Team Corally RDX Touring Car >
Old 01-07-2006, 04:59 AM
  #4981
Fervidsea's Avatar
What do I need to purchase to run a front spool in the RDX?
Fervidsea is offline
Old 01-07-2006, 05:20 AM
  #4982
stiltskin's Avatar
Trader Rating: 103 (100%+)
A spool for the RDX.
stiltskin is offline
Old 01-07-2006, 05:34 AM
  #4983
Fervidsea's Avatar
Sorry let me be more specific. I purchased the rc specilized front spool for the rdx but it doesnt have the pully attached. Am I missing something? Do I also have to purchase the pully as well? I currently have twin Diffs.
Old 01-07-2006, 07:19 AM
  #4984
FBJ's RDX's Avatar
You need the diff pulley, part #79171. Also, i suggest get extra driveshaft caps, part #79189, it easily wears out when running a spool. I hope this helps.
FBJ's RDX is offline
Old 01-07-2006, 07:34 AM
  #4985
Fervidsea's Avatar
Thank you
Old 01-07-2006, 09:20 AM
  #4986
Mr. Shookie's Avatar
If you run the spool do yourselfa favor and get the steel cvds and the metal blades...You will thank me after about 2 runs with the plastic blades...
Spools tear those plastic blades to bits then you have a metal to metal conflict and we already know what the outcome is...LOL
If you setup your spool right it is nasty agressive....My D rate is set to 72%....
Remember you want your cvds strait out from the spool.
Ok My two pennies....
-Shookie <><
Mr. Shookie is offline
Old 01-07-2006, 11:24 AM
  #4987
Still Bill's Avatar
Could someone detail the part names and numbers of the items needed to create a spool in my RDX?
Just want to make sure I got it right. Many thanks.
Still Bill is offline
Old 01-07-2006, 03:57 PM
  #4988
Here you go...
http://www.speedtechrc.com/store/ebp...id=439&id=4940
http://www.speedtechrc.com/store/ebp...id=441&id=4923
http://www.speedtechrc.com/store/ebp...id=443&id=5108
And these are what I would upgrade on the front end if you do use a spool....
http://www.speedtechrc.com/store/ebp...id=443&id=5347
http://www.speedtechrc.com/store/ebp...id=443&id=5228
Hope that helps,
-Shookie <><
If you are running a one way you will need the bearing holders and bearings for a diff to run a spool.....But I am assuming you already have those...
Old 01-07-2006, 05:05 PM
  #4989
Superfly1967's Avatar
Could someone give me a part number for the motor guard piece. I have bent my brush tab twice from getting t-boned. I would like the motor guard piece as I believe it should stop this from happening.
Thanks in advance.
Superfly1967 is offline
Old 01-07-2006, 07:13 PM
  #4990
Jeff Brown's Avatar
Thanks in advance.
It is not available yet.
Jeff
Jeff Brown is offline
Old 01-07-2006, 07:18 PM
  #4991
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Question for Jeff B
Jeff,
Are the .9 piston still available? I purchased a new rdx with the 1.3 pistons and I sold my old one...however I have really been struggling with setting on the car...I can only figure it is the difference in pistons.
I have tried toso setup and cuffs setup listed on the website and the car has an on power push(high speed sweeper type of turns) and tons of off power steering.
I have tried changing the damping but I my car seemed to work much better with the .9 pistons with 40 front and 30 rear oil...any other suggestions other than the pistons...caster and rear toe in adjustment have not really solved the problem.
Thanks Jamie
J.Gonzalez is offline
Old 01-07-2006, 07:37 PM
  #4992
Jeff Brown's Avatar
Originally Posted by senna555
Jeff,
Thanks Jamie
Yes, the pistons are still available. They just put the 1.3mm ones in since everyone was switching to them. How high bite of track are you running? I ran today and went down to 30lb springs in the front and it was way better. I thought about trying the 26lb. Perhaps also try less droop in the front, unless you are already running about 1-2mm up travel.
The excess off power is usually due to droop and weight transfer.
Jeff
Old 01-07-2006, 07:44 PM
  #4993
J.Gonzalez's Avatar
Default Jeff b follow up
The track is med grip. As the track grooves up the car tends to improve as far as onpower steering goes. I been running 30-33 front springs and 24 rears. I have about 2mm of droop in the front.
I will try reducing the droop in the front.
What shock oil would you suggest for the 1.3 pistons if I am trying match 40/30 with the .9 pistons...I have been running 60/50 with the 1.3 pistons
I will give you guys all call on monday to order the pistons.
Jamie
Old 01-07-2006, 07:53 PM
  #4994
Jeff Brown's Avatar
Jamie
Well, probably either 60/50 or 70/60 to equal the same you were using. I would also recommend trying 22lb or even 19lb springs on the rear. I know, its weird, but it helps carve the corner.
Jeff
Old 01-08-2006, 04:48 AM
  #4995
Mission_carbon's Avatar
Hi Guys come back ealry after one heat of carpet thrashnal with a broken diff screw and no 1 had any spares not happy.
Has any one got any RDX spares they want to sell like hubs wishbones diff bolts Black spring set, Sliver spring set maybe even a spool one-way.
Please PM with what you got.
Also what would be the best to run on carpet?
Spool, One-Way, Diff
Thanks,
Will
Mission_carbon is offline
