Old 01-31-2006, 09:07 PM   #5521
Jeff Brown's Avatar
Originally Posted by Customworksking
I was wondering what blocks to use when I add anti-squat I have super low blocks now do I move the front up a notch or can I use the stock block and put it in the lower hole.....what I think is,it is the same but more or less degree...any info will help thanks
Use the stock block in the lower hole. Otherwise you get too steep of an angle for the anti-squat. It is about 1.5 degrees I believe for the angle.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-31-2006, 09:15 PM   #5522
RDXracerboy's Avatar
Send a message via MSN to RDXracerboy
Originally Posted by 1fastguy1
maybe try the 2 degree rear uprights
it really plants the rear of the car.
Mo
Thanks for the reply fast guy, I'm willing to try those uprights, any chance you know what part # they are? I can't find them in the parts list at the corally site...
RDXracerboy is offline   Reply With Quote
Old 01-31-2006, 09:17 PM   #5523
FBJ- where is that indoor asphalt track????
Mike Dobbs
barnacle is offline   Reply With Quote
Old 01-31-2006, 09:19 PM   #5524
RDXracerboy- where in the corner is your car getting loose? entry, middle, exit?
Mike Dobbs
Old 01-31-2006, 09:21 PM   #5525
Exit and at the exit of hair pins, but wasn't like this with stock setup...
Old 01-31-2006, 09:27 PM   #5526
It sounds like it is an on-power situation.
The thicker oil is probably slowing down the weight transfer at exit and keeping the weight on the nose a little longer than with the 20wt oil.
Mike Dobbs
Old 01-31-2006, 09:28 PM   #5527
So should I deviate back to that stock setup for the superior this weekend? Because it really did feel much better and was similar surface...
Old 01-31-2006, 09:31 PM   #5528
Thats up to you!
The fast guys are fast because they TEST stuff to see what works.
Mike Dobbs
Old 01-31-2006, 09:34 PM   #5529
Thats up to you!
Thanks for the replies
P.S. I would like those 2 deg uprights in my box for testing, whats part #? Can't find at site...
Old 01-31-2006, 09:37 PM   #5530
Jeff Brown's Avatar
Originally Posted by RDXracerboy
When I first built my kit and I went to put in the droop screws, my integy wrenches striped them so I have no droop at the moment. (haven't had time to go to shop to get them yet but am going to put them in before race weekend) but even though it had no droop, with the stock setup of 20 wt oil all around with 17 lb springs all around, the car felt really hooked, the back in would not get loose even if i tried really! All I did was change the wt and springs, now I just got done with some more testing, nothing has changed just that I put 35 wt all around 17 lb springs in front and 14.5 lb srpings in rear, now rear is really loose and will break very easily and lose it. I know droop has a big part in why its happening, but why is it so much worst just by the oil and spring changes? Both test runs where in same place same asphalt, only other difference is the first time with stock setup I had my older CS27GL's in it, and this time I put my brand new ones on... And man was the back loose. Any suggestions besides droop?
First Rule of Asphalt: Setup is 90% Tires (Yes, I know every uses CS27 or RP30 typically)
Used tires always push, especially if they are used more than 3 runs. Which most people do. So they kind of adjust the car to that setting. Then they put on "freshies" and the car is insanely aggressive.
I think without the droop screws it will be tough to try things and the fresh tires are too aggressive. The tires were the biggest change as the oil and springs seemed fine.
Jeff
Old 01-31-2006, 09:41 PM   #5531
Jeff Brown's Avatar
Search slower..... 79296 and 79297. These will be more stable into the corners and will finish the corner better. Remember to remove the shims behind the roll blocks. Toe on the hinge pins is quite different than toe on the hubs.
Jeff
Old 01-31-2006, 09:42 PM   #5532
Jeff
Ok I get it, I know it's hard without the droop but was wondering why such difference just cause oil change, anyways I understand the wheel part, but if I shouldn't setup with fresh tires or ones with more then 3 runs, which should I setup with?
Old 01-31-2006, 09:46 PM   #5533
Jeff Brown's Avatar
I think the car with new tires is too aggressive because of the roll due to no droop screws. So when you put the screws in and adjust it, it won't be so violent of a difference.
I try to setup the car for fresh tires but that gets expensive. Its a balance for sure.
Jeff
Old 01-31-2006, 09:51 PM   #5534
Jeff
Ok thanks for the reply, I need to stop by superior to get some more set screws, I was really dissapointed with these integy wrenches I got, since the sides are just flat instead of like the corally one with pointy sides they strip my screws easily, so not using anymore.. So I'll wait till I get them and set the droop before I adjust anything eles. Thanks.
Old 01-31-2006, 11:09 PM   #5535
FBJ's RDX's Avatar
The indoor track is located in Manila, Philippines. It's dimensions are 158ft x 76ft. Hopefully Scotty (Trackside) will visit this April to race with us. He visits Manila every other year.
FBJ's RDX is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
