Old 01-24-2006, 11:21 AM   #5311
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
It's certainly possible if they don't provide enough pressure against the bolt to hold its setting.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-24-2006, 11:24 AM   #5312
syndr0me's Avatar
Trader Rating: 32 (100%+)
Cool, I'll mess with that tonight. I don't have a manual handy, so for a sanity check, washers go: ()(), right?
syndr0me is offline   Reply With Quote
Old 01-24-2006, 11:31 AM   #5313
Correct...or if you have your arm blocks spaced out more than the stock 1 mm, you can use 6 washers and it'll also be more responsive to small changes in adjustment.
USVTA Member #211
Old 01-24-2006, 01:57 PM   #5314
Customworksking's Avatar
Trader Rating: 73 (100%+)
Talking race
Originally Posted by GMSchmidt
CustomWorksKing - Sorry I missed your post a while back.
Yea - I've been meaning to make it up to Springfield and race with you guys. Right now I've got all that I can handle down here in St Louis. Scott Lucas told me about your track. He has been racing up there with you guys I believe. We've usually got some great racing down here with Drew Ellis , Skip Starkey, Jimmy Piersol, Larry Stone, Steve Smith, etc... It's actually an accomplishment to make the A and perform well. Fortunately, my Corally is doing well against all the non-factory XRay's.
We've got a big race this weekend (Memorial race) with factory support (a bunch of Drew's sponsors) and plenty of door prices. Check out our thread. Hope you can make it down here some time (if you guys want to race this weekend - come on down, it's a 2 day race).
http://www.rctech.net/forum/showthread.php?t=94716
This weekend I'll be trying out the 6 degree hub carriers and 4.0mm chassis.
Greg
I'm on it I will see what I can do ...Going to look in the post now to see what's up.......I been helping Scott He's getting better thanks Kevin
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-24-2006, 02:11 PM   #5315
Glowster21's Avatar
Trader Rating: 116 (100%+)
Has anyone mounted the new Motor Guard on one of the older chassis yet? I have 2 cars, 1 with the 4mm chassis and one with the 2.9mm and I don't want to kill the chassis. Is there a certain drill bit/countersink that anyone recommends? How about measurements for where to drill?
Thanks!
Glowster21 is offline   Reply With Quote
Old 01-24-2006, 02:18 PM   #5316
Mission_carbon's Avatar
Originally Posted by Sushi Boy
Sure thing, I think some of the fastest cars on the track in the rubber classes were RDX's. I'll make sure to grab the setup for you and post it here. This was a a very high traction event, so it might be a little bit different than yoru track.
-Korey
Thanks Korey. The track i run at has high traction so its all gravy baby.
Thanks again,
Wills
Mission_carbon is offline   Reply With Quote
Old 01-24-2006, 08:44 PM   #5317
Jeff Brown's Avatar
Originally Posted by syndr0me
Oooh, would that cause it to back out you think? Last time I built it, they did look a little flatter than usual. I think I've got some new ones I can throw in there.
There are reasons they come in a "Diff Rebuild Kit".
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-24-2006, 11:57 PM   #5318
syndr0me's Avatar
Jeff
Yea, I totally deserved that. :-D
I inexplicably stripped out a post that the battery strap tightens down on during a nasty wreck. That's the first time I've damaged one of those, and I don't tighten them very much at all to avoid tweak. I guess that's a decent spare to add to the collection.
Old 01-25-2006, 12:00 AM   #5319
syndr0me's Avatar
Hey Jeff, Tell the Corally guys if they make a new pit towel in the color scheme of the new header cards (grey, red) I'll buy two. Something that doesn't snag so much would be cool too.
Obviously I don't expect them to produce towels just for me, but if they're considering doing some in that new color scheme, it would be hot.
Old 01-25-2006, 12:24 AM   #5320
syndr0me's Avatar
Okay, last question. Do wheel hexes from any other manufacturer have the same dimensions as those from the RDX?
Old 01-25-2006, 04:55 AM   #5321
Glowster21's Avatar
Thanks!
Anyone have any words of wisdom on the motor guard?? Hey Jeff...Dave at Speedzone in CT is a great guy and is moving Corally product like you wouldn't believe. Turned him into a believer and I think Corally will push "Brand X" to the side in his shop now!
Old 01-25-2006, 08:45 AM   #5322
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
I have used some Tamiya ones in a pinch, but you have to shim them a bit, as they are thinner between the pin and bearing... creates a little slack. on the plus side, they offer 4, 5, and 6mm wides...
i get those tight spots in a couple of my diffs, too... never thought of the clip, tho! ill be calling ya shortly, Jeff.....
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-25-2006, 08:52 AM   #5323
Jeff Brown's Avatar
Well, the screws are 3mm so 1/8" might be a bit big. I have not put one on so I dont know how it fastens down. If the screw goes through and into a nut then a 1/8" should be fine. 3mm would be tighter though so it doesn't shift.
Jeff
Old 01-25-2006, 09:20 AM   #5324
Trader Rating: 18 (100%+)
Jeff,
Are the diff circlips available seperately? If so what part number?
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 01-25-2006, 09:52 AM   #5325
Can someone tell me what the difference is between the UK and Us Carpet Spec version?
Cameron is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
