Old 12-12-2005, 09:45 PM   #4636
Trader Rating: 17 (100%+)
Hey guys, I just bought an RDX for getting back into touring car racing so I had two questions:
1st question is which setup do you guys prefer for ozite carpet with the rubber backing?
2nd question is since I bought the UK Version I will rebuild the car but do you have any recommendations to get or upgrade?
Thanks.
429racer is offline   Reply With Quote
Old 12-12-2005, 09:56 PM   #4637
for carpet rubber use Rob Michael set-up form the Novak RAce 05 ...i use this set-up as a starting and i don t have to change a lot of think! i try it a 3 different track and a those track this set-up was really fast!
Pace
Pace72 is offline   Reply With Quote
Old 12-12-2005, 09:59 PM   #4638
Sorry I should have said stock foams and soon hopefully mod for question 1.
Old 12-12-2005, 10:02 PM   #4639
for stock foam go with Jeff Cuff set-up from Las VEgas...this one is really good!
Pace
Old 12-12-2005, 10:10 PM   #4640
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Pace you liking the car?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-12-2005, 10:16 PM   #4641
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
you have a pm, Mr. McGreeeeeeevy.....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-12-2005, 10:24 PM   #4642
Brian, i don t have use your car yet....i will use your car when i will run 19T.
Pace
Old 12-13-2005, 07:03 AM   #4643
raffaelli's Avatar
Originally Posted by Big Rigg
The same thing happens to my car all the time... spins when turning one direction but is super dialed the other... 99.8235721% of the time it is because of a small hairline stress fracture on the tip of the A-arm outside of the small hinge pin... the castor block or rear hub will twist in an impact and break the arm in the same spot every time (I have about 8 or so arms that all broke that way) it is usually hard to see the break... try taking all the castor or hub off the arm then twist the end of the arm if you're not sure...
Hope this helps, good luck
Thanks, I will post what is wrong when I get a chance to tear it down.
24ITA
raffaelli is offline   Reply With Quote
Old 12-13-2005, 07:04 AM   #4644
raffaelli's Avatar
Originally Posted by Fatboy Joe
check your CVD pins, all of your bearings, your shocks (if any of them have leaked), diffs in the rear, your oneway bearings in front. i had the same experience before but with a different car, a cvd pin was loose and was intermitently popping out as i turn so it binds and causes it to spin out. also, seized bearings can cause it too, they may feel ok but once some forces act up during cornering, they bind too. i hope this helps. im getting my RDX soon, cant wait to build it
Thanks, I will check you list out when I tear it down.
24ITA
Old 12-13-2005, 10:02 AM   #4645
Mission_carbon's Avatar
Pace
Sorry for my blindness but i cant find that on there site have you got a link
Mission_carbon is offline   Reply With Quote
Old 12-13-2005, 10:08 AM   #4646
http://www.corallyusa.com/2005/setups/RDXNovakRob.pdf
Another really good one is Jason Ertrachter's winning setup from the IIC Vegas race.
http://www.corallyusa.com/2005/setups/RDXiicJason.pdf
USVTA Member #211
Old 12-13-2005, 10:29 AM   #4647
Thanks Brian Ill be using that next round of carpet thrashnal
Old 12-13-2005, 08:45 PM   #4648
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default question for about shims under couplings (jeff b/corallyusa)
With Jaco tires what is the correct shim under coupling for the front and rear to get the correct track width.
If I switch to the 2degree toe in hubs how would I have to shim the car to get the correct trackwidth.
I have tried both Cuff and Toso setup and the car seems to push mid corner on low speed/med speed turns....I am have the stock couplings as listed in the intstruction...1mm on all of the front and 1.5 shims in rear on rear set of couplings to get 1.5 toe in.
J.Gonzalez is offline   Reply With Quote
Old 12-13-2005, 09:30 PM   #4649
You want to run 2.5 mm in the front. This should make the car more stable and I noticed it gave quite a bit more mid and exit steering.
USVTA Member #211
Old 12-13-2005, 09:43 PM   #4650
Korey Harbke's Avatar
I'll second that, 2.5 is usualy where I start for anything. I've even run as much as 3mm on some wheels for asphalt racing.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
