Old 01-13-2006, 09:39 AM   #5071
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by Jeff Brown
Everything on the internet must be true, it has to be.
Jeff
Sorry bro...just trying to get confirmation....seems rumors are stretched even further now adays...LOL
Thanks for the clarification...
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-13-2006, 09:42 AM   #5072
Actually when you cut the shock shafts and eyelets you can still use the stock perches. I believe Toso has the stock ones on his car.
Jeff
Sweet I knew You guys would get it figured....Now back to 100% COrally....LOL
-Shookie <><
Maybe a measurement of how much to remove?
Old 01-13-2006, 09:48 AM   #5073
stiltskin's Avatar
Trader Rating: 102 (100%+)
What is the design purpose of the lowered shock tower? Is it just to run slammed bodies or does it actually affect the handling of the car? I'm talking about the ones at Specialized RC with original camber mounts. It seems to me that if you lower the tower and then cut the bottom of the shock shaft and eyelet, you haven't really adjusted where the piston rides in the fluid.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-13-2006, 10:17 AM   #5074
Yeah to slam body height.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 01-13-2006, 10:53 AM   #5075
Jeff Brown's Avatar
-Shookie <><
Well, the lowered tower is 3mm lower. So I would trim that off the shaft. That is what I did along with cutting the eyelet pretty much the same or a tick less.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-13-2006, 10:55 AM   #5076
Jeff Brown's Avatar
Well, cutting the shock shaft and eyelet allows the piston to ride back in the original position. We are not trying to have it ride in a different location. Since the tower is 3mm lower, the shock needs to be essentially 3mm shorter to maintain the proper fuction of the dampening. If you follow me.
Jeff
Old 01-13-2006, 11:13 AM   #5077
stiltskin's Avatar
Jeff
I gotcha. So it's just for lowered bodies and a slightly lower cg. Thanks.
Tony Rumple
Old 01-13-2006, 01:13 PM   #5078
Pezz's Avatar
Send a message via Yahoo to Pezz
Quick question about the roll center blocks. I have the small dots on the side of the roll centers facing down in the lower holes. I want the roll centers set more at the nuetral position, so that would be the lower hole with the small dots facing up?
Any help would be great.
-B
Pezz is offline   Reply With Quote
Old 01-13-2006, 01:54 PM   #5079
Mission_carbon's Avatar
Two things,
One used these ball ends
http://www.speedtechrc.com/store/ebp...id=236&id=2079
and these perches and you will have them slamed as low as you can go...
http://www.speedtechrc.com/store/ebp...nid=241&id=908
Also every type of spring size has fit on those perches...
I run HPI R40 and PRO4 springs as well as Corally...They all fit..I have fit Tamiya springs as well...
Two,
Why the heck did Corally USA let Cuffs go?
He won at will and had one dialed car...
-Shookie <><
Thanks for this info Shookie my friends have all got HPI and Tamiya springs but none Corally so ill get these orderd and bump there springs.
Thanks Buddy
Big Will
Mission_carbon is offline   Reply With Quote
Old 01-13-2006, 02:08 PM   #5080
koabich's Avatar
Send a message via Yahoo to koabich
Jeff,
Can you tell us the deal on what's really going on with Jeff Cuffs?
Thanks in advance
koabich is offline   Reply With Quote
Old 01-13-2006, 03:52 PM   #5081
Korey Harbke's Avatar
-B
When you say a more "neutral position" do you mean the arms more level? It's been a while since I've run on rubber tires, but if you want to raise the hinge pins a touch just flip the blocks around, so the dot is pointing up. That should give you a little more turn in, and a little less grip in the middle and exit of the corner.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-13-2006, 04:13 PM   #5082
Customworksking's Avatar
Trader Rating: 73 (100%+)
Wink where
Two things,
Two,
-Shookie <><
^^^^^^^^^^^these here^^^^^^^^
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-13-2006, 04:15 PM   #5083
Arrow rdx
I heard corally is coming out with a upgrade kit somewhat like the 415 is this true.?.also what chassis is better for 19t foam 3.9 or 2.9 any help will do
Old 01-13-2006, 04:27 PM   #5084
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
on foams, the 3.9 is the definite choice, from what i hear. on high grip especially, you can see the difference in laptimes... more consistant.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-13-2006, 04:27 PM   #5085
stegger's Avatar
Where did you here this fella, i hope it's true split bulkheads would be a god send to a car already built by the man himself
stegger is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
