:31 PM   #5867
Korey Harbke's Avatar
It was originally designed to be used when you use large amounts of rear toe in. when you add shims on the rear mount of the rear arms to add toe in it widens the car out too much. To keep the car within the 190mm max width corally developed these so it stays within that limit.
Generally speaking though, when you narrow the rear end it free's up a bit.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-18-2006, 03:43 PM   #5868
-Korey
Cool. Would this be a big change? or a fine tuning adjustment?
Old 02-18-2006, 03:48 PM   #5869
More fine tuning in my opinion.
Old 02-18-2006, 04:03 PM   #5870
Merciless's Avatar
Send a message via ICQ to Merciless
Originally Posted by Electro-MAX RC
To clarify, do you want to add the spacers (~4mm) to lower the ballstud on the steering block (out toward the wheels) or the bellcranks (mechanism over the drive belts)? What does this allow the car to do again and why?
Thanks!
by the wheel i believe to reduce bumpsteer
Merciless is offline   Reply With Quote
Old 02-18-2006, 07:12 PM   #5871
-Korey
Would you happen to know the part numbers?
Old 02-18-2006, 07:15 PM   #5872
Not off the top of my head. You can do a search on corally USA's website anbd they should pop up though.
-Korey
Old 02-18-2006, 07:18 PM   #5873
Glowster21's Avatar
Trader Rating: 116 (100%+)
Hey Korey, Any luck with that new Integy 19 turn? I know this isn't the 19 turn thread but wanted to check on you anyway. Rollouts, performance, anything?
Glowster21 is offline   Reply With Quote
Old 02-18-2006, 10:32 PM   #5874
syndr0me's Avatar
Trader Rating: 32 (100%+)
corally.com has been updated with the leaflets and information about the new arms. Here's a video:
http://international.corally.com/movies/wb1.wmv
syndr0me is offline   Reply With Quote
Old 02-18-2006, 10:56 PM   #5875
Yeah it's fast. It;'s a pain to build though. you can't tighten the endbell too tight or else it warps and shorts out. I geared it at 108/38 on a 70 ft long indoor carpet track with 56.5mm tires. It can take a huge gear lol. F brushes or 767's, cavity them, and run red springs.
-Korey
Old 02-18-2006, 11:23 PM   #5876
Jeff Brown's Avatar
79263.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-19-2006, 05:42 AM   #5877
TRF415boy's Avatar
Originally Posted by LANCEisaCRACKER
so i can put the 4mm ball studs on the steering BELLCRANK, or the ball cup[s that connect to the hub carrieers to the bellcrank?
thanks
On the front hub ! If you put them under the bellcrank you will make things worse.
TRF415boy is offline   Reply With Quote
Old 02-19-2006, 06:35 AM   #5878
TRF415boy's Avatar
Originally Posted by syndr0me
At any rate, thanks for answering our concerns, Corally. You have proven yet again that your customer's faith is well-founded.
Better late than never, this arm breakage problem had been going on since the Assassin days (how long ago was the Assassin released ? 4 years or something like that ?)... Seems like someone have finally been able to have them understand the profile and not the material was the cause.
Old 02-19-2006, 08:21 AM   #5879
LANCEisaCRACKER's Avatar
ok sounds like a good idea about the bumpsteer. im gonna see if i can get them ball studs to only put on the two hubs itself. thanks
LANCEisaCRACKER is offline   Reply With Quote
Old 02-19-2006, 02:51 PM   #5880
Merciless's Avatar
Default Carpet with rubber tires help please
Hi all,
I've run the RDX twice now and must say i quite like it
First time out i used the Steve Lissamore "DMS" set-up barring the shock pistons which i don't have (he says to use "Tamiya 3") part number would be appreciated. The car felt very stable and easy to drive but i felt it was lacking Mid corner, it just wouldn't rotate quite fast enough in the very middle of the corner on a neutral throttle.
Second time out i changed things around to Chris Kerswell's "DMS" set-up again barring the Shock pistons but felt with the full 6deg of caster it was pushing on corner entry before being abit loose there after.
Anyway of the 2 i preferred Steve's set-up but need to get somemore mid corner rotation , just wonder what your idea's might be ??
I'm sure both set-up sheets can be found on Helgar racings site if you dont already have them
My idea's are thinner front shock oil, raise the inner front camber link , take off the anti dive but use 4deg caster blocks instead of 6 . one at a time of course but i'd like to know what you think i should do first ??
Also would the Tamiya pistons soften it up much (much more responsive?) ?? is there a large difference between them and the std. corally ones ??
Cheers guy
Oh. This is a great thread loads of info in it
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
