Old 01-31-2006, 02:31 PM   #5506
RDXracerboy's Avatar
Send a message via MSN to RDXracerboy
When I first built my kit and I went to put in the droop screws, my integy wrenches striped them so I have no droop at the moment. (haven't had time to go to shop to get them yet but am going to put them in before race weekend) but even though it had no droop, with the stock setup of 20 wt oil all around with 17 lb springs all around, the car felt really hooked, the back in would not get loose even if i tried really! All I did was change the wt and springs, now I just got done with some more testing, nothing has changed just that I put 35 wt all around 17 lb springs in front and 14.5 lb srpings in rear, now rear is really loose and will break very easily and lose it. I know droop has a big part in why its happening, but why is it so much worst just by the oil and spring changes? Both test runs where in same place same asphalt, only other difference is the first time with stock setup I had my older CS27GL's in it, and this time I put my brand new ones on... And man was the back loose. Any suggestions besides droop?
RDXracerboy is offline   Reply With Quote
Old 01-31-2006, 02:53 PM   #5507
Jeff Brown's Avatar
Originally Posted by Greg Anthony
Jeff, did you get my order out?
Rob wanted to get the bulkheads nickel plated so they did not tarnish. Should go out shortly as he was dropping them off today. When do you need it by?
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-31-2006, 02:56 PM   #5508
Holy BLING-BLING!
sweetness. need to have it in my hand Friday. Also, check your e-mail....
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 01-31-2006, 03:54 PM   #5509
Jeff Brown's Avatar
Holy BLING-BLING!
Actually I just talked to Rob and he shipped out your order today with the sample nickel plated one. You will have it by Friday. Topdeck is in there as well.
Jeff
Old 01-31-2006, 05:21 PM   #5510
Anyone have any setup suggestions on my post right above?
Old 01-31-2006, 05:51 PM   #5511
what is the difference between the new rear upright narrow and the stock one??
Pace
Pace72 is offline   Reply With Quote
Old 01-31-2006, 06:44 PM   #5512
NetDevil's Avatar
Send a message via AIM to NetDevil
I just bought me a corally. Moving from a tc4 to a corally is like moving from a honda to a ferrari. I Love It! Any suggestions on what I should do to make the car a little more stronger? I'm having problems with the hubs.
NetDevil is offline   Reply With Quote
Old 01-31-2006, 06:45 PM   #5513
highwayman's Avatar
i noticed that on most RDX set-upw, the pro's use different shock oils front and rear, why is that ?
highwayman is offline   Reply With Quote
Old 01-31-2006, 07:01 PM   #5514
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Pace,
The new upright is for when using lots of toe-in so that the car isn't too wide.
Netdevil,
Get yourself the SRC Kydex/hard foam bumper package, part # SRC1005.
highwayman,
This controls the rate at which each end of the car transfers weight side to side and front to back. The thicker oil up front keeps the car smoother (slower left to right transition, and slower transfer to the front so it doesn't load up) and slows the transfer to the rear under acceleration to free up the rear end of the car.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-31-2006, 07:07 PM   #5515
FBJ's RDX's Avatar
Default Q's for Mr. Jeff Brown
Hi Jeff, I just wanted to ask what front drive did you use for your setup posted on the Corally Site, in the Aspahlt Rubber Tire Settings? Did you use One-way or Spool? Also, what particular Body Shell and Wing for that setup? I am trying make a baseline for my setup on our new indoor asphalt track. Thank you for your time.
FBJ's RDX is offline   Reply With Quote
Old 01-31-2006, 08:03 PM   #5516
Trader Rating: 52 (100%+)
maybe try the 2 degree rear uprights
it really plants the rear of the car.
Mo
Mo Denton is offline   Reply With Quote
Old 01-31-2006, 08:14 PM   #5517
Korey Harbke's Avatar
I know Jeff is a avid spool user
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-31-2006, 08:21 PM   #5518
Customworksking's Avatar
Trader Rating: 73 (100%+)
Post rear anti-squat
I was wondering what blocks to use when I add anti-squat I have super low blocks now do I move the front up a notch or can I use the stock block and put it in the lower hole.....what I think is,it is the same but more or less degree...any info will help thanks
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-31-2006, 08:46 PM   #5519
Jeff Brown's Avatar
Spool.
Jeff
Old 01-31-2006, 08:58 PM   #5520
ok Brian..
Pace
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
