Old 01-23-2006, 10:39 PM   #5296
Customworksking's Avatar
Trader Rating: 73 (100%+)
Lightbulb PUSH
I been working on a push for weeks now and I got it dialed by freeing up the rear 1.5deg toe,short flat camber links and making camber changes as needed also use Glue to work the car "side walls" 2.5 to 3mm of uptravel ....Ft longer camber links more angle less up travel 1.5 to 2mm no glue AND the KEY thing is TOE .5 deg toe IN and wow the cas was fast!!!! put 2 laps on the field 19t
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is online now   Reply With Quote
Old 01-23-2006, 10:41 PM   #5297
Korey Harbke's Avatar
Originally Posted by JRX-S Bill
Korey,
Do you have the 4mm chassis?
Sure do
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-23-2006, 11:57 PM   #5298
nhra6849's Avatar
Trader Rating: 33 (97%+)
Send a message via AIM to nhra6849
Default RDX
Korey, check your PM
nhra6849 is offline   Reply With Quote
Old 01-24-2006, 12:32 AM   #5299
syndr0me's Avatar
Trader Rating: 32 (100%+)
Do you guys find yourselves needing to tighten your front diff frequently? Mine seems to back off a bit every few races. It got better for a while after I replaced the diff half with the tab in it, but it seems to be happening again. The rear diff never has this trouble.
I guess I should ask for a few of those tabs on my next order.
syndr0me is offline   Reply With Quote
Old 01-24-2006, 02:23 AM   #5300
Mission_carbon's Avatar
Sushi Boy:
Do you know where i could get a 27Stock Rubber Set-up from this race? did you have any buddies in this race who had a RDX?
Thanks,
Wills
Mission_carbon is offline   Reply With Quote
Old 01-24-2006, 02:49 AM   #5301
ooliganRC's Avatar
Send a message via MSN to ooliganRC
check the helger-racing site, it has a corally section and has steve lissamores and chris kerswells 19t setup on it, found them a very good place to start
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 01-24-2006, 03:24 AM   #5302
Thanks for that Mi2Dude
Wills
Old 01-24-2006, 08:09 AM   #5303
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
syndr0me, You may need to replace your diff bolt...as the problems you are having usually start on the old diff bolts before they break.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-24-2006, 08:30 AM   #5304
alb
Trader Rating: 19 (100%+)
I was just going to say the same thing. It happened to me last week!
alb is offline   Reply With Quote
Old 01-24-2006, 08:34 AM   #5305
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by syndr0me
Are the arms with no number on them soft? The others are marked with 50 and 75, right? I put whatever came with the original UK kit on the front and I haven't had nearly the trouble with breakage.
I ran 6 packs through the car tonight (in practice) and didn't break a thing. I didn't hit much either, aside from taking a few turns too tight, but front impacts just disappear into the wonderful bumper. We'll see how things go tomorrow night during club racing, but so far, I've had much better luck with the softer arms up front.
What do you guys do about replacing bearings? Do you just buy more Corally bearings? I bought a ceramic kit from ACER, and they didn't hold up well at all. All the bearings in the outside of the hubs died after a couple of months, and the larger bearings the diffs ride on are starting to suffer as well. I had much better luck with the stock bearings. I cleaned and oiled both religiously, but those damn ceramics, while smooth, are terribly delicate. I'm probably due for another set to replace those suffering and have a few spares on hand.
I use the stock Corally Bearings except I get the Much More Racing wheel axel bearings only because I get them cheaper...I do have the Speedtech ceramics and only have the diff outdrive and layshaft bearing left in one of my RDX's as like you said the wheel axel bearings wear out in a hurry. Not had a problem with the Diff or layshaft bearings being Ceramic. I find the stock bearings in my other RDX are just as smooth as my Ceramics its just that the Ceramics last longer.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-24-2006, 08:51 AM   #5306
Wills
Sure thing, I think some of the fastest cars on the track in the rubber classes were RDX's. I'll make sure to grab the setup for you and post it here. This was a a very high traction event, so it might be a little bit different than yoru track.
-Korey
Old 01-24-2006, 09:45 AM   #5307
GMSchmidt's Avatar
CustomWorksKing - Sorry I missed your post a while back.
Yea - I've been meaning to make it up to Springfield and race with you guys. Right now I've got all that I can handle down here in St Louis. Scott Lucas told me about your track. He has been racing up there with you guys I believe. We've usually got some great racing down here with Drew Ellis , Skip Starkey, Jimmy Piersol, Larry Stone, Steve Smith, etc... It's actually an accomplishment to make the A and perform well. Fortunately, my Corally is doing well against all the non-factory XRay's.
We've got a big race this weekend (Memorial race) with factory support (a bunch of Drew's sponsors) and plenty of door prices. Check out our thread. Hope you can make it down here some time (if you guys want to race this weekend - come on down, it's a 2 day race).
http://www.rctech.net/forum/showthread.php?t=94716
This weekend I'll be trying out the 6 degree hub carriers and 4.0mm chassis.
Greg
GMSchmidt is offline   Reply With Quote
Old 01-24-2006, 11:16 AM   #5308
syndr0me's Avatar
Dang, I'm using the new bolts in both diffs. I haven't heard about the new bolts failing, so hopefully it's not -that-. :-(
Thanks for the bearing info. Glad to know I'm not the only one that blazed through expensive ceramics. Le sigh.
Old 01-24-2006, 11:18 AM   #5309
It's either that or you might have collapsed washers behind the bolt...that's all I can think of.
USVTA Member #211
Old 01-24-2006, 11:19 AM   #5310
syndr0me's Avatar
Oooh, would that cause it to back out you think? Last time I built it, they did look a little flatter than usual. I think I've got some new ones I can throw in there.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
