Old 02-09-2006, 05:38 PM   #5746
syndr0me's Avatar
Trader Rating: 32 (100%+)
You guys sauce out to the orange? I was told when I started to just do the inside third and never bothered to see if that's what everybody does. I'll have to try that and then turn down the dual-rate so I can get more steering through setup and less through steering throw.
syndr0me is offline   Reply With Quote
Old 02-09-2006, 06:14 PM   #5747
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
They probably told you that when you started to make the car easier to drive. Now that you're a more adept driver, go out to the orange. You'll probably have to turn the dual rate down at least 5%, probably more.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-09-2006, 07:21 PM   #5748
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Yeah, looks like XRay.
Michael Barch is offline   Reply With Quote
Old 02-09-2006, 10:03 PM   #5749
syndr0me's Avatar
Hmm, cool, I'll try that with the tires. I noticed when I turned my dual-rate up, I got more steering, but my lap times went down. I've read you should use as little steering as possible to get around the track.
Old 02-09-2006, 10:12 PM   #5750
i have try the middle hole on the front arm for the shock...and i didn t like the feel...i found the car react nervous (twitchy) and i don t have more steering at the end. so i went back to the normal set-up and my car was way better.
Pace
Pace72 is offline   Reply With Quote
Old 02-09-2006, 10:12 PM   #5751
Yes but you should always give yourself a little extra than the minimum for race situations where you might need to take non-standard lines.
USVTA Member #211
Old 02-09-2006, 10:34 PM   #5752
syndr0me's Avatar
So you guys only glue your side-walls when the traction comes way up, like a big races?
Old 02-09-2006, 10:43 PM   #5753
BlackKat's Avatar
Originally Posted by Merciless
Guys,
How do the tamiya pistons compare to the std. corally ones ?? Samller or larger holes ?? if a set-up called for tamiya 3 pistons and 50wt oil,any idea what oil i should go with if using the corally pistons ??
Thanks i'm guessing the tamiya pistons would cause less pack but thought i'd confirm
Can anyone answer this one? I'd like to know as well. If the setup calls for say, 40wt rear and 60 wt front with 1.3 pistons...What would be the equivilent with 2 or 3 hole Tamiya pistons? Just curious
BlackKat is offline   Reply With Quote
Old 02-09-2006, 10:46 PM   #5754
Korey Harbke's Avatar
Yeah, I onyl glue mine if I have too. If the car starts lifting in the corners I'll glue the sidewalls of the tires. I'll be trying the tamiya 3 hole pistons this weekend... I'll let you guys know how it works out.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-09-2006, 10:50 PM   #5755
syndrome..your right...for club race i don t think you need to glue your side wall because the grip is not high like big race...at big race we start our tire around 56mm... so where i race (club race) i start my tire at 58 because i feel that at 56mm i don t have enought traction and with the 58 my car was better (faster lap time)....but want we have our big event...i true my tire down up to 56mm and put some glue on the sidewall.
Pace
Old 02-09-2006, 11:00 PM   #5756
syndr0me's Avatar
Huh, cool, thanks for the info guys. I usually start at 58mm, but until recently I've been gluing because that's what everybody else does. It was killing the life of my tires though, because once they wore down to about 56mm the glue was catching on the carpet and tearing up the sidewalls. So I stopped gluing and found more grip. There are so many variables in this hobby when you get competitive, it's pretty overwhelming at times.
Old 02-09-2006, 11:04 PM   #5757
Rule of thumb: if you're having to glue your sidewalls for club racing, there's something wrong
USVTA Member #211
Old 02-09-2006, 11:44 PM   #5758
syndr0me's Avatar
Now, if I could just figure out why I'm faster with those silly GQ tires when everybody knows Jaco is the best. That's a good tip, no more crunchy sidewalls until I get good enough to compete at a big race, and confident nobody will beat me up for my asshattery on R/C Tech! :-D
Old 02-10-2006, 12:06 AM   #5759
Just say Parma , all together now
USVTA Member #211
Old 02-10-2006, 12:09 AM   #5760
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
