Old 01-08-2006, 08:53 AM   #4996
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Originally Posted by Mission_carbon
Hi Guys come back ealry after one heat of carpet thrashnal with a broken diff screw and no 1 had any spares not happy.
Has any one got any RDX spares they want to sell like hubs wishbones diff bolts Black spring set, Sliver spring set maybe even a spool one-way.
Please PM with what you got.
Also what would be the best to run on carpet?
Spool, One-Way, Diff
Thanks,
Will
Diff's front and rear
-Eric
EricO3 is offline   Reply With Quote
Old 01-08-2006, 09:03 AM   #4997
FBJ's RDX's Avatar
Originally Posted by Mr. Shookie
If you run the spool do yourselfa favor and get the steel cvds and the metal blades...You will thank me after about 2 runs with the plastic blades...
Spools tear those plastic blades to bits then you have a metal to metal conflict and we already know what the outcome is...LOL
If you setup your spool right it is nasty agressive....My D rate is set to 72%....
Remember you want your cvds strait out from the spool.
Ok My two pennies....
-Shookie <><
Hi Shookie, where can I get those steel CVDs and Metal Blades? Thanks
Sonny
FBJ's RDX is offline   Reply With Quote
Old 01-08-2006, 09:08 AM   #4998
Mission_carbon's Avatar
-Eric
Thanks,
Also what Oil should i be running im using 40 Front 30 back got some over steer problems moved the shocks up a hole? any other ideas
Mission_carbon is offline   Reply With Quote
Old 01-08-2006, 11:14 AM   #4999
Pezz's Avatar
Send a message via Yahoo to Pezz
Sonny
I'm not shookie, but you can buy them here
Or order them from your LHS.
-B
Pezz is offline   Reply With Quote
Old 01-08-2006, 06:06 PM   #5000
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
i have the rubberneck bumper on. i break arms frequlently. would the brp tc3 wide bumper help at all? im limited money . would this save arms at al? thx
Z.Hallett is offline   Reply With Quote
Old 01-08-2006, 06:27 PM   #5001
EricO3's Avatar
Thanks,
Are you running the 1.3mm pistons front and rear? If so, i'd try 60/40 with 33lbs springs in front and 26lbs spings on the rear (silver spring set)
-Eric
Old 01-08-2006, 06:30 PM   #5002
Yes. Specialized RC has a pre-cut bumper you should use.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 01-08-2006, 06:56 PM   #5003
Still Bill's Avatar
Default RDX
A modified BRP TC3 or Specialized RDX bumper (both Kevlar) will help save the front end arms. I have not broken one yet.
To save the rear arms, consider using softer plastic arms on that end of the car...Not the "hard" or "extra hard" arms...too brittle. The soft ones cost less too.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-08-2006, 09:17 PM   #5004
Jeff Brown's Avatar
Well...... RDX seemed to fair well up in Wisconsin. TQ by Jim Herrmann and overall win by Jeff Dayger. Back to back wins for Jeff. Nice! I believe there were 7 RDX cars in the Stock A-main.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 01-08-2006, 09:24 PM   #5005
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Tosolini was up around 2nd/3rd till he got knocked into the boards...
XMSRacing is offline   Reply With Quote
Old 01-09-2006, 09:52 AM   #5006
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
****EDIT****
Mr. Shookie is offline   Reply With Quote
Old 01-10-2006, 07:23 AM   #5007
Glowster21's Avatar
Trader Rating: 116 (100%+)
Originally Posted by Jeff Brown
Yes, the pistons are still available. They just put the 1.3mm ones in since everyone was switching to them. How high bite of track are you running? I ran today and went down to 30lb springs in the front and it was way better. I thought about trying the 26lb. Perhaps also try less droop in the front, unless you are already running about 1-2mm up travel.
The excess off power is usually due to droop and weight transfer.
Jeff
Jeff
I am having a similar problem...Tons of off power steering but having a hard time getting the car to dive into the corners. Running 1.3 mm pistons, 30lb front springs with 60wt, 26lb rears with 40wt, 2 mm droop front 2.5mm rear, ultra low roll blocks, shortest possible camber links, 1 shim under each front coupler. I read that increasing the number of shims will help with steering...Is that true? Also, this sounds like a strange question, but when you say less droop do you mean to tighten or loosen the droop screws? Having a brain cramp....High traction on foams...
Glowster21 is offline   Reply With Quote
Old 01-10-2006, 10:20 AM   #5008
Jeff Brown's Avatar
Originally Posted by Glowster21
Jeff
Longer camber links will smooth out the car. Remove some droop from the rear end. Adding more shims will make the car wider and more stable. It will prevent it from dumping a bit as well, which you may be experiencing. Perhaps try dropping the rear springs down to 22lb as well so the rear rolls a bit more.
Less droop means tighten the screw, so you have less up travel.
Jeff
Old 01-10-2006, 10:22 AM   #5009
Korey Harbke's Avatar
Well diving into the corner, to me is like off power/entry steering. Generally when Jeff talks about droop, it's how far the car lifts up over ride height. So when he mentions "less droop" he means to tighten the droop screws a bit.
If you are having issues having the car feeling a little dead on power I generally tighten the front droop screws a touch. It keeps weight from transfering to the rear of the car, resulting in more on power steering.
On another note, if you guys are having problems getting the front end to hook up entering the corner give the new lower shock tower a try. The upper row of camber link adjustment is the same as the standard tower, so it is one row higher than our "hand made" lower towers. This will give you better turn in, and keeps the front end from dumping over. Made a world of difference in my car.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-10-2006, 10:23 AM   #5010
blah I was too slow.....
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
