Old 12-31-2005, 02:23 PM   #4906
Originally Posted by Superfly1967
What is the internal tranmission ration for the RDX?
2.0
Bobby J is offline   Reply With Quote
Old 12-31-2005, 03:50 PM   #4907
Superfly1967's Avatar
Thanks, one more question. I'm swithching to 64 pitch and was needing opinions as to who makes the better light weight pinions. Right now, I use Robinson Racing.
Superfly1967 is offline   Reply With Quote
Old 12-31-2005, 05:02 PM   #4908
Customworksking's Avatar
Trader Rating: 73 (100%+)
Exclamation gears
Robinson is fine + if the weight of your pinion was a matter of winning or loosing Ide look into them save your cash for hopups for the car trust me
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 12-31-2005, 07:48 PM   #4909
dawgmeat's Avatar
Default I'm back in fold
Still gettin' the T2 but with no part support until 2 weeks after the come had to give RDX a second run
dawgmeat is offline   Reply With Quote
Old 12-31-2005, 08:45 PM   #4910
PomAbroad's Avatar
Send a message via Yahoo to PomAbroad
Talking
Happy New Year everyone.
Associated RC12l4
Schumacher Mi4CX, Spektrum DX3S
Smash'Em Racing, WA's home of fun in R/C motorsport, Insert credits to continue......
PomAbroad is offline   Reply With Quote
Old 12-31-2005, 09:32 PM   #4911
dawgmeat's Avatar
time to hit the club happy new year
Old 12-31-2005, 09:35 PM   #4912
stiltskin's Avatar
Trader Rating: 102 (100%+)
Welcome back. Let me know when you're ready to sell this one.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-01-2006, 01:32 AM   #4913
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
Good Luck to team Corally in 06 !!!!
see ya at the birds !! let's kick this F'er off with a bang !!!!!!!!!!!!!!!!!!!!!!!!
Teee 2 ................. tooo baddd ..................RDX in 06 !!!
Cuffs gimmie an IM I need to discuss 19T
Thanx buD
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 01-01-2006, 02:26 AM   #4914
Dude ditch that MSX ....... opps .... i mean T2......."
Corally ... maybe add some flex in the suspension
word here by other drivers ... in carpet........... " car breaks to easy"
Jeff,..... gimme to test .........
50% graphite :
75% graphite :
Arms
4 and 6 deg carriers
steering knuckes
0 deg offset rear carriers
Is it possible ??
Thanx Bud !!!!
CeLbRatiN Here IN NY 06
Old 01-01-2006, 10:18 AM   #4915
ebone's Avatar
new to this car so bear with. the little dots on the hinge pin adjustment block? do those go up or down, or a combination of both?
ebone is offline   Reply With Quote
Old 01-01-2006, 10:30 AM   #4916
teetwo's Avatar
Send a message via AIM to teetwo
Are you talking about the bulkhead? I know theres two little dots on the bulkhead, on that is up, one that is down. For carpet, you want to put the hingepin holder on the bottom hole. That is for lower center of gravity, less body roll, better control. Hope that helped.
teetwo is offline   Reply With Quote
Old 01-01-2006, 10:33 AM   #4917
syndr0me's Avatar
Trader Rating: 32 (100%+)
Generally both down. You can stagger them (one up, one down) if you'd like that. That's how you adjust anti-dive and anti-squat. Putting them both up will raise the arm evenly and change the roll center. If you're running carpet, most people run them in the lowest holes on the bulkhead, and have the small holes pointing down.
syndr0me is offline   Reply With Quote
Old 01-01-2006, 11:47 AM   #4918
Thanx buD[/QUOTE]
whats up buddy what do u need to know
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 01-01-2006, 09:02 PM   #4919
PomAbroad's Avatar
Hey guys, I wonder if you can help. We just started running rubber at our club for the new season, and i'm not sure if my tyres are wearing as they should. The front right tire is wearing extremely on the very inside of the tyre, down to the canvas after 7-8 runs. I run a 9x1 on a tight technical track, there are two flat out 90 degree left hand corners one after the other that I beleive are causing the excessive wear. Does this sound normal for rubbers? My setup is as follows:
Front
5mm ride hight
2mm droop
2 deg caster
0 deg kickup
1deg toe out
-0.5 deg camber
Roll centre 1-1
Camber link top row 2nd hole from left
1.3 pistons, 17Lb spring, 40WT oil.
Shock outer hole on arm, 2nd hole in on tower.
No anti-roll bar.
What to do next?
Any help appreciated
Kev
Associated RC12l4
Old 01-01-2006, 10:26 PM   #4920
Atomix's Avatar
Front
5mm ride hight
2mm droop
2 deg caster
0 deg kickup
1deg toe out
-0.5 deg camber
Roll centre 1-1
No anti-roll bar.
What to do next?
Kev
Are you running the kit ackerman setting?
What tire / insert combo are you using? 1/2 a degree camber doesnt sound like alot for this to be happening??
Atomix is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
