Team Corally RDX Touring Car >
Old 01-15-2006, 04:41 PM
  #5131
Number 11's Avatar
Guys drivers come and go move on. I love the RDX what an awesome car after years of battling with my previous car. I get a RDX and it is like a different driver is behind the wheel.
Number 11 is offline
Old 01-15-2006, 04:43 PM
  #5132
Korey Harbke's Avatar
I saw you were laying it down, good job man.
Korey Harbke is offline
Old 01-15-2006, 04:48 PM
  #5133
Number 11's Avatar
Thanks Korey. Yeah I hit 30 laps Friday almost got Chris P if we had a few more seconds I might of been able to find a way past him. I couldn't be more happier with the car so smooth, quiet and stable. I also got the EA motor working and it was fast.
Old 01-15-2006, 04:52 PM
  #5134
Cool beans
Old 01-15-2006, 07:04 PM
  #5135
you guys are amazing, There was no hacking between me and dan. I followed behind him for 3 minutes had plenty of time to hit him and i backed off. I waited for teh right time that i thought to make the pass. I talked to dan after teh race and he even said i didnt hack him. If you guys dont know the whole story dont write it. Also u didnt hear me after the north carolina race saying that dan hit me and he didnt wait in the main. Passes are made and some time there is contact. There was contact, so small that dan got right back on my bumper. Tust me guys i dont race dirty and never will. So once again get your facts straight before you start bashing people on the net.
Jeff Cuffs
Jeff Cuffs is offline
Old 01-15-2006, 07:08 PM
  #5136
P-DUB's Avatar
Congrats on the new ride Jeff...Now update that signature
P-DUB is offline
Old 01-15-2006, 07:41 PM
  #5137
Customworksking's Avatar
Trader Rating: 74 (100%+)
Post rdx
hello all ran the RDX again today still a bit pushy but I dont have my new tires yet the 1s I have now are glued on the side walls so I'm sure it would help if they were not glued......Does parma and Jaco have a shoe chart I can print...whats the best combo for 19 and stock foam dbl pink,dbl pink orange? thanks
Customworksking is offline
Old 01-15-2006, 07:49 PM
  #5138
Still pushy? Where in the corner is it feeling pushy, probably post your current setup again as well. I run the Jaco Double pink/oranges up front and the dbl pinks in the rear. I've also been running Speedmind Tires alot, and parma's off an on as well.
-Korey
Old 01-15-2006, 07:53 PM
  #5139
Originally Posted by Jeff Cuffs
you guys are amazing, There was no hacking between me and dan. I followed behind him for 3 minutes had plenty of time to hit him and i backed off. I waited for teh right time that i thought to make the pass. I talked to dan after teh race and he even said i didnt hack him. If you guys dont know the whole story dont write it. Also u didnt hear me after the north carolina race saying that dan hit me and he didnt wait in the main. Passes are made and some time there is contact. There was contact, so small that dan got right back on my bumper. Tust me guys i dont race dirty and never will. So once again get your facts straight before you start bashing people on the net.Jeff Cuffs
Ok, first off, there was no hack or anything of that sort. There were certain places on the track where our cars were better than each others, his happened to be off the sweeper and there was a lil contact, its almost impossible to make a complely clean pass on someone, unless they complely blow a line. Our driving lines were dfferent in that section, and he took advantage of it, oh well, it happens. And at last, Jeff and I are buds, theres no hard feelings between us, racing is racing, thats why we do it.
Dhartman03 is offline
Old 01-15-2006, 08:09 PM
  #5140
Lightbulb set
-Korey
OK FT no toe,camber 1.5 to 1 tried .5,camber link bottom row 2nd hole in,shocks 3rd hole in AE copper spring,shock oil 45 wt 2hole tamiya,3rd hole out on arm 2mm uptravel,wheel base short,width 2mm shim both sides,4deg caster blocks,4mm ride H ,diff..rear 1.5 camber,1.5deg toe,45wt oil 2hole tamiya ,AE blue,camber link middle hole on hud carrier,top row 1st hole on tower,shocks 1st hole on tower,3rd hole on arm 2.5 to 3mm uptravel,wheel base long or all clips in ft of arm 3.9mm chassis
Old 01-15-2006, 08:38 PM
  #5141
Looks a little soft to me. Right now I'm running 33 lbs fronts and 26 lbs rears. If you want to stick with AE springs, maybe try something like purples in the front, and copper in the rear.
-Korey
Old 01-15-2006, 08:51 PM
  #5142
Jeff Brown's Avatar
Jeff Cuffs
What up Jeff. Hope the new ride treats you alright. Like someone else said, drivers come and go. Whether people decide a new car is better, or it helps them stay motivated it does not matter. Everyone makes a decision for themselves and others will always give heat for it. What can you do yanno.
See you at the birds.
Jeff
Jeff Brown is offline
Old 01-15-2006, 09:14 PM
  #5143
RCFREAK's Avatar
Trader Rating: 18 (100%+)
i was there... finished in the same main with Cuffs and Hartman... there was no real talk about anyone HACKING!! This was a race for position and it was enough room for Cuffs.. to just get by with a little of rubbing.. especially at the end of a sweeper!!! did not really effect Dan.. he was still on his bumper!! If he "peeled" him... i know Cuffs would have waited... nothing of that sort was needed and intended..
Both Racers are top notch!! PLEASE DONT CAUSE ANY ISSUES BETWEEN THESE LEVEL DRIVERS!! they are good friends!!
GOOD LUCK CUFFKINSKI!! will be chatting with ya soon!! you guys and the TEAM BUTTER crew make racing a blast and well worth it!! outtacontrol you guys are!!!
arv.
RCFREAK is offline
Old 01-15-2006, 09:32 PM
  #5144
Still Bill's Avatar
Hey Matt.
Still Bill is offline
Old 01-16-2006, 05:15 AM
  #5145
morris's Avatar
Trader Rating: 44 (100%+)
Originally Posted by JRX-S Bill
Hey Matt.
which matt are you hey to?
morris is offline
