Old 01-12-2006, 08:49 PM   #5056
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Thanks Mike
Great job winning Sportsman at the Novak!!
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-12-2006, 09:04 PM   #5057
ebone's Avatar
true where i race in lynnwood washington there ia a corally guy. korey aka sushi boy, one of the most helpful guys you will ever meet.
ebone is offline   Reply With Quote
Old 01-12-2006, 09:07 PM   #5058
Still Bill's Avatar
We don't need to go to Lynnwood, Korey posts here all the time...Very helpful.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-12-2006, 09:35 PM   #5059
Customworksking's Avatar
Trader Rating: 73 (100%+)
Red face push
Onpower push 19t foam pink rear dbl pink orange FT I know without my setup u cant say where to start but can U tell me a few things to do other less uptravel/more droop please
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 01-12-2006, 09:53 PM   #5060
Jeff Brown's Avatar
Sure....... Lean the front shocks in one hole. Lengthen the front camber link. Drop 10wt on the oil in the front. Drop a spring rate in the front. Add caster. Try pro-squat in the rear. Less rear toe-in. Hope this helps.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-12-2006, 11:02 PM   #5061
Arrow rdx
Thanks Jeff , I was going the right direction I did have 2deg caster So, I'm sure 4 will help love the car 1st time I ever drove a car on foam after 4yrs of stock rubber .....Like to thank Chris Tosolini for all the Help at the Novak race!
Old 01-13-2006, 06:02 AM   #5062
morris's Avatar
Trader Rating: 40 (100%+)
Default rubber tires
that was a stupid question.i figured that foams would be more agressive.
i thought there would be some close to comparisent.
thx,
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-13-2006, 07:07 AM   #5063
GMSchmidt's Avatar
Jeff Brown - thanks for the help with the RDX on the phone yesterday.
I did the shock changes you recommeded while running the lowered towers. It definitely will help the pistons run lower in the shock body. One other question though:
I've been running TC4 spring perches so I can run the right ride height with carpet (usually 4-5mm). Is this the best option currently? Or is there a different perch I should try? Or is there one coming from Corally?
Thanks again.
Greg Schmidt
St Louis, MO
GMSchmidt is offline   Reply With Quote
Old 01-13-2006, 07:16 AM   #5064
koabich's Avatar
Send a message via Yahoo to koabich
Thanks again.
Greg Schmidt
St Louis, MO
I have heard you could run Xray perches but I haven't tried tham as they were too expensive. You have to buy the shock bodies and caps and everything else with them.
I have tried the Tamiya and if you are using Corally Springs, they won't work as the Corally springs are too big in diameter and the spring goes right over the perch. I have been running the Associated and have had no problems...they work perfect!
koabich is offline   Reply With Quote
Old 01-13-2006, 09:04 AM   #5065
Korey Harbke's Avatar
Custom- I tend to prefer 4 -6 deg of caster. 2 deg always felt alright, but 4 and 6 deg fo caster always let the front of the car bite a little harder in the middle and exit of the corner. It lets the car finish off the turn much better.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-13-2006, 09:10 AM   #5066
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Two things,
One used these ball ends
http://www.speedtechrc.com/store/ebp...id=236&id=2079
and these perches and you will have them slamed as low as you can go...
http://www.speedtechrc.com/store/ebp...nid=241&id=908
Also every type of spring size has fit on those perches...
I run HPI R40 and PRO4 springs as well as Corally...They all fit..I have fit Tamiya springs as well...
Two,
Why the heck did Corally USA let Cuffs go?
He won at will and had one dialed car...
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-13-2006, 09:24 AM   #5067
Post ball ends
Shookie where r u useing the ballends U posted??
Old 01-13-2006, 09:37 AM   #5068
WHere????
which possition?
-Shookie <><
Old 01-13-2006, 09:38 AM   #5069
Jeff Brown's Avatar
Originally Posted by Mr. Shookie
Two,
-Shookie <><
Everything on the internet must be true, it has to be.
Jeff
Old 01-13-2006, 09:39 AM   #5070
Jeff Brown's Avatar
Thanks again.
Greg Schmidt
St Louis, MO
Actually when you cut the shock shafts and eyelets you can still use the stock perches. I believe Toso has the stock ones on his car.
Jeff
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
