Old 01-30-2006, 09:33 PM   #5491
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Yes indeed, Sir. It's very close to the stock settings. Drive freq is from 20-40 and minimum drive is right on 40. Limit is all the way up. I don't remember the braking stuff...I just get it so that I can slam them if need be but other than that I don't care.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-30-2006, 09:50 PM   #5492
Trader Rating: 17 (100%+)
SWEET! Thanks again Brian! I must say after this Sunday's race (TQ'D, and went home before the main because it got late and our usual fast guy didn't run) I really like this car even though I keep hearing the rant and rave about the T2. Starting to get the feel of this car but want to do more changes to know what changes do what. Next step is to try the drilled shock tower versus lowered factory tower and ackerman positioning.
429racer is offline   Reply With Quote
Old 01-30-2006, 10:03 PM   #5493
Hi guy,
this past week-end i try for the first time the new low shock tower...for me it made a huge difference over the stock drilled one...i made some shock extention too just to see the differnece between the stock one ...and wow!! can t wait to have the real shock extension from SRC...my car stay flatter and have more corner speed...i have way more steering with the extension...i use the 22lbs spring...i try the 19lbs but feel a slighty push on power...so i try the 22lbs and "Voila".....the RDX is so nice!!!
Pace
Pace72 is offline   Reply With Quote
Old 01-30-2006, 10:04 PM   #5494
subman's Avatar
Originally Posted by Jeff Brown
thanks
subman is offline   Reply With Quote
Old 01-31-2006, 09:02 AM   #5495
Soviet's Avatar
Originally Posted by Pace72
Hi guy,
Pace
Extension??? What may i ask are you talking about??? Interested party here.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 01-31-2006, 10:09 AM   #5496
stiltskin's Avatar
Trader Rating: 102 (100%+)
On your rear a-arms, you have a shock extension that moves the lower joint closer to the tire. SRC has made some that are even longer. I guess length is important.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-31-2006, 10:14 AM   #5497
Soviet's Avatar
metal ones??? I have them on the arms.
-Me
Old 01-31-2006, 10:48 AM   #5498
Jeff Brown's Avatar
They are LONGER.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-31-2006, 11:23 AM   #5499
koabich's Avatar
Send a message via Yahoo to koabich
There is a new version that are longer to help lay down the shocks a little more. The drivers using them are dropping down in spring weight with them as well.
koabich is offline   Reply With Quote
Old 01-31-2006, 11:25 AM   #5500
It's not really to lay down the shocks, more to just move the bottom shock mounting location further out to give the shock more leverage over the arm. This will give less overall chassis roll. To get back some of the traction lost by going out futher, we have been running softer springs---19lbs.
USVTA Member #211
Old 01-31-2006, 11:47 AM   #5501
Trader Rating: 18 (100%+)
Is this working on Carpet or is this for Asphalt? When will there be a new part number for us to have our LHS order for us? (or direct order...)
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-31-2006, 01:06 PM   #5502
This is for carpet, foam tire.
As for part #....
Jeff?
USVTA Member #211
Old 01-31-2006, 01:37 PM   #5503
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking #
B nice to get a set
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-31-2006, 02:22 PM   #5504
Jeff Brown's Avatar
SRC79248 is the part number. Just slammed here trying to leave for Snowbirds. Website is behind a bit.
79264 ball studs are required. You must use a camber link ball end on the shock shaft as well otherwise the shock hits the tire. We shave off all foam on the insides of the rear tires as well to make sure it clears.
Jeff
Old 01-31-2006, 02:29 PM   #5505
Jeff, did you get my order out?
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
